Hi Guys, need some help with a 5 speed Type 9 gearbox into a x-flow powered escort.
Please only reply if you know exactly what you are talking about, because I want to get this right, plus as well it would be a good post to go into the Tech Archives.
GEARBOX
Right, first of all, the gearbox itself. Am I right in thinking that I will need a 5 speed type 9 box from a 1600 Sierra, as a 2000 one wont fit due to different input shaft? Will the box from a 1600 Capri be the same as the 1600 Sierra item?
CLUTCH
I have read that I need to use the original X-flow pressure plate(are all the pressure plates the same on x-flow Escorts, ie 1100/1300/1600?), a Sierra release bearing(1600?) and a clutch plate from a 1300 Sierra? Which cable do I use-RS2000 or Sierra 1600/2000? I take it that the original release arm from the Sierra is retained.
PROPSHAFT
Again I have read somewhere that I will need one from an RS2000. As my shell does not have the centre bearing mount, the prop will need to be a single piece item from a MK1 RS2000?
SPEEDO CABLE AND DRIVE GEAR
Which cable do I use? I have heard that the drivegear from my original 4 speed box will need fitting to the 5 speed in order to keep the speedo the same.Is I a straght forward swap? I realise I will need to swap them before I put the gearbox into the car.
STARTER MOTOR
Which one?
ENGINE/GEARBOX SANDWICH PLATE
Will need modifying to follow the new gearbox in certain areas, or will a 1600 Sierra item fit?
OTHER PARTS
I believe that I will also need the RS2000 gearbox lowering blocks, and a quickshift kit so that the lever does not hit the Handbrake lever(and also gets rid of the spongy change).
BODYWORK
Right, I know that the gearlever has to be moved back, so thats no problem. There is a strengthener that runs under the gearbox tunnel-does this need to be chopped into to provide clearance?, and if so will it weaken the area and need rebracing in some way?
Finally, the gearbox mounts..
I want to do the conversion properly, so will be drilling out the spot welds on the mounts and moving them further back. If you look at my diagram, am I right in thinking that the amount the mounts have to be moved back will be A-B?? Oh, and how much will I need to add onto that measurement, due to the slight offset in the alloy gearbox blocks?
Hope you can help guys, and please remember to only reply if you know certain aspects for sure
I dont think ive missed any aspects! If so, please tell me
Thanks in advance
Dan
