Hi Folks,
First off, hello aain everyone... Im back!
Right, I am looking to fire up my YB engine tonight for the forst time in a few years and am wondering if there is anything I should do first, based on your experiences?
There was zero fuel in there, so small traces in the system are about 3 months old. But I will pour in some fresh. Oil is as new and filer was new when last started but has been sat so after initial fire up and run I will dump this later. I will just run up on normal water for time being to check everything over, then drain after a flush and use proper coolant later.
Over the past few years all I have ever done is push the starter to turn the engine over, but never fired it.
Anything else I should consider prior to pushing the button??
Dave
