Results 41 to 80 of 81
Thread: Captain Sensable YBT
  1. #41
    Sep 2005
    Wiltshire
    701
    Re: Captain Sensable YBT
    I have seen this on all cosworth engines, and one was a genuine standard 20k mile car I took the head of to upgrade the gasket!
    Should have had reliefs as standard.
    yes clint your right thinking about it i was offered some 4x4 pistons and rods and they had valve dinks in them
  2. #42
    25,118
    basic, but a pillar drill and scales are good for testing valve springs, i tested a set of used std springs, most were ok but several were defiantly a bit down on pressure so we got a new std set of springs
    a quick ccing of the head,
    cr is a little over 8.1 so i will leave alone.
    pic of a crank, no particular reason other than its the std/std un ground truftrided crank from the linford pinto
  4. #43
    25,118
    skimmed head and block makes a bolt length check important, just to be on the safe side i took a little off the ends on the front 8 bolts, the rear to are sunk deeper in the block so i didnt bother
    in order to locate the gasket i cut down some old bolts, build a ring of braze up on it and turned it down to suit the holes in the gasket, it nearly worked too! just two bolts located the gasket really well, only one drawback, the front one wouldnt come up through the head so by the time id turned it down enough that it would go through the head it didnt locate the gasket nearly as well, using a 3rd bolt helped with location
  5. The Following User Says Thank You to Graham For This Useful Post:
  6. #44
    Nov 2004
    Sunny Essex
    4,831
    100
    Oooo, excited face. Stunning work Graham, gives me so much confidence to see the lengths you go to even at this stage of assembly. C/R is spot on, which considering the skimmed head, block and valve cutouts is some miracle you've pulled off.
    What's left to do now?
    Nov 2004
    Sunny Essex
    4,831
    100
    Not gonna sleep now...
    Mar 2008
    west bromwich
    1,861
    i know what you mean dave carnt wait for mine off joe
  9. #47
    Mar 2008
    west bromwich
    1,861
    here another one
  10. #48
    Mar 2008
    west bromwich
    1,861
    and with rex fitted, sorry david to hijak the thread but iam as excited as you son
  11. #49
    Dec 2008
    Finland
    2,106
    62
    Is that an alli alternator mount?
  12. #50
    Clint's Avatar
    Jul 2001
    936,154
    Lovely work Graham
    Quote Originally Posted by xpackboy View Post
    Why is there chucks out the side of the pistons, did the piston slip when they tried to do the valve cutouts?
  13. #51
    25,118
    Lovely work Graham
    that pick is x packs engine, the one i did is further up the page
  14. #52
    Clint's Avatar
    Jul 2001
    936,154
    Sorry for the confusion G, I was asking xpb
    Your pockets look perfect
  15. #53
    Mar 2008
    west bromwich
    1,861
    joe only does perfect ! thanks for the comments clint , sorry for the confussion graham
  16. #54
    Mar 2008
    west bromwich
    1,861
    yes it's an alloy bracket off anembo engineering on here nice guy Greg
  17. The Following User Says Thank You to xpackboy For This Useful Post:
  18. #55
    Nov 2004
    Sunny Essex
    4,831
    100
    Nice engine xpack, now stop showing off cos you've got a bigger turbo than me
    Mar 2008
    west bromwich
    1,861
    lol thats rex, t rex hes for big hp son ,sorry for the hyjak
  20. #57
    Nov 2004
    Sunny Essex
    4,831
    100
    No probs, look forward to seeing it
    Nov 2004
    Sunny Essex
    4,831
    100
    Engine at Grahams almost finished;
    See here for the install progress; http://www.turbosport.co.uk/showthre...133380&page=27
    Nov 2004
    Sunny Essex
    4,831
    100
    Meet Linford Jnr, all built up now and ready to drop in. Massive thanks again Graham, amazing work
    Mar 2008
    west bromwich
    1,861
    Looks the nuts son
  24. The Following User Says Thank You to xpackboy For This Useful Post:
  25. #61
    25,118
    just got off the phone to dave,
    its survived a mapping session, which is always good, not forgetting this isnt actually a yb, its a pinto with a yb head!
    i wont give the figures away,
    but they sound quite good given the near std nature of the top end and a small turbo, which was only taken to 1.5 bar in the interests of long life
  26. #62
    Nov 2004
    Sunny Essex
    4,831
    100
    Well she produced the goods. Once up and running it mapped like a dream and never missed a beat after 5 or 6 hours on the roller.
    Made a smidge under 330bhp and considering the std cams, small turbo (T34/.48), vxr injectors and hybrid engine (2wd,4x4 + race pinto) is a fantastic package. Has a lovely torque curve and should be very nice to drive. With the lighter bottom end and race flywheel it doesnt take too long to get to 7500 rpm either!
