Results 1 to 29 of 29
Thread: Breaking 500BHP MK1 Fiesta RWD Cosworth VIPEC EFR7670 ETC
    Sep 2005
    kent
    Ok due to the car not getting enough use and a house extension needed I’ve decided to break the car. For those of you that don’t know the car it’s a 1982 Mk1 Fiesta L with 4 Owners and was around 30,000 miles when I got it. It has the been converted to RWD to a high standard. It uses MK1/2 Escort front suspension, and a Capri Atlas Rear axle. The engine in the car is a 200 Block YB Cosworth engine and with the guidance and mapping from Mark at MA Developments it made 521BHP and 518lbft torque. The car has had no expense spared and owes me in excess of £30k most parts on the car were bought new.
    I’ll list what is for sale and what certain things include below. This is advertised on other forums so please if you want any parts please post a reply on the thread stating the parts of interest as well as any PM’s as this will be first come first serve according to the thread so people can see. Just bear in mind it is on other forums!
    In an ideal world I could do with selling the shell first before I take it apart so I’ve got room in the garage for all the parts that I take off, so there may be a short wait on the parts people want.
    Payment can be pay pal but as a GIFT only, if not your parts will not get sent until full payment is received. Cash on collection or bank transfer is also fine.
    Ok firstly a bit about the Shell;
    The shell as said is converted to rear wheel drive, using Capri/Escort running gear. Tunnel is big enough for a T5 Gear box. Rear axle is mounted via a 4 link kit and Watts linkage. Engine is sat nice and far back mounted on a WCXM. Front end uses compression struts. The rear is Tubbed allowing wide wheels (currently running 9J on the rear. Full weld in roll cage with door bars and seat belt bars. The car is fitted with Berg Cup Arches and front Splitter. The shell is painted inside and out and stone chipped, painted and lacquered underneath too.
    Included in the sale of the shell is as follows;
    Headlights, Indicators, De-Badged Grill, Fibreglass Bonnet/Boot, Doors, Windscreen, Perspex Windows, Carbon Door Cards, Mirrors, Wiper motor, Handles inside and out, Power steering column and adjuster, Steering wheel, Dash (not inc Dash 2 and gauges) Centre Console, Pedal box, Master cylinders, Braided brake lines, Hydraulic Hand brake, Passenger Foot Rest, Gear lever Surround, Carbon Roof Scoop, Rear Lights, Tow Eyes, Fuel Tank, Fuel Filler/Cap, Teflon fuel lines and fittings, Battery and Tray, Complete 3” Stainless Exhaust System, Plumbed in Fire extinguisher and nozzles, Oil cooler, Washer Bottle, Long Acre interior mirror, steering wheel hook, Concentric top Mounts with billet spacers. Steering Rack and WCXM.
    90% of the above which is included on the shell was Brand new and cost over £5000.
    Price for shell: £5000 Your more than welcome to come and view it, but please only serious viewers I don’t get enough time at home with the family as it is so please don’t just come round for a nose! (I don’t mean to sound rude but I’m sure the genuine people understand where I’m coming from)
    Pictures of at various stages of it being built are below, but just to reiterate it only comes with what’s listed above, if you’re not sure on anything please just ask.
    Engine Rebuilt less than 1200 miles ago
    Spec is;
    200 Block 6 Long Studded
    Cosworth Racing pistons 8:1 Comp
    New Genuine Cosworth Oil pump
    New Shells
    New ARP Flywheel Bolts
    New ARP Conrod Bolts
    New ARP Bottom end stud kit
    New thrusts and washers
    Full Balance of crank, rods, pistons, pulleys etc
    26.5mm Ported/polished head
    New Valve Guides
    New BD16 Inlet
    Std Exh Cam
    New Double Valve Springs
    New INA Followers
    New Valve stem Seals
    New vernier Pulleys
    Reconditioned Distributor
    New Cometic Gaskets through out
    4 Layer WRC Head Gasket
    New Belt and tensioner
    New Water Pump
    Magnetic Sump Plug
    AN fitting welded in sump
    New Alcon Paddle clutch
    Thermostatic oil cooler plate
    New Phaze, TDC Sensors
    The engine was built with quality parts, all parts were supplied by Matt lewis/Mark Shead
    With a Borg warner 7670 and Vipec management it made 521BHP and 517lbft torque.
    The engine has covered less than 1200 miles and 750 of those were running in. Its ran on Silkolene PRO S oil and that’s been changed twice since run in.
    Not included will be Turbo/manifold, inlet manifold complete, starter, alternator, rocker cover and coils and a couple of sensors which are unique to the vipec.
