So..
Im trying to work out a compression ratio for a proposed build.
Its a Cosworth N/A.
Using the online summit calculator at say ''for domed pistons use - and for dish use +''
Now, Im using Wossner N/A Pistons but are they a dome or are they a dished piston.?
https://www.shopbhp.com/products/wos...ed-pistons-set On the Wossner website it say +11cc which makes them a dish I would have thought? but surely a + indicated adding volume i.e a dome.
https://www.summitracing.com/newsand...ion-calculator Specs are as follows:
Wossner 92mm Cosworth n/a Pistons. flush with top of block.
93mm diameter head gasket ?
92mm bore
76.95 stroke (standard)
4x4 Cylinder head. Chamber volume of 41cc
Any help most welcome.
