Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 81 to 120 of 199
Thread: Zetec Install
  1. #81
    Pit Crew Decade Plus User TepiTheFinn's Avatar
    Jan 2003
    Finland
    1,226
    Re: Zetec Install - Throttle Bodies Fitted
    RChambers said:
    They look almost identical to my suzuki ones so they should bolt straight up to the manifold one you have spaced them out.
    yes they look quite same. are yours made by mikuni?
    can you measure hose size for throttlebody? are your hoses from st170 or from GSXR?
  2. #82
    Aldershot
    4,538
    Hoses are from the ST170. I can't measure them without removing them from the car but they were oval. When you slide them on the throttle bodies they become round. From looking at your throttle bodies I would say that they should fit. Bring the throttle bodies down to the Ford parts desk and try the rubbers for fit before you buy them if you are worried. You could always use some samco hose instead if its difficult to get hold of the Ford parts.
  3. #83
    Jul 2004
    Reading
    1,275
    Is the 46mm the inlet, or outlet as they are tappered. I cant believe a motorbike uses 46mm throttle bodies?
  4. #84
    Aldershot
    4,538
    Mine were 44mm tapered down to 38mm I believe. going by the same relationship yours should taper down to about 40mm?
  5. #85
    Jan 2003
    Finland
    1,226
    i haven't actually measured yet. i was just reading year 2003 KAWASAKI ZXR12 specifications, and it was told there.
    Nipondenso EFI with 46mm throttlebodies. Later bikes have sub-throttles to give lowspeed driveability.
  6. #86
    Aldershot
    4,538
    Yep the suzuki's have the sub throttles in later models. They are controlled by the ecu so you are lucky you got the best ones
  7. #87
    Jan 2003
    Finland
    1,226
    i measured 46mm velocity stack and butterfly, after that it's tapered down to 43mm.
    here's the bike specs.
    http://www.sportbikez.net/showcase/44
  8. #88
    9,212
    168
    HI,3 QUESTIONS.
    1, why ir the engine so high at front ? what sumps on it.
    2. do you have a fuel return line? you mention a regulator,but the regulator sits in return not feed line. .
    3, where to but st170 manifold, and from what year.
    cheers ,great thread
  9. #89
    Aldershot
    4,538
    Re: Zetec Install
    Thought I would answer the above questions and post a few update pics so people don't think I've done a Yodi
    1, Its a Retro Ford sump. Doesn't seem that high when you see it for real, maybe the pics are deceptive.
    2, Just made a return line adaptor. Fits in place of the pressure sensor. Using a cosworth fuel pressure regulator.
    3, Any ST170 will do, best bet is to try breakers.
    And here are the pics...
    So close to finishing its frustrating. Just missing Classic Ford show . Just have to fill with water/antifreeze and get a cossie fuel filter. At least I don't have to use my old PC with extension lead
  10. #90
    I love to crap Decade Plus User PercyBigun's Avatar
    Jul 2002
    Cambs UK
    Re: Zetec Install
    you done it yet then or what!
    My Sites www.MondeoSTTDCi.co.uk
    and www.mondeost.co.uk
  11. #91
    Jun 2004
    Haywards Heath, West Sussex
    1,373
    Re: Zetec Install
    He must be driving about in it. Or is too annoyed to face telling us...
  12. #92
    Aldershot
    4,538
    Re: Zetec Install
    Nah not driving it yet but pleased to say it started first time. Had a small fuel leak in the bracket I made so had to remove it to repair. Should be driving it soon!
  13. #93
    What curb ;-) Decade Plus User FF_Mark's Avatar
    Nov 2001
    Berkshire, UK
    26
    Re: Zetec Install
    any updates ?
  14. #94
    World Champion Decade Plus User markb's Avatar
    Feb 2003
    Plumstead
    6,821
    10
    Re: Zetec Install
    i remember when those librettos came out.. ultimate bling in the day, but mapping cars is probably the perfect use for them these days.... as long as you don't have to use the felt mouse!
  15. #95
    Aldershot
    4,538
    Re: Zetec Install
    Yeah, everything is done apart from the lambda mount. Waiting for zetec_escorts to send me one through the post and then I can weld it on and bolt the exhaust on properly. Then tax and insurance ready for Retro Cars show hopefully . I need to balance the throttle bodies so I'm gonna need to blag/borrow/buy some motorbike carb/bodies balancers. Because of this the idle is a little rough but everywhere else its running sweet as. Can't wait to take it for a spin. I'll post some pics later of the finished engine bay and some other bigs that I've done since the last update
    Cheers for all the advice guys, couldn't have done it without you all.
