Page 1 of 25 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 ... LastLast
Results 1 to 40 of 990
Thread: rx8 gearbox?
    Dec 2013
    Stockport
    91
    24
    rx8 gearbox?
    I read this post...
    http://www.turbosport.co.uk/showthread.php?t=455751
    Any one tried an rx8 6 speed? Seems the answer ! ?
    Jun 2007
    Whitley Bay
    3,437
    81
    rx8 gearbox?
    Think I will buy some plates for next project could ask for group buy?
    Screaming 1300 mexico rep
    Dec 2011
    Northamptonshire
    731
    Re: rx8 gearbox?
    Be good to see some more info on this with pictures.
    Dec 2011
    Northamptonshire
    731
    Re: rx8 gearbox?
    Just did a bit of looking boxes are cheap and these are the ratios:
    1st --- 3.760
    2nd --- 2.269
    3rd --- 1.645
    4th --- 1.187
    5th --- 1.000
    6th --- 0.843
    Reverse-- 3.564
    25,118
    Re: rx8 gearbox?
    for spirited use with a low diff ratio, forget 1st gear and pull off in 2nd and you have a half decent set of ratios
    Oct 2007
    Mold
    625
    28
    Re: rx8 gearbox?
    1st gear is a bit wank
    http://www.turbosport.co.uk/signaturepics/sigpic12022_2.gif
    Jul 2010
    South Wales
    4,689
    221
    Re: rx8 gearbox?
    Quote Originally Posted by BIG-G View Post
    Not really. I run a 3.89/3.77 diff and if i needed to pull off on a hill it would be great otherwise pointless. It is like a standard/tranx type 9 all in one a good box and much stronger than any type 9.
    25,118
    Re: rx8 gearbox?
    as i said ignore 1st, and pull off in second and you have a nice set of 5 close ratios, or if you want to tickle around pulling off with no revs/fuss or do a hill start as freddy said it will pull away dead easy
  9. The Following User Says Thank You to Graham For This Useful Post:
  10. #9
    Oct 2007
    Mold
    625
    28
    Re: rx8 gearbox?
    second gear would last about 2 minutes in a box not designed to handle the launches would it not
  11. The Following User Says Thank You to BIG-G For This Useful Post:
  12. #10
    3,242
    Re: rx8 gearbox?
    The gear tooth 'set' would be no different between 1st and 2nd - usually only top gear is different to reduce noise from a quite helical cut anyway.
    Unless you are planning double duty as a land rover, a 3.76 1st with a 3.89 axle is ridiculously low.
  13. #11
    9,208
    Re: rx8 gearbox?
    If you lived where I do then you might consider a close ratio box with an extra "crawler" 1st bloody perfect.
  14. #12
    Jul 2010
    South Wales
    4,689
    221
    Re: rx8 gearbox?
    3.76 is what i am running on my standard type 9 now (1st) with a 3.89 diff and it isn't ideal but it is no landrover gear, good for auto tests and hairpins on hillclimbs.
  15. #13
    Jun 2012
    ireland
    1,158
    Re: rx8 gearbox?
    sorry to resurrect this slighty old thread, but perhaps we could keep the discussion going, has anyone gone any further with it?
    im definitely looking at this (mating to an xflow) would i have to get a bespoke friction plate made or is there one that fits?
    i see from the other thread that the escort prop is the same splines apparently, what about the prop length does anyone know?
    cheers!
  16. #14
    Jun 2012
    ireland
    1,158
    Re: rx8 gearbox?
    double post
  17. #15
    Jul 2010
    South Wales
    4,689
    221
    Re: rx8 gearbox?
    cheers!
    the friction plate and clutch could be a 23 spline clutch used with the standard type 9 as they are the same input shaft. the output shaft you could use a ford type prop shaft but you would have to change the seal in the back of the box or i think (i say think because i haven't measured the length out it) use the rx8 fiberglass/carbon fiber prop with an adapter plate to bolt it to the diff flange. I will check the mazda prop length later. I still want to do this converstion in the future but i haven't had time YET!
