Page 5 of 10 FirstFirst 1 2 3 4 5 6 7 8 9 10 LastLast
Results 161 to 200 of 380
Thread: Turbo Xflow ... worth it?
  1. #161
    Nov 2011
    Cwmcarn
    301
    Re: Turbo Xflow ... worth it?
    No, I think you got it wrong. I believe you take "compression reading" for "compression ratio". We are talking about compression ratio so you have to calculate / measure the total capacity of the combustion chamber (gasket etc.. including) end calculate the compression ratio compared to the total engine displacement. This is very important and that the number we need. It should end at approx 8,5/1.
    There are a lot of good readings about this on internet. Or just buy any silly tuning book. Most of these books are totally useless, copying each other but.... they all have the right calculations in it.
    Okay I'll look into that then cheers
  2. #162
    Nov 2011
    Cwmcarn
    301
    Also I'm going to get my pistons ceramic coated as advised. Is it worth getting new rings?
  3. #163
    Mar 2012
    2,118
    Personally, I don't like new rings on used pistons. Usually the piston groove is no longer straight and the ring has the same shape. Fitting a new ring often means the piston only support the ring on the inner side and ring will brake under pressure. Or the rings AND pistons are OK, or you replace both if to far worn out. In some occasions you can machine the ring groove wider (back in correct shape) and fit slightly wider rings. So you can use older style Pinto rings (wider) in later type pistons but no idea it's also possible for the KENT.
    Coating is a good idea. If budget allows. It will keep the heat out of the piston. I've been using a cheap setup water/methanol injection system to do the same. Just as in these cheap tuning books I've fitted a pressure sensor in the manifold, windscreen washer pump and reservoir, a solenoid to be sure the supply was shut of when not needed. It also keep the combustion chamber cooler and believe me, the engine was very prone for pinking, after fitting this setup, bullet proof against detonation. Only little water/ methanol is needed. Jet was set to spray 3 liter/hour if in constant use. Please deduct the boost pressure from your water pump pressure if you test the capacity of your system. fool the water pressure supply by fitting a "waste" so you lower the line pressure the same as you want the boost pressure. Now you can test your capacity.
  4. #164
    Nov 2011
    Cwmcarn
    301
    That's great info again onyd thanks again!!
  5. #165
    Nov 2011
    Cwmcarn
    301
    Is there any other bits I should look at getting coated or is it not cost effective? Inlet manifold?
  6. #166
    Mar 2012
    2,118
    Piston is most important. I don't have an idea what it will cost. If cheap, go for it. But you don't have to build an engine so close against the dead line. In the engines I have in mind, you don't need any of them. With a moderate boost of 7 psi, 8,5/1 and rich jetted at full load nothing is going wrong. I feel, the water/methanol is a better way to keep temp out of the engine as coating. But don't start rushing for something you don't need. If you feel saver, OK, install.
  7. #167
    Nov 2011
    Cwmcarn
    301
    Pk thanks again
  8. #168
    Nov 2011
    Cwmcarn
    301
    Okay so overall here is my idea:
    I'm using a 1660 Xflow block
    Lightened pistons machined to give me 8:1 cr
    Ceramic coat pistons
    Get crank reground and new main bearings
    Fit new big end bearings
    New crank seal
    1300 can
    High pressure oil pump
    Oil cooler
    Chambered head
    Double valve springs
    Lightly ported on inlet
    Duplex timing gear
    T15 turbo running 7-8psi
    Intercooler
    Bike carbs - no injection
    New gaskets and seals throughout.
    Does this sound like a plan?
  9. #169
    Mar 2011
    Australia
    58
    Does your 8:1 machining in the pistons take into account the chambered head?
    The t15 is a fairly small turbo, I'd dig up compressor map for it to check out how it will go with 1660cc. My gut feel is that you're going to want at least a t20 or t25.
    Looks good otherwise though
    Mk2 2 Door Cortina, Injected Turbo 1600xf
    http://www.turbosport.co.uk/showthread.php?t=375976
  10. #170
    25,127
    no need for double springs if using a std cam, bike carbs will just prove a pain to fabricate a air tight airbox, and in any case you really dont need the airflow potiential they give, stick with a single car carb. either mod the pistons or use a chambered head, no need for both
  11. #171
    25,127
    one thing you should strongly consider is having unleaded exhaust inserts fitted to the head. non unleaded head and turbo heat will kill exhaust seats FAST
  12. #172
    Mar 2011
    Australia
    58
    My 2c only, but I'd stick with the double valve springs. We began to see valve float at around 6k rpm with 8psi and a GT cam. Stock springs are only around 40lbs, so once you subtract around 10lbs for the boost (boost pressure * the inlet valve area) it's like running a 30lbs spring.
  13. #173
    25,127
    heavy duty singles are more than man enough
  14. #174
    Nov 2011
    Cwmcarn
    301
    Well I've got double springs already so may as well use them. I'll look at having unleaded valve seats putting in then good shout. So run a Renault 5 turbo carb then? Rather than bike carbs/weber 40?
