you got to run up the strip against kevmk2![]()
Looking very nice , and be great to see it back out again![]()
Puddy mate, what injectors will you be running after the greens (for wearing in) ?
I have been looking at the Siemans?
Escort Mk1 Cosworth YBT build.
1000cc Si![]()
I was close![]()
I am at work![]()
Why arent you at work?![]()
A few pics from today,everything now connected ,just
gotta put fuel,oil and coolant in tomorrow
puddy![]()
Just in time for Santa Pod...
Bet your a happy bunny, just need to get some miles on it now Mark
Bet your itching to use it again and run it in and use it in anger![]()
Old skool forever
Just don`t tell the wife
how much it really costs!
cant wait to see itlast time i saw it was at pod when it went bang
love this car and brilliant to see its all back together![]()
Glad to see its all back together![]()
tep well donr m8,glad its nearly there m8.hopefully see you at pod
Well done mate, i think thats the quickest ive seen you put it back together![]()
Nice one Puddy, hope to see you at the weekend with it mate![]()
Brilliant work
Glad its coming back to life!!
Be very interested how you get on with that TB![]()
Looks great Puddy![]()
Screaming 1300 mexico rep
Superb, good to see it in one piece again![]()
Cheers lads, so p***ed off I never had it ready in time for
classic ford weekend, would have saved me rolling out my
excuses to everyone at least a hundred times !
' Next year ' .......................
puddy![]()
Nice to see you over the weekend mate, be good to see the car at Chelsea next month![]()
So close but yet so far, spent a fair bit of time up the
lockup yesterday, after gathering all of the fluids and tools
I'd need.
Started off filling the engine oil and coolant , simple
enough.
Then jacked her up and filled the gearbox with my leaky
syringe,very messy!
Whilst underneath I gapped the tdc sensor properly as
well.
Then decided which fuel pump to use so disconnected the earth on one of them and then cracked the unions under the bonnet only to have pressure on both ,seems they can earth through the lines/body as well, so had to disconnect the live as well !
Finally tried for some oil pressure before firing it up so took
out the dizzy and spun the pump up with a drill and bits.
success with the pressure but one and a half hours late and I still could not get the dizzy clamp back on so gave up, hoping to get back up there tomorrow as theres a bloody school inset day today !!!!!!!!!!!!!
puddy![]()
That would be nice and easy if it was dizzyless![]()
Crikey you have cracked on with it !
Good effort :top:
What size is the TB ? a mate of mine ran a 75mm iirc (may of been bigger) on his 505hp let and once rolling the throttle was like a switch, no inbetween which he said made it quite difficult to control the wheelspin with the GT30 so switched back to a Cav V6 tb which is similar in size to a YB one.
Best of luck with the mapping, I still believe it wasn't a SCS issue why it failed in the first place unless you know different but if it were mine I would triple check all the wiring and fuel system, no doubt you have checked the whole car through anyway but I'd hate to see it melt again.
Not long till your pushing Kev down that strip now![]()
My mate Jason is sticking with a 2.5" inlet to keep the throttle response. The bigger the throttle body the less responsive it gets apparently.
Can always change it to a 2wd one later on i guess.
Puddy needs to get in the 11's first before he gets into the 10's![]()
Well done mate![]()
Happy Dayz Mark,
Well happy for you Fella
Old skool forever
Well done glad to hear it running again![]()
Cheers lads, gotta adjust the clutch push rod a bit then
drive it round my dads for some more fettling and fit the
innovate lambda sensor kit, then hopefully get it mot'd
puddy![]()
Crack on mate![]()
Breaking MK1 & MK2 Escorts, all models
Vehicles Bought & Sold
All Parts Available
Ebay Shop http://stores.ebay.co.uk/escort-tec
website www.escort-tec.co.uk
Back with the Turbo boys...for now
biggy