  18. #16
    Jul 2010
    South Wales
    4,689
    221
    Re: rx8 gearbox?
    double post
    replied ;P
  19. #17
    Jun 2012
    ireland
    1,158
    Re: rx8 gearbox?
    super mate, thanks for the info! i didnt know the input shaft was the same, ive done very little research on the actual box. I'm just a little sceptical though, if this is such a good alternative, why are there not more done? are we missing something??
    any idea what thickness of adapter plate you will get away with leaving a safe enough amount of meat in the spigot bearing?
  20. #18
    Jul 2010
    South Wales
    4,689
    221
    Re: rx8 gearbox?
    haven't got a clue what the thickness is you will have to work that one out yourself and i think it is lack on knowledge about the box and the fact that you have to make an adapter plate to fit it. They have a hydraulic clutch as standard too. if i was you i would copy the ford side of the bell housing and use the ford starter and then the other side will be to just bolt the 6 speed up to the engine then. I'll get round to it one day.
  21. #19
    Dec 2011
    Northamptonshire
    731
    Re: rx8 gearbox?
    If using a Pinto the easiest way is to use a transit pinto to MT75 adaptor plate we done one for a customer who's putting this box in a MK2 Cortina.
    It bolts to the pinto block so you just need to sort out the box side of it to bolt the bell housing to the plate simple.
  22. #20
    Dec 2011
    Northamptonshire
    731
    Re: rx8 gearbox?
  23. #21
    Jun 2012
    ireland
    1,158
    Re: rx8 gearbox?
    well im using an xflow, which is the same bolt pattern as a pinto, so that could work. the plate is not really my concern, the biggest worry is the spacing, and will the spigot shaft go into the bearing far enough,and will the splines on the input shaft be sufficient to pick up the clutch by enough - no use in having 1/4 of the splines sticking in the end of the clutch plate
  24. #22
    Jul 2010
    South Wales
    4,689
    221
    Re: rx8 gearbox?
    None of that eill be a problem i don't think. The rx8 prop is 49.5" too so you have enough room to make an adapter plate to the diff flange :P
  25. #23
    Jun 2012
    ireland
    1,158
    Re: rx8 gearbox?
    Sounds good, im just starting to look for a box now, there is any amount on ebay for under 100quid, but it’s costing me a small fortune to get the bloody thing send to me
    Anyone over here wants more than what a full car is worth for one.
    Have you any idea what way the hydraulic clutch setup is on it? Ie could it easily be converted to mechanical, or is it one of those incorporated cylinder/fork jobs?
    Also does the gearstick come out in the same place as the type-9?
  26. #24
    Dec 2011
    Northamptonshire
    731
    Re: rx8 gearbox?
    Clutch cylinder is external its near the top of the gearbox over to the left from memory the gear lever is slightly further back.
  27. #25
    Jun 2012
    ireland
    1,158
    Re: rx8 gearbox?
    type9 lever is already pretty far back how much is slightly, mm's like or a few inches?
  28. #26
    Jul 2010
    South Wales
    4,689
    221
    Re: rx8 gearbox?
    Have a look at this
    http://www.turbosport.co.uk/showthre...=276802&page=8
  29. #27
    Jun 2012
    ireland
    1,158
    Re: rx8 gearbox?
    ahhh brilliant, very helpful! cheers mate
    I had a look at a 6speed toyota altezza RS200 box last night, they are made by the same crowd as well as the nissan S15 6 speed so i thiught they would be largely the same but obviously not so if a 23spline clutch fits your RX8 box !
    Altezza has 21 splines input shaft, 225 friction plate. just a random bit of info
  30. #28
    Bristol
    175
    17
    Re: rx8 gearbox?
    I am just starting to look in to fitting one of these boxes to my MKI Escort with a Zetec.
    What are the options for getting the Speedo to still work ?
    Is there a 'fix' to either
    1 Mod the box to have a mechanical speedo drive,
    2 Something to convert the electronic Speedo to drive the escort mechanical Speedo,
    Or
    3 is there a 'modern' Speedo that can be fitted in to the the escort dash (so to keep it looking as original as possible) that will work with the electronic speedo output ?
  31. #29
    9,208
    Re: rx8 gearbox?
    you could use a koso type speedo ? run off prop etc.
  32. #30
    Mechanic Matt75's Avatar
    Mar 2011
    Melbourne
    797
    Re: rx8 gearbox?
