So, the engine has been totaly re-build. Its a Cosworth YB. N/A.
The head is ported, New valves, springs, guides etc. Its on twin 45's It runs as sweet as a nut.
BUT. One or possibly two of the lifters just wont stop tapping.
Truth is, sometimes it goes quiet until engine is hot.
I have changed the oil and filter twice.
Fitted new ENA lifters.
Cams are new mild road Newman.
Oil pressure is very good at 60PSI when hot.
The top end has plenty of oil around.
Im now desperate to cure this issue as its driving me mad.
Someone on another forum said clean the oilways in head but dont know where they are and as I said lots of oil in top of engine anyway. Also, as it sometimes goes quiet Im thinking no blockages there.
Also it has been suggested the bores for the lifters could be worn oversize, they seemed a good fit when I changed them. Im pretty sure the noise is on the exhaust side at the back. It is 100% lifter noise, not piston slap or valve contact, I have checked. I have had the cam cover off and cams are not worn at all. I did purge the oil pump with a drill before the cams where fitted and had good oil flow from oilways in bearing carriers.
Im reaching the stage now of considering buying another head and ditching the one I have but its not cheap especially when it will need porting etc.
Could it just be a new lifter or two needed even though they are new. How can I tell what lifter/s are faulty. Tried the squash test and even the quiet ones seem to compess easily. The Engine has done around 150 Miles now and still taps.
Really appreciate any suggestions guys, im desperate.!