    Price for engine is £3650
    Other Parts for sale are as follows;
    T5 Gearbox with centre push hydraulic clutch cylinder, gear lever and Quaife nob  £500 Prov Sold
    Vipec V44 ECU, Loom, Rocker cover and coil packs (1 coil pack plastic plug is broken but it still works fine) Bought new from Mark shead. £1350
    Borg Warner EFR7670 Internally Gated and high boost actuator on a 2wd manifold with modded trouser section, Air filter and hose included. £1450
    Injector dynamics 1000cc High IMP injectors with spacers to fit YB inlet £250
    Alloy Remote Anti lag/ISCV Housing £35 PROV SOLD (JUDDY)
    Turbo oil feed pipe and filter £30 (Prov sold BAILEY)
    Inlet manifold, Complete with throttle body, Fuel rail with -6, adjustable fuel pressure reg and TPS. Custom made to fit in a fiesta but will fit std cars but would need intercooler pipes modding. £200 PROV SOLD (JUDDY)
    Holley Blue Lift Pump £85 PROV SOLD (Juddy)
    Bosch 044 Pump with cradle £130
    Fuel swirl pot £50
    Race Technology Dash, with Buttons and oil pressure sensor £450
    AEM Gauges; Boost, AFR, and EGT (sensors included but egt sensor broken)
    AFR- £85
    Boost - £65
    EGT - £50
    Airtec intercooler (has had both pipes modded so will put hoses in a different place to standard) £120
    Airtec 2wd Radiator £100
    4 Port Breather with AN fittings, Catch tank and Hoses £250
    Universal Header Tank £40
    GAZ Coil over front legs with springs MK1/MK2 Escort £220 Prov sold
    GAZ Rear Shocks/Springs £65 PROV SOLD
    Rear Axle; 2.8 Capri Atlas (full width), 4 Linked and welded Tubes, Rear Disk brackets with Tran-X LSD, Tran-X 18 Spline shafts, Watts Linkage, 3.75 Final Drive (excl chassis weld on brackets and Brakes) £1100 Prov sold
    Escort Mk1/2/Capri Group 4 Alloy front Hubs with Studs/bearings etc £60 prov sold
    Rally Design Bucket seats (pass one has a tear in the base) £60
    Pair of TRS 75mm 5 Point harnesses (non FIA approved) £150
    Front brakes to suit MK1/2/Capri Legs; Focus RS/Fiat Coupe Brembo 4 Pots Reconditioned, Yellow stuff Pads, Billet Alloy brackets, 305mm grooved and drilled disks. £220 prov sold
    Rear Brakes; 4wd Sierra cosworth calipers (reconditioned), Yellow stuff pads, Vented grooved and drilled disks. £75 Prov sold
    Wheels/Tyres; Compomotive ML, Rears are 9x15 and fronts 8x15. 225/45/15 Rear tyres and 205/50/15 front tyres. Toyo R1R’s £500
    There may be stuff I’ve forgotten, so if there is something you want its worth an ask.
    All prices are + any postage costs.
    Sep 2005
    kent
    Re: Breaking 500BHP MK1 Fiesta RWD Cosworth VIPEC EFR7670 ETC
    AEM AFR Gauge - Sold
    Jan 2010
    Watford
    30
    328
    Dibs on the header tank & washer bottle dependant on pic
    Cheers Scott
    May 2004
    London
    58
    658
    hi m8 can I see the pas seat with the tear email it to me please on g.lane7@ntlworld.com tks. where in kent are you.
    Jun 2007
    Whitley Bay
    3,437
    81
    Stunning build
    pm'd
    Screaming 1300 mexico rep
    Mar 2013
    Brighton, United Kingdom
    109
    10
    The build quality is 1st class. Such a shame it has to go. Was wondering what the offset was of the wheels? Interested in putting them on my mk2. Also where are you located? Tom
    Jul 2004
    leicestershire
    247
    Omg adding all the bits up if youve sort of worked it out if all sells how much will it return ?wish the car was for sale whole and was wondering how much you would of taken complete
    Mechanic samashbymk2's Avatar
    Jan 2009
    worthing
    587
    Some bloody cheap parts there...
    Chuck norris HAS counted to infinity.... Twice
    3,641
    I'll take the front legs and brakes if the sale falls through.
    Sep 2005
    kent
    Header tank and 044 pump Sold
    Sep 2005
    kent
    Quote Originally Posted by hairball View Post
    I would have wanted £15,000 for it complete, but where would the fun be in that, I've had all the fun building it and now even more taking apart again lol
    Sep 2005
    kent
    No problems mate if theres any change i'll let you know.
    Pit Crew Decade Plus User Huxley's Avatar
    Feb 2005
    Thatcham
    987
    79
    Have the rear brakes gone ?
    Jul 2004
    leicestershire
    247
    Quote Originally Posted by pacificzetecturbo View Post
    Omg im gutted its just what i wanted looked amazing build if you havent started to take to bits ill have it and ill let you take it to bits and put back together when your bored ill pm my number
    May 2004
    London
    58
    658
    I will have the seats please can you send me some pictures of the tear. where in Kent are you. email me on g.lane7@ntlworld.com please
    Sep 2005
    kent
    Quote Originally Posted by AVO32 View Post
    Hi sorry, I was waiting for a reply on MK1fiesta.com on the seats and the guy has said yes he wants them so sorry they are now sold.
    Sep 2005
    kent
    Vipec now Sold
    Sep 2005
    kent
    Race Tech Dash2 SOLD
  19. #19
    Spanner Monkey Alan G's Avatar
    Jul 2005
    Ireland
    363
    21
    Have the brakes sold??
  20. #20
    Sep 2005
    kent
    Quote Originally Posted by Alan G View Post
    Yes mate front and rear brakes sold.
  21. #21
    Nov 2014
    Aberdeen
    12
    Interested in the Vipec...
  22. #22
    Nov 2014
    Aberdeen
    12
    oops just seen its sold
  23. #23
    Formerly harrier mk2 Decade Plus User Fridgeman's Avatar
    Jun 2007
    Derby, United Kingdom
    2,529
    151
    what a shame , stunning thing hate to think how much thought and time went into this build.
    EVERY DAY,S A LEARNING DAY
  24. #24
    Mechanic Bower's Avatar
    Aug 2009
    England
    641
    I have pm you
    Ford V4 engines for sale. 07977 409910
  25. #25
    Aug 2013
    Marlborough
    Hi
    has your engune sold?
  26. #26
    Aug 2009
    England
    641
    As per pms interested in alternater and injectors
  27. #27
    Nov 2014
    Surrey
    10
    Old thread i know, but if you still have vipec, give me a shout.
  28. #28
    Aug 2009
    England
    641
  29. #29
    Sep 2005
    kent
    Hi Sorry for the delay, I don't come on here often. All bits are now sold but thanks for trying.
