Hiya dude.
My boyhood dream was also a mk3 2-door. Something we never had here, So I've settled on a moar door.
I toyed with both the 6 and the 8 before eventually biting the bullet on a zetec conversion purely for insurance/running costs.
Anything is possible if you have the time and the inclination and money. Just depends on how much work you can do yourself.
The mk3 has the same floor plan is mk4s and 5s. So Anything that will drop in to the later cortinas will drop in.
The v6 cologne with t9 box is a straight bolt in swap. You will need the t9 with the longer input shaft, and cologne Bellhousing. And the 2.3 v6 gives you very little gain over the 2L in the real world. And the Siamese exhaust ports mean the usual flow work isn't really an option for more horsepower.
the 2.8 v6 can be used for a little more go. I've had the 2.8 running a rejetted 2.3 carb and manifold in a mk5. Sounds nice, smooth, goes pretty hard (Vs a 2L). Can be done in a weekend if you know what your doing.
Also the 4L quad cam v6 is part of the cologne family, and can be shoehorned in, I've not attempted such a conversion. But I would assume it's a rather tight fit, and prolly requires some serious messing with the pipe bender to get the headers between the rails.
302/351 Windsor means cutting the front cowling and recessing the rad in under the top rail, and cutting the firewall (Look at Australian tc Cortina engine bays for an idea of what I mean) as well as a bigger tunnel. It's a lot of work. But it does get the v8 in there.
The Cleavo's are a heavier block, and bang for buck, aren't as worth doing as the Windsor.
I'm prolly gonna get boo hissed for saying it. But they really don't handle the v8 conversion all that well. They already handle like trash. Adding more weight to the front affects the steering geometry, in particular the bump steer, making them as flighty as a rabbit on crack. (I'm talking real world experience daily driven here)
And if you give it the willy too many times, you will start popping rear glass out. a Sure sign the power of the 8 has twisted the chassis (Again. Been there, tried that, busted knuckles and scratched my head over it before)
Ideally... dump the front crossmember and get the crossmember and rack from a Hyundai Stella Prima. The Stella used the same floorplan as the Cortina, So the crossmember and rack bolt in, But are heavier, add power steering, and 3degs neg camber to fix the handling problems. 15" saab rims are a bolt on. Then Cut the firewall/front Rad mount/tunnel up and biff the 351 Windsor and C6 box in. Then your still going to need to reinforce the ass end to stop it twisting under heavy load. Like when parallel parking at the local supermarket.
To keep it simple. I'd stick with the 2.8 v6. In all honesty. a 2L Duratec has more power than the v6. And far better fuel economy.
Another option is what I've gone with. a 2L Zetec. Bolts up to the Cortina box. Run it on carbs. Hit up retro ford for the rest of the conversion pieces.
Here's a pic of my Zetec into mk3 conversion as it sits at the mo
Attachment 65553 Also...
PICS.... I LOVE PICS OF MK3 CORTINAS....
So like... post 'em up. :-)
