Results 1 to 24 of 24
Thread: 2L Pinto- Crane Roller Cam- Weber 50's
    Pit Crew Decade Plus User Group4_Mark2's Avatar
    Dec 2004
    Ireland
    1,781
    31
    This is the results of my most recent build
    The spec is
    2050 Pinto
    136mm PEC I-Beam rods
    Woosner pistons
    Ported head (44.5mm inlets 38mm exhausts valves)
    12:1 compression ratio
    Crane roller cam 260 degrees duration @ 50thou lift
    Esslinger Valves.
    Custom tuned distributor from Jason (Rwd fords rule)
    Cranks scraper from Jason (Rwd Fords rule)
    Standard Pinto Crank triple doweled to flywheel.
    Modified Twin 50 carbs
    Tuning in the car by RWD Fords
    There was only one power run on the dyno with no tuning
    A little in car from the sligo Rally
    http://www.youtube.com/watch?v=l22-tRzHMww
    Tom
    May 2010
    West Wales
    203
    Re: 2L Pinto- Crane Roller Cam- Weber 50's
    Impressive
    Dec 2004
    Ireland
    1,781
    31
    The cam was timed with 6 degrees advance to give better low down torque at the expense of peak power. If it was retarded a few degrees I think that the 200bhp would have been possible.
    The dynamic compression ratio was also a bit low so a higher compression ratio or a cam with different timing would have perked up the figures quite a bit also.
    Tom
    Racer Decade Plus User RWD fords rule's Avatar
    Ireland
    3,579
    173
    Nice work Tom very good porting work on the head, 13 to 1 would add a lot of torque all the way up with that cam esp low end but she's going like stink as it is with a nice spread of power
  5. The Following User Says Thank You to RWD fords rule For This Useful Post:
  6. #5
    May 2007
    Vic, Australia
    662
    133
    Well done! Did you end up sourcing the cam blanks? Is this the profile you will be making copies from? Where do I sign up?
    Shaun
  7. The Following User Says Thank You to escortinadriver For This Useful Post:
  8. #6
    Pole Position Decade Plus User M11rf's Avatar
    Apr 2004
    Bangkok, Thailand, Thailand
    4,346
    479
    I bet that is nice to drive... All the way to 8000
    Nice torque.
  9. The Following User Says Thank You to M11rf For This Useful Post:
  10. #7
    Dec 2004
    Ireland
    1,781
    31
    Quote Originally Posted by escortinadriver View Post
    Shaun
    Hello Shaun,
    Sorry, I meant to respond to you about the cam blanks.
    This is the original cam that I wanted to get copies made from. The thing about this cam is it could be better. The timing is not optimal for 12:1 compression ratio so I had to advance the cam a lot to get the dynamic compression ratio in the ball park. With the same duration and different timing it would have 5 or 6 lb/ft more torque and the revs torque would hold on possibly even longer to give better peak power. The other problem with this cam is it is cast so there is a slight risk that it may break with the high spring pressure and revs.
    I was able to source a few places to get custom billet cams machined and a few to do cast roller cams. Jason (RWD_fords) on here will be doing a cam kit in the near future which should be a flyer with the correct head and exhaust setup. I will go through my email and post the cam companies in the next while.
    Tom
  11. The Following 2 Users Say Thank You to Group4_Mark2 For This Useful Post:
  12. #8
    Dec 2004
    Ireland
    1,781
    31
    Quote Originally Posted by M11rf View Post
    Nice torque.
    I have not actually driven the car but it does go well. Pulls from quite low revs all the way to 8000.
  13. #9
    World Champion Decade Plus User caprimentle's Avatar
    Nov 2009
    essex
    6,623
    338
    very nice, i love a good pinto
  14. #10
    Dec 2004
    Ireland
    1,781
    31
    Small video of the rolling road.
  15. #11
    Apr 2009
    Ireland
    Hey lads, This is my motor btw
    Just said id ad to this, Top job by Tom and Jason on this engine, 2 very knowledgeable fellas ! It really feels and sounds like a 16v.
    It pulls from practically noting, ok its on huge carbs so naturally enough it will bog down on wot below 2000rpm after that though it really is a gem.
    A wee confession.......rev limit is 8200 really is nice to have them extra few revs between corners if needed.
    Vid of it on the rollers, didn't limit it in this one.
    http://www.youtube.com/watch?v=64N-p...1&feature=plcp
    Cheers again to the lads, cant wait for the next development of this to try and keep the millington boys on their toes
    *EDIT* HA HA, you bet me to it on the Vid Tom
  16. The Following 2 Users Say Thank You to MEX8O9P For This Useful Post:
  17. #12
    Dec 2004
    Ireland
    1,781
    31
    Thanks Enda,
    Really great to see the engine in action and some good results. A little more torque at low revs would have suited the sprints better but the wide power band gets the car going well on the rally stages. Some great driving on the sligo stages.
    TOm
  18. #13
    Dec 2004
    Ireland
    1,781
    31
    Video of the car with roller pinto in action this year in Mayo.
    http://www.youtube.com/watch?v=3pS4nri4k1g
    Potentially 10th overall but for a puncture on stage 6 which lost 4 minutes.
    Also lost a bit of time here after passing an EVO on the stage
    http://www.youtube.com/watch?v=WhsskhzaxrM
  19. #14
    Jan 2009
    Germany
    428
    What is the Final Drive Ratio, please.
  20. #15
    Ireland
    3,579
    173
    Axle has a 5.14 CW+P ZF LSD 2.8 shafts, grp4 studs
    Stage 8 from the last rally:
  21. #16
    Ireland
    3,579
    173
    Video outside the car in the Sligo Rally last year:
  22. #17
    Jan 2009
    Germany
    428
    Thanks, very nice Car.
  23. #18
    Dec 2004
    Ireland
    1,781
    31
    Small update on the roller engine which still lives and gets better.
    Engine recently rebuilt and after a few years of trouble free service. Needed a new valve and some rework on the port filler. One piece had dislodged and disappeared out the exhaust.(not good but no damage done.)
    Engine is now on throttle bodies
    Not sure if the video can be seen but the following is a link from Facebook
    https://www.facebook.com/photo.php?v=662729797138178
    Only have the dyno plot from the first run but finally made 205bhp and 166lbft torque.
  24. #19
    Jun 2015
    Australia
    295
    Hi group4 mark2 what fuel did you use.
  25. #20
    Dec 2004
    Ireland
    1,781
    31
    Hi,
    Due to the cam design (Low dynamic compression ratio) then engine would run on standard unleaded without too much difficulty. However for safety it was normally run on 101 Octane.
    Recently the engine has been updated to 2.1L so the compression is up to around 12:1 so 101 all the time now.
    Recently the engine has been dynoed at 217bhp and 181lb/ft. Very happy with that
  26. #21
    25,119
  27. #22
    Jun 2015
    Australia
    295
    great result cheers mario.
  28. #23
    May 2007
    Vic, Australia
    662
    133
    Quote Originally Posted by Group4_Mark2 View Post
    Tom,
    Have you got a contact for Jason?
    Did he finish the cam package? Still based on the on from Dave in the states?
    PM me if preferred.
    Thanks.
  29. #24
    Dec 2004
    Ireland
    1,781
    31
    Hi,
    I sent you a PM but Jason can normally be found on Facebook https://www.facebook.com/jasonmc777
    Regards
    Tom
    Regards
    Tom
