facet pump
is there an issue with fitting a facet redtop? below the fuel tank, at the moment its in the boot bolted to the boot hinge strengthener above the tank, Im not keen on there where its mounted, mostly because of the safety issue and the noise issue in the cabin, especially as I would like to move the battery to the boot as well,
Re: facet pump
Those Facet's have good suction spec's so fitting above fuel level is ok but a fully gravity flow position below the floor is a better solution. Tucked out of the way so its not too low and should work fine.
Just be aware that when they fail, it'll AWAYS be after you've brimmed the tank LOL!
The Following User Says Thank You to katana For This Useful Post:
