Originally Posted by
Graham latest update on the test is, the valves are still sealing perfectly. When i had the pistons out i overlaid the top compression rings from cyls 1+2 over 3+4 and they matched exactly for dia and gaps, so despite me initally thinking there was a tension difference there isnt one.
So we are back to head gasket, with no signs of a blow on blow or head face or outer faces of the gasket i can only assume it was an internal blow between layers, ive never seen that on a cometic but i have seen it on standard manufacturers mls gaskets. With hindsight i undid the head with what was a realitively short breaker bar, shorter than i would normally use and they didnt seem to be overly tight. i cant rememeber if i retorqued the head bolts, BUT despite always checking i have never had head bolts clamping a cometic head gasket tighten up further after running an engine.