    Everyone was very complemetary about the build at the track n road and they said the results were brilliant.
    We could have thrown more boost at it (under 1.5 bar) but it would have lost the drivability and not added a lot on the top.
    If I do ever upgrade this engine, maybe after a couple of refreshes they said that cams, a bigger turbo and injectors would see a fair hike in power without a lot of work. For now though this has turned out exactly to plan and I cant thank Graham enough for all of his time, should be a lot of fun and not over stressed.
    Nov 2004
    Sunny Essex
    4,831
    100
    Just a couple from yesterday..
    Moderator+ Decade Plus User
    dangerousdave's Avatar
    Oct 2002
    London
    15,132
    65
    Should be nice and punchy for you Dave, what torque did it make and at what rpm? Better still post the graph
  29. #65
    Nov 2004
    Sunny Essex
    4,831
    100
    Will post up some more info asap but for now I'm just so happy that it is running and doing everything we hoped it would.
    Nov 2004
    Sunny Essex
    4,831
    100
    272 lbft /6000, peak power at 328hp /6700. About 300hp @ wheels.
    Revved to 7500, which was over 150mph even with the n/a spec diff
    Nov 2004
    Sunny Essex
    4,831
    100
    Also mapped to 293hp with boost control switched off..
    25,118
    its revving well, must be the head work, cos its not the cams or turbo making it rev. the fact its revving so well is a bonus, because that means the n/a diff ratio can stay, so with the great throttle response on track it should perform like its got more like 400bhp. but running the boost it is, hopefully it and the turbo will have a long life.
    im sure that more boost could of picked up a big chunk in the midrange, although as dave said i dont think youd see any large gains to be had at the top perhaps another 20bhp, but when you have 330, going to 350 isnt that much of a gain anyway
  33. #69
    Nov 2004
    Sunny Essex
    4,831
    100
    Diff might be ok for brands, lydden and even silverstone national.
    I was surprised when I saw power runs going past 150mph!
    Pit Crew Decade Plus User Toymex's Avatar
    Jan 2004
    farnham surrey
    1,337
    Quote Originally Posted by david_white View Post
    You will be doing well if you see those sort of speeds Dave
  35. #71
    25,118
    there are not many places your see 150mph, withteh turbo beemer i maxed out at 158mph at snett, but that was with about 50% more power than you have
  36. #72
    Nov 2004
    Sunny Essex
    4,831
    100
    Yeah not expecting that speed on track but good to see it wasnt nearer 130! Be interesting to see how it compares to cars with more power but longer gearing, ie the other 2wd cossies out there
    Ireland
    3,579
    173
    Great job on the engine as usual Graham, it is a nice torquey responsive engine to drive I am sure, some of the cars with more peak power may have trouble keeping up with you Dave, the head porting is certainly a key ingredient, I think Graham goes well above the Real flow figures most full time head porters achieve
  38. The Following User Says Thank You to RWD fords rule For This Useful Post:
  39. #74
    25,118
    with the head i had to stop myself! i ported the inlets 3 times, keep going back and improving more, i only did a fairly basic job on the exhausts, reasoning once your past obstructive lump of guide boss, it was the turbo that was the restriction
  40. #75
    25,118
    nicked off facebook
    low and not so low boost, cant call it high boost because it isnt! hard to see not so low boost line in thin solid red/brown but its there
  41. #76
    Jul 2006
    bristol
    10,882
    892
    Looks good bud
  42. #77
    Jun 2007
    Whitley Bay
    3,437
    81
    Sorry to bring up an old thread Graham, but would like to know how this engine got on with the pinto crank
    Did it ever see a power increase or turbo and cam swap?
    Did the engine do much racing?
    Any issues?
    Got an engine to put together soon and im looking at a similar spec ported head, hybrid t34/48 housing and would like a puncy 380-400bhp on standard pinto crank if possible
    Screaming 1300 mexico rep
  43. #78
    25,118
    its done a few races, but has never been cranked up for more power.
    pinto crank is plenty strong enough, vizard was building 400-500 bhp turbo pintos using standard cranks 20 years before the yb appeared!
  44. The Following User Says Thank You to Graham For This Useful Post:
  45. #79
    Jan 2007
    Finland
    12
    Any estimates how much beating 1.6 liter pinto crankshaft (66 mm stroke) will take?
    I have YB head and blue injectors which limit the power now. Never dynoed it, so don't know if there is 270 hp or less.
  46. #80
    Quote Originally Posted by pta View Post
    Turbo or NA?
Tags for this Thread
