Page 2 of 2 FirstFirst 1 2
Results 41 to 75 of 75
Thread: FIT A ZETEC - Part 4 - Sump - NOT FINISHED
  1. #41
    Jun 2007
    UK
    176
    Re: HOW TO FIT A ZETEC - Part 4 - Sump - NOT FINISHED
    thanks. yes those look similar to the diesel engine mounts i have.
    I will put it together and see what i get thank you.
  2. #42
    Jun 2007
    UK
    176
    ok just checking.
    my pickup pipe is hitting 2 crank bearing studs has anyone else encountered this? i was just going to take the studs out cut abit off then put them back in? sound good?
    cheers.
  3. #43
    Brum Town
    1,822
    26
    you have to remove the metal plate underneath and cut the studs too
  4. #44
    Jun 2007
    UK
    176
    Cheers pal.
  5. #45
    Middleton,Wisconsin USA
    I'm in the begining stages of a Zetec into a Mk1 Cortina swap. As some of you know the US $ is very weak to the pound sterling so to save some $$ I fabbed my oil sump. I sourced a 1.8 cvh sump, cut it up. I had a 1500 GT sump, cut it up. Then set to welding it all back together. Follow along and feel free to ask any ??
  6. #46
    As you can see from the pics very little of the 1.8 cvh sump was used, only the 2 ends and the baffle. The flanges a peices of heavy guage sheetmetal.
    As of now it's only partially welded and I need to cut out part of the baffle from the 1500 sump.
    I'm not sure if the 1.9 cvh motors that came in our fwd Escorts have a sheetmetal sump or not, if they do then one wouldn't need to source a 1.8 Sierra sump from the UK saving more $$!!!!!
  7. #47
    Tyre Kicker iety2004's Avatar
    Jun 2007
    Bridgend
    I can confirm that the ST engine, with its two piece sump design has the sump bowl at the front of the engine.
    Fits my Talbot Sunbeam,
    What about baffling this sump? Whats the best was to do this? The car will be used for Tarmac rallies. I've heard some people putting Fuel tank baffling foam in sumps.
  8. #48
    Mechanic TINAMAN's Avatar
    Aug 2005
    Reading Berkshire
    584
    Sorry lads i know its a fairly old thread but ive got a 2.0l Black top going in a MK1 Cortina with escort rack and pinion so will still need rear drop sump, can i confirm the following
    I can use a 1.8CVH sierra sump by using the CVH oil pump and pick up pipe?
    Alternator is a CVH one ok to use with Retro Fords alt kit?
    Flywheel someones said use the std CVH one as its lighter what clutch to use with a 2.8 type 9 box?
    What starter to i need to look for
    Also using Bike carbs heard i can use a modified MK4 Escort ECU for the ignition side anyone done it if so what do i need
    sorry for all this any help would be great CheeRS Dave
  9. #49
    Feb 2007
    Norway
    942
    58
    Tinaman - Black top uses a two piece sump with one alu ladder and the the tin bottom sump. The 1.8CVH fits the Silvertop which has a one piece alu sump.
    Can't help with this one as I haven't gotten this far myself
    If you do you loose the possibilty to use the crank sensor for position sensing/timing that built into the Zetec flywheels and need to add a timing wheel to the front pulley.
    Can't help here as I'm using a Silvertop and I'm not sure if they're the same reg. starter. I am using the starter that cam with my Silvertop. It looks like it'll need spacing out to work properly
    Can't help with this one either as i am going either MegaJolt or MegaSquirt for ignition controll (using Wber DCOE 45s).
    HTH
    67 TVR VIXEN V8
  10. #50
    Mar 2003
    Now over the pond North side
    3,540
    Quote Originally Posted by Sonus View Post
    Not true as you can use the fly wheel from a late xr2i and that uses crank sensor
    Dazzle
  11. #51
    Apr 2008
    varna,bulgaria
    36
    Hi There.i'm Making An Escort Mk3 Conversion To Zetec(2.0 From Mondeo),i Know That The Sump And Pick Up Pipe Must Be From Escort1.8 Zetec.does It Straight Bolt On,or The Sump Must Be Reworked
  12. #52
    9,210
    see the post i did in the rs turbo section
  13. #53
    Apr 2008
    varna,bulgaria
    36
    thank's mate!!
  14. #54
    Jun 2008
    brisbane, qld AUSTRALIA
    Re: FIT A ZETEC - Part 4 - Sump - NOT FINISHED
    Hi guys, i have just bought a focus st170 wreck to convert into my mk1 escort. Could you pommies please give the run down on how to modify the sump, engine mounts and starter motor to suit a sierra 5 speed box. I am going to convert to bike throttle bodies also retain the variable cam timing of the st170, hoping to use the cars computer and wiring loom.
    Any help would be much appreciated, this is my 1st contact to your forum. Thanks Ross from Aussie.
  15. #55
    Aldershot
    4,538
    The sump you will struggle to convert as it is a two piece top half ally, bottom half steel. It would be easier to buy a sump from Retroford over in UK but if not then best sump to mod is a 1.8cvh sump off of a Sierra (if you had them over there). The engine mounts on the engine will be nowhere near for rwd so you will have to fab new ones from scratch unfortunately. Starter motor is from the above sierra or a 2 litre DOHC sierra ideally. You can fit an escort pinto starter if you space it away from the bellhousing slightly (about 10-15mm ish from memory). You will need to use a 1.8 zetec flywheel and you can either use the zetec clutch or redrill the flywheel for a pinto clutch. You need to fit a sierra spigot bearing to the crank to support the input shaft. Don't think you will be able to run bike bodies with the original ecu.