  16. #96
    Aldershot
    4,538
    Re: Zetec Install
    Fiiiinnnnnniiiiissssshhhhhheeeedddd
    Thanks to zetec_escorts (Glyn) for the lambda nut
    Had a few running problems but it turned out that the throttle bodies were WAY out of adjustment. It runs pretty good now, just need to get it rolling roaded. Just got to phone around for insurance now (yay!) and then I can drive it. Here are the pics of the finished engine bay...
  17. #97
    Jun 2004
    1,373
    Re: Zetec Install
    That's a bit nice.
    Like I said on MSN, bit of semi-gloss black on the cam cover and it'll look like it was supplied there from new!
  18. #98
    Jul 2002
    Cambs UK
    Re: Zetec Install
    very nice job indeed! when are you getting it on the rollers? and any chance of putting a sound clip to upload?
  19. #99
    Feb 2003
    Plumstead
    6,821
    10
    Re: Zetec Install
    nice.. looks the part. I bet you're well pleased!!
  20. #100
    Aldershot
    4,538
    Re: Zetec Install
    Here is a little video clip of the engine running. Sorry about the crap quality, I filmed it on my digital camera.
    Engine running
    Just driven it to the petrol station and back and it attracts quite a bit of attention . Its pretty rapid but its running too rich at the moment. Can't wait to get it mapped properly.
  21. #101
    Feb 2003
    Plumstead
    6,821
    10
    Re: Zetec Install
    sounds great!!!
  22. #102
    Jan 2005
    lincs
    268
    Re: Zetec Install
    Quote Originally Posted by markb_s1
    sounds great!!!
    looking good richard so you beat me to it eh? congrats mate
    just out of interest what did you do for an oil breather? also where did you get your exhaust sleeve from? iv tried claire at PLR but they dont do them
  23. #103
    Aldershot
    4,538
    Re: Zetec Install
    Erm oil breather... yes... hehe. At the moment its venting to atmosphere but I'm going to use a bike bottle as a catch tank. I got the sleeve from a local motor factors. Its a little bit big tbh but it seems to work ok.
  24. #104
    Mechanic oliver's Avatar
    Mar 2004
    Powys
    558
    Re: Zetec Install
    sounds good mate. ive now got mine running properly with the new fuel pumps. By the way i checked the temp on the exhaust manifold and it reached 250deg and one point and then it seemed to cool down a bit ill see tomorrow. pray:
  25. #105
    Aldershot
    4,538
    Zetec Install - Finished-ish
    Well this is the pretty much finished engine bay (well they are never finished are they) and I'm pleased to say that in the month or so its been done its been brilliant. I've had good fuel economy (ish) and smooth low rpm running and when you floor it the damn thing bloody shifts! I would recommend this conversion to anyone and would be glad to help anyone who wants to try and do it on the cheap. Total cost is around £2000 so pretty decent value as a 2k pinto would only just be this powerful (if that) and would be a bitch around town and at the petrol pump. Maybe this could be made a sticky as it is pretty much a complete overview of zetec installation and hopefully it can help other people
  26. #106
    Nov 2001
    Berkshire, UK
    26
    Re: Zetec Install - Finished-ish
    Will you be getting it rolling roaded ? be interesting to see what power its putting out.
  27. #107
    Aldershot
    4,538
    Yep soon as I have enough money I will be. I'm hoping for about 160bhp but I'll be happy as long as its over 150bhp. Either going to use Redline Racing in Iver or Southern Carbs.
  28. #108
    Jul 2004
    Reading
    1,275
    Rich,
    What have done with regards to air filters? I was thinking of buying a blank base plate and one of the foam filters that Burtons sell.
    Zetec Mk 1 Escort
    Mk 2 X Pack Capri 3.0S (not a copy, the real thing)
    Mk 1 XR4i
    Mk 3a Fiesta Si
    www.zetecescorts.bravehost.com
  29. #109
    Aldershot
    4,538
    So far I haven't done anything about air filters. I will probably get a set of four small universal k&n's as they just bolt onto the ends of the throttle bodies. I'm not touching foam filters after what happened last time!