  15. #175
    Nov 2011
    Cwmcarn
    301
    And I'll check if I can get enough off the pistons before buying chambered head
  16. #176
    Nov 2011
    Cwmcarn
    301
  17. #177
    25,127
    snake oil mate, proper inserts are the only way to do it properly
  18. #178
    Nov 2011
    Cwmcarn
    301
    Okay thanks
  19. #179
    Nov 2009
    essex
    6,623
    338
    go t20 to t25 turbo. run an r5 carb and personally after skimming and coating the pistons which are also second hand it's prob gonna set you back nearly 200 quid and they will still be your weak point and your boost limit, for the sake of 200 quid more, buy proper forged pistons and get it done with imo. then your engine can and will take 150bhp all day every day without trouble.
  20. #180
    Nov 2011
    Cwmcarn
    301
    Forge pistons are £650 a set that's out of my budget
  21. #181
    25,127
    better to save up for a while and do it properly, cheaper in the long run
  22. #182
    Nov 2011
    Cwmcarn
    301
    Hmm maybe I'll see
  23. #183
    Feb 2007
    west midlands
    1,171
    32
    Personaly i would go for forged pistons as you've been advised. It will be cheaper in the long run and safer. Standard xflow pistons break easy in n/a engines. Renault 5 carb on a single choke manifold. All you need to do is drill the mountig holes on carb bigger to fit
  24. #184
    Jan 2008
    Up the garage
    2,775
    218
    In my experience cast pistons become worn on the top ring lands very quickly which means that the ring doesn't fit tightly enough in the groove, which in turn allows more gas to get past, and it allows the ring to move in the groove more and more on an ever increasing scale - the bigger the gap, the quicker the wear appears. Think of a moving piston ring like a hammer and the more space it has the more powerful the hammering becomes.
    Some pistons in naturally aspirated engines I have seen are worn within 5000-10000 miles.
    Taking a set of already worn pistons and getting them ceramic coated is going to be a waste of money and similar to making a silk purse out of a sows' ear.
    Buy forged ones - maybe even custom made ones - to suit your application. They will last a lot longer and will do the job properly.
  25. #185
    Nov 2011
    Cwmcarn
    301
    Quote Originally Posted by looneytune View Post
    Okay thanks mate I'll certainly look into it
  26. #186
    Feb 2007
    west midlands
    1,171
    32
    I'll second honkywhitetrash's post aswell
  27. The Following User Says Thank You to looneytune For This Useful Post:
  28. #187
    Nov 2011
    Cwmcarn
    301
    I'm just trying to build on a bit of a budget like but obviously forged are ideal I'll just have to see
  29. #188
    Jan 2008
    Up the garage
    2,775
    218
    Building on a budget and putting a hole in a piston is not really good economic sense when you have to start again! I can understand your limited funds but if that's the case take your time and do it right!
    I always think "you buy cheap you buy twice" comes true more often than not.
    Most people who are advising to spend more have probably made the mistakes that you are likely to encounter!
  30. #189
    Nov 2011
    Cwmcarn
    301
    Quote Originally Posted by HonkyWhiteTrash View Post
    Yeah I know that yeah have to wait a bit then I guess
  31. #190
    Jan 2008
    Up the garage
    2,775
    218
    It'd be a good opportunity to read a bit about engines, and turbo theory, and also get your cylinder head sorted with unleaded seats, nice quality valve guides that don't have play between the valves and guides, and a good valve job. Valves that seat/seal properly with nice wide contact areas will help the valves get rid of the excessive heat generated by the turbo.
    I can guarantee that with a little bit of reading your desires and approach to the job will change as you realise what is and isn't possible.
  32. #191
    Nov 2011
    Cwmcarn
    301
    Forged pistons it is. Just dropped mine and cracked one ...
  33. #192
    Nov 2011
    Cwmcarn
    301
    Can anyone recommend somewhere to get the unleaded head done?
  34. #193
    9,216
    168
    lyons in brynmawr will do it, ask for mike harris . if you pop up they have a shop entrance, go to asda but turn right on the next roundabout and its on the left.
  35. #194
    Nov 2011
    Cwmcarn
    301
    I have mikes number I'll call him tomorrow
  36. #195
    Nov 2011
    Cwmcarn
    301
    If I was to go fuel injection what's the cheapest way?
  37. #196
    9,216
    168
    bike bodies and megasquirt probably cheapest, not easiest tho ..................
    unless you can mod an escort zetec plenum system to fit x/f
  38. #197
    Mar 2012
    2,118
    I've got no idea how good you are with carbs but fitting bike carbs and turbo charge them?!? Yes, sound easy but believe me, a lot more difficult as using a R5 turbo carb. Not saying It can't be done.
    Prices of fuel injection systems did not raise in the last 15 years. No idea which would be cheapest, probably if you can reprogram an OEM ECU but I can't. If you can solder, maybe Megasquirt would be cheapest but best you know something about electronics and computers.
  39. #198
    Nov 2011
    Cwmcarn
    301
    Okay I'll ask someone good with electrics (y)
  40. #199
    Nov 2009
    essex
    6,623
    338
    maybe look into something real simple like single point injection like the mk3 fiestas etc had, seen quite a few kits about in the past for not alot.
  41. #200
    9,216
    168
    the thing is, going full mappable injection and turbo just to get 150 bhp from a worn x/f makes no sense to me whichever way i look at it ?
