omex 700 on c20let
will be fitting omex 700 ecu to let soon so wondering do i need to use all the sensors that are on there originally ? or are there some that wont be used when using omex?
thanks
Re: omex 700 on c20let
you need to use crank sensor, water temp and air temp
i had an xe in and ive just taking it out it was on carbs with mbe so they should be ok. is there any site with diagram of let wiring ?