  16. The Following User Says Thank You to RChambers For This Useful Post:
  17. #56
    Jun 2008
    Thanks very much for your help mate. Hope i can contact for any future advice.
    Cheers, Ross.
  18. #57
    Mar 2008
    manchester
    724
    has anyone got any approc measurements on the modification of the 1.8 sump to get it in the escort? cheers !
  19. #58
    Feb 2007
    Norway
    942
    58
    I'll repeat my question from my resto thread here:
    Will my modified silvertop ally sump fit a blacktop engine if I remove both the tin part and the alu ladder from the blacktop?
    See my resto thread in my sig for pics of modified sump
    67 TVR VIXEN V8
  20. #59
    Feb 2005
    Norway
    438
    Take a look at ebay item 250269164307 and pictures
  21. #60
    Oct 2008
    oz
    hi there fellow ford fruits!
    just a couple of queries regarding the sump mods for mark 2 escort.
    1:why is the 1.8 cvh specified,what is different on the other cvh engines,as these are more readily available. are the front and rear seal sizes the same?
    2:regarding the two piece sump, does the alloy part hang too low itself for the escort near the rack and crossmember?
    the oz dollar rules out the retroford option at the moment,it would be more than the engine!
    cheers.
  22. #61
    Brum Town
    1,822
    26
    the 1.8 was fitted to the sierra so its a different shape and more ideally suited for a RWD car. obviously if you plan to cut the shit out of it then it doesn't matter as much, assuming the FWD derivitives are made from tin also?
  23. #62
    Oct 2008
    oz
    thanks for the reply. my thoughts exactly, if it's got to be butchered then the shape is not a big issue. i was just curious if they were the same length and width or if the bigger engine had bigger dimensions.
    cheers.
  24. #63
    Finland
    190
    1.8cvh sump is totally different than other cvh sumps.
    For example bolt pattern is different, there's a picture in a thread somewhere here.
  25. #64
    Oct 2008
    oz
    yeah right, i eventually found the thread, it's on page two {titled zetec rwd sump,posted by darth vader} for those interested and the bolt pattern is different. does anyone know about the 1.9 yankee cvh, if this has the correct bolt pattern, seal sizes, length and with?
    cheers.
  26. #65
    Bodger wellys's Avatar
    Aug 2007
    Boston, Massachusetts, United States
    I just bought a 1.9 CVH yank sump, it came today will check tomorrow if its any use
    If an Irishman Cant
    Eat It,
    Drink it
    or Ride it
    You can Be sure he'll BREAK IT!!!
  27. #66
    Aug 2007
    not looking good i dont think going by the pics on here, wall:
    If an Irishman Cant
    Eat It,
    Drink it
    or Ride it
  28. #67
    Jan 2012
    south yorkshire
    31
    Hey, could you possibly post some dimensions and tell me the oil capacity of the 1.8 cvh sump.
    cheers
  29. #68
    Dec 2009
    Rugby
    25
    11
    Hi Wellys
    Did you find out if the 1.9 sump will fit a Zetec or not, I am trying to help a guy in Winnemucca, NV fit a Zetec into a Lotus Elan +2, he has a blacktop unit and needs a sump off a front wheel drive Escort Zetec (front bowl) but I wondered if this 1.9 might be an option.
    Regards
    John
  30. #69
    Mechanic Doug@g19engineering's Avatar
    Mar 2006
    Nr Ipswich
    729
    The easy sump option for fitting zetec engines into Escorts or Anglias can be found here!
    http://www.g19engineering.com/index.php?cat=4
  31. #70
    Aug 2012
    chorley, lancs
    137
    I cut and shut what I think was an Escort Zetec sump that came with my silvertop. I had the ally plate and could do a lot of the work myself, but it still cost £60 to get the welding done. side cut out was for the starter. this was to fit in a Tiger Avon I was building at the time.
    http://s128.photobucket.com/user/ste...20920.jpg.html
    http://s128.photobucket.com/user/ste...20919.jpg.html
    http://s128.photobucket.com/user/ste...20918.jpg.html
  32. #71
    Aug 2012
    chorley, lancs
    137
    baffling I fitted to the windage tray
    http://i128.photobucket.com/albums/p...2/P1020219.jpg
  33. #72
    Tyre Kicker new1's Avatar
    Jun 2016
    Moscow
    31
    32
    Quote Originally Posted by seventynine View Post
    1.6 was fitted there also, but it's got a different outer radius of an oil pump and accordingly one on sump. Even the engine mounts are a little offset compared to 1.8 ones!
    It rusts!
  34. #73
    Feb 2015
    Wiltshire
    Just wanted to check, I have also just found this thread. I've sourced a 1.8 CVH sump to fit up to my ST170 engine in my mk2 escort. I've modified the area around the oil pump, slotted the mounting holes, sourced and modified the 1.8 CVH oil pick up pipe and thought I was ready to fit. However, reading some threads on here it would seem that the sump bowl also needs modifying to clear the World Cup x member, is that right? Cheers
  35. #74
    9,210
    Yes have a look in my 2nd project thread
  36. #75
    Oct 2019
    San Francisco, California
    10
    Good info on the sump.