    What about a GPS speedo? Then no cables at all.
    Matt
  33. #31
    Post Re: rx8 gearbox?
    well boys sorry about the delay iam new on here so not allowing me to reply to privite messages , and finding out how to use this ..site
    the rx8 box is more or less a straight swap for the weak type 9 and a lot cheaper than buying a set of tranx gears and hydroilc system and quick shift as the rx8 has all this and same price of type 9 all in .
    my plate will fit any type engine with a little work of a few holes . but for most engines can come pre drilled to suit all ..
    right its same as type 9 1" 23 spline main shaft and out put prop is same and you can use rx8 lighter type and only have to drill your flange to suit .if you use the type9 prop you need to change the oil seal but i can supply plate bolts oil seal and instrutions with diagrams to show but its so easy , and your clutch is a 2.0 but its better to leave this and wet clutch other trying to do a cable but this could also be done at extra cost use your typ 9 starter too, ..the only thing that a minus of this is that its electronic speedo , so you have to sort your method on this depending on or choice of car kit, race car etc ..if any questions need to ask phil 07815007836 .. plate kit and gearboxes in stock
    some pics off first plates done should help out they can come in any colour plastic coated if rquireed ..
  34. #32
    Re: rx8 gearbox?
    sorry lads not letting upload pics will do new ones tomorrow forall to see , phil
  35. #33
    Re: rx8 gearbox?
    Click image for larger version Name:	photo - Copy (6).JPG Views:	2069 Size:	111.0 KB ID:	72671Click image for larger version Name:	photo - Copy (6).JPG Views:	2069 Size:	111.0 KB ID:	72671Click image for larger version Name:	photo - Copy (10).JPG Views:	2082 Size:	144.2 KB ID:	72672Click image for larger version Name:	photo - Copy (9).JPG Views:	2083 Size:	141.2 KB ID:	72673Click image for larger version Name:	photo - Copy (8).JPG Views:	2072 Size:	143.5 KB ID:	72674Click image for larger version Name:	photo - Copy (6).JPG Views:	2069 Size:	111.0 KB ID:	72671 hope these help
  36. #34
    Re: rx8 gearbox?
    Click image for larger version Name:	photo - Copy (13).JPG Views:	2073 Size:	135.4 KB ID:	72675
  37. #35
    Re: rx8 gearbox?
    Its as easy as putting type9 in .. Just updated thread.p9cyo
  38. #36
    Re: rx8 gearbox?
    The lexus is 200 is totally wrong and oppisite to the rx8 .. Looked at that before i work out that the rx8 is the best and easiest with the splines all the same ..as you use your clutch and prop ... Lexus is differnt aswel as nissian sx200 honda s2000 .. Mazda its same as ford .. So therye a bargain for what your getting
  39. #37
    Jun 2012
    ireland
    1,158
    Re: rx8 gearbox?
    thanks for the info Phil. how much are your plates? and a box for that matter? are you retaining the hydraulic clutch?
    How is the bellhousing size, does the standard non-auto tunnel need to be modified?
    cheers !
  40. #38
    Re: rx8 gearbox?
    Hi there .. There should be no problem with the large tunnels in escorts as the bell housing is smaller than the type9 ... But it's easy to use as the hydrolic system really , but could be changed to cable if really needed but I think the hydrolic will be more reliable ... Could do plate with all new bolts oil seal and p&p for £100 . Cheapest conversion plate ever really and gearbox £150 with stick clutch arm bearing and hydrolic system .. £20p&p all from low mileage cars .. Gearbox mount coming soon .. But can adapt. Type9 one .. Phil 07815007836 .
  41. #39
    Jun 2012
    ireland
    1,158
    Re: rx8 gearbox?
    cool, can you post some pics of the plate please?
    you can get GPS speedo kits with a small L.E.D display for about 60 dollars in the U.S, you wont have a speedo in a tunnel, but its a good solution
  42. #40
    Bristol
    175
    17
    Re: rx8 gearbox?
    It would be good if there was a way to retain a Speedo that will drive the mileometer , so as to monitor the miles covered due to restricted mileage on insurance.
Tags for this Thread
