most of you guys have heard of the almost mythical Harris pintos.
this one is fairly old and was probably built by the now passed Ron Harris
https://youtu.be/3P_NH_GZHgs
It may have been happily used for its intended purpose but for this owner to use on the road - no wonder he wanted it sorting out, its not being very flexible is it!
Good video as ever - liked the Zodiac one also, ingenuity abounds!
When i got the notification on youtube for this - i was really curious to see it - and the result is sort of 'as expected'
no doubting they build alot of good going reliable engines. no doubt. But, they definitely have marketed well and got the sunday morning burnout crew well and truly on board over the years.
That carb setup is simply ridiculous, it seems some people think ' the worse it idles and runs below 4k, the cooler and faster it is' they had smaller chokes on manta 400's.
that made no more that a well build homebrew pinto in a shed, and would have done those numbers happily on 36 chokes. appreciate it may be a little tired.
Makes no difference though, some people will be happy with that to have a sunstrip on the window
Excellent video Graham, quite impressed with the numbers for a tired engine, I suspect for hill climb events this would have been a good performer.
hope my engine when it gets installed will give good numbers although I've requested that it built to be road engine with emphasis on good spread of high torque.
http://www.turbosport.co.uk/showthre...t=#post3756365
Cannot wait to the see the strip down .
dont hill climbs have any corners seems rather hairy even for hillclimb.
I don’t suppose 190 bhp is too bad, allowing for a little bit wear and tear, all in all its general health can’t be in a critical condition if it’s making those figures. Judging by the torque numbers and where it peaks the engine must be fitted with a full Race cam; whether there are any identity marks on it is another matter. As for the big 50’s getting the choke size down to a sensible level could prove rather difficult.
I think the same as MM, 45’s and a more sensible camshaft if the Engines’s going into a Road car. Another thing for the owner to consider is the gearing including final drive along with wheel and tyre size, all can have a big effect on how an engine performs, especially at starts and low speed driving.
It’ll be interesting to see what the head looks like when it comes off, I doubt there’ll be anything to surprise you Graham. Looking forward with interest.
It'd be interesting just to swap to EFI and mappable ignition, to see how much the older oversized carb and dizzy are holding a setup like that back, perhaps mostly at the lower end.
I'm sure up top the carb/dizzy can still perform well up top...albeit to the detriment of the low end
Scope and pulse sensor in the crankcase would help identify any cylinders with excessive blowby.
It looks like this thread’s now being discussed on the P*** Heads Forum! There’s some very knowledgeable people on there and there’s also plenty of Richard Heads.
Did / does Harris have a dyno (or rolling road)?
Haven't heard from either of them in a while.
Hopefully they're both well.
Hi Graham have u started any work on the harris motor like a camshaft change cheers mario
maybe............ i might end up running the test more than once, because the current plan is to use the 40/41 equipped engine currently on the dyno.
this evening i pulled off the 45's and stuck a dgas on, unsupringly it dropped nearly 20bhp. next up i chucked a single 45 on a lynx manifold on, that was an eye opener, that gave a fraction more power than the DGAS, loads more low down torque, but power dropped off really quickly after peak. judging by teh high rpm stand oof the 40/41 has too much duration to work properly with single carb
Good grief that takes me back to 1984 when the two choke rule came in for Road Rallies. We tried a 38 dgas and struggled to get the thing to run anything like, we discarded that in favour of a single 45 Dcoe on a Mellors Elliot manifold which was the old Autovita one. The engine ran much better on it apart from a massive flat spot in the mid range which proved very difficult if not impossible for the best of the Rolling Road operators at the time to sort out. With a std 2.0 bottom end, a virtually std head and a WR40 cam the best power we saw was 115 bhp @ the wheels, the worst was 85 bhp.
i didnt know that
the single 45 suprised me in another way too. if you compare the 38dgas to single 45, they peak about the same point, but the 38dgas actually held onto power betterjudging by the amount of fuel standoff id say teh cam has too much timing to work well with the single 45
Wouldn’t it be nice if someone lent you a pair of split Weber’s to test, I think you’d be surprised how good they would be. All the standoff problems with too much cam was issues people had 40 years ago with the single carbs and long duration cams. Brookes was the first to my knowledge to do the split manifold for a Pinto.
Is it this one? Are they 48's?
Even back then there were several cams for the Pinto from fast road to race.
My RS had a Crane P284 cam, with a modified DGV it had 112 bhp at the wheels.
Have to get the magnifiying glass out G - those are definately 48's. Either way you'd have to have deep pockets to take a saw to two DCOE's, as opposed to just one, but that does look lush!
Those FAJS Weber replica's are just GBP 294 from IKE (and that's the 5 progression hole version), cheaper if you get them from China directly.
It’s stamped 48 DCOE on the body, whether that’s the actual size is another matter.
The manifold looks different to the Brooks one, his has a balancer chamber similar to the BMC SU manifold.
It will be interesting when Graham gets a set on the Dyno to see how they compare to the twin 45’s.
compaired to twin 45's they are simlar low down but 14bhp shy at the top.
they were better every where than the 38dgas.
compaired to the single 45, they were significantly better once past 4500, but couldnt match the single at lower rpm, but oddly the single 45 was better low down than even the twins, however at high rpm the single 45 threw so much fuel back out the intake i was worried about it becoming a flame thrower, clearly the single 45 on the lynx and engine and 40/41 cam combo wasnt good at high rpm
