Hi all,
I am running an st170 engine and type 9 gearbox in my mk1 escort. I have got it all running but the car crunched into gear and lunged forward stalling the engine (when the clutch was fully pressed). When I wound the clutch in a bit, so the bearing was tight up against the clutch, I can now change gears but the biting point is right at the bottom of the pedal travel. Here''s a run down of what I have.
St170 engine.
Retroford zetec flywheel drilled for a pinto clutch
2.0 pinto clutch (quinten hazel)
capri cast bell housing with cable clutch (square-ish bellhousing not the rounded type)
RS2000 CL bearing
type 9 gearbox.
Cortina type 9 fork
I have spoke to several people and they all say this should work, But it doesn't and it's got me stumped. The only solution I could think of was to cut and reweld the fork in a more forward position.
Has anyone else had this trouble and if so how did you fix it?