  30. #110
    Jul 2003
    wicklow, ireland
    Re: Zetec Install
    Rich
    It looks great, id say ur chuffed now....how are u finding the fuel consumption?? Are u still using a 4 spd box??? Whats the bhp on that at the mo???? It looks a complicated job if you dont have a clue what ur doing......
    mk 2 mexico 1978
    mk 2 van 1978 (sold)
    mk 1 van 1971
  31. #111
    Aldershot
    4,538
    Re: Zetec Install
    Right its had a power run at Track and Race rolling road and it got 144.7bhp. Not bad considering its on the base map. They said with a remap it should be good for at least 160bhp as my attempt at a map was a bit feeble to say the least! Fuel economy when cruising is really good. On the Brunters oldschool thrash I averaged 32mpg over the whole day (including the thrash!). That was mostly motorway driving in fifth gear but with the included track action it probably averages out. Of course if you redline it all the time the fuel economy is pretty dire. I would say its not a hard conversion but its a bit more involved than an xflow or pinto engine fit. With the Retro Ford bits the engine just bolts straight in so its mainly wiring and plumbing. If you had a spare 2k cash you could go for the weber alpha throttle bodies kit as it has a wiring loom in the kit already.
    Getting it mapped hopefully the end of this month so will post the results here...
  32. #112
    Jul 2004
    Reading
    1,275
    Re: Zetec Install
    Glad it has all worked out for you. Sadly mine has gone into long term storage as I am going to live and work in Lisbon. Hopefully, I can get some work done when back in blighty as it is being stored at my dads Ford dealers so i have access to a body and work shop.
    Zetec Mk 1 Escort
    Mk 1 XR4i
    Mk 3a Fiesta Si
  33. #113
    Spanner Monkey Phil01825's Avatar
    Dec 2005
    East Sussex
    335
    Re: Zetec Install
    I know there has been many problems with the site. Is there any chance of getting the pictures back on all the earlier posts. I must say that this site is a goldmine of information. Keep it up.
  34. #114
    Aldershot
    4,538
    Re: Zetec Install
    The site is being transfered to a new server and all the pictures should be restored once that is finished. If you need any pics before them let me know as I have copies on my computer.
  35. #115
    Jul 2002
    Cambs UK
    Re: Zetec Install
    you should find the remap gives you better MPG too, it did on mine (mines a different setup but the principle is the same for proper fuel/air ratios, timing etc giving better efficiency)
  36. #116
    Dec 2005
    East Sussex
    335
    Re: Zetec Install
    (The site is being transfered to a new server and all the pictures should be restored once that is finished. If you need any pics before them let me know as I have copies on my computer.)
    Thanks,
    I'm a long way from starting any work due to home commitments, but when I get going I'll give you a call if the pics haven't come back.
  37. #117
    Oct 2005
    south east
    19
    Re: Zetec Install
    I could do with a look at the pictures on this thread - any idea when you might have the time to complete the tranfer?
    Cheers.
  38. #118
    Jan 2006
    Australia
    148
    Re: Zetec Install
    ......pics must b coming soon.......
  39. #119
    Jan 2006
    Lancashire
    282
    Re: Zetec Install
    Guys, first hats of to richard and his car. Many people talk a great job but few finish with the business. It's I have been planning a zetec escort since about 98, got a good rolling shell, built a garage, started a body restoration (though it's freakishly good for a MK2), went to live in Germany for 2 years, got married, had two wonderful children and finally I am 'on it'.
    Just built a rollover jig for the shell, sourced gsxr tbs, fuel pump, got the edis kit, picking up the spanner muncher zetec tonight and am well and trully commited.
    Planning to use the gsxr injectors at first and am making a manifold & modded fuel rail that will utilise the standard gsxr twin bolt rubber mounts that go from round to oval perfectly. (It helps that I am a CNC programmer with good access to a CNC milling machine...)
    Concept is for a standard looking Amber RS2 droop with a civilised kick up'ass from the zetec. The body resto is probably the major part of the job and certainly the most time consuming. If anyone is interested I will post a few pixels on here cos it seems the thread needs a new project now Richards is done.
  40. #120
    Jan 2006
    Australia
    148
    Re: Zetec Install
    where has richard gone???
