Results 41 to 80 of 120
Thread: Thread for throttlebodies, pics and dimensions
  1. #41
    9,208
    Re: Thread for throttlebodies, pics and dimensions
    gp4 mark
    depends what you want from it, v3 is more robust and has ign drivers onboard but v3 or v 2.2 can use an edis to do ign.
    firmware version is more important, megasquirt n spark extra is the most comprehensive. check out msefi.com
    tarmac t
    do you want to make your own ? if so i will give you dimensions.
    if you want a set made to fit the webber manifold all i need is the ctr spacing for the ctr holes, and thats it, then i can supply stubs with gsxr t/b(42mm 750) inc fuel rail.
    pm me for more info whichever if you want it. times short as i have 3 months max, could be a dole boy next week if union sorts a deal !!!!!!
  2. #42
    Dec 2004
    Ireland
    1,781
    31
    gp4 mark
    Thanks for getting back to me. Sorry to hear about the job.
    For the moment I am not going to build any throttleodies but will use the standard injection setup on my pinto and control it using the megasquirt and edis. I am hoping that this setup will be somewhat easier and allow me to learn about the megasquirt without having to worry about fabrication etc.
    From my reading up on megasquirt it appears that there are two versions of the processor on the v3 boards MegaSquirt-I: (68HC908) and MegaSquirt-II: (MC9S12C64). Megasquirt II being faster and more expensive. Which did you use ?
    Also I was looking at Msextra firmware which seems to be very good but the megasquirt n spark probably does the same thing. It is a minefield of choices.
    Regards
    Tom
  3. #43
    Feb 2005
    Greenock, Scotland
    MS1/extra is basically squirtnSpark, but with extra features. THey both use teh MS1 CPU, so you would be as well running the extra code. It will allow you to add extra features in the future once you fell happy to do so without anyfirmware updates. I would probably recommend eth hi res code, as its built on top again, but with a higher resolution injector pulsewidth. pulsewidth with MS1 are only a minimum of 1.0ms, with the exception of the high res code, which has a minimum pulsewidth of 0.35ms. Thats almost 3 times more acuracy.
    You can run MEgasquirt as basic as you want with squirtnSpark, extra or high res, you can even just use it for fueling and nothing else if that what you wanted. All you do is wsitch off anything taht you dont need. Its easy enough once you have plyed with the setting for a few hours, which is where buying a megaStim comes in handy as you can play before fitting it to the car
  4. #44
    Finland
    190
    Quote Originally Posted by Sparker View Post
    MS1 has 0.1ms pulsewidth, "hires" ~0.035ms and MS2 0.001ms.
    MS1 v3 with extracode (hires or not) is a good choice.
    MS1 can be updated to MS2.
  5. #45
    Spanner Monkey tarmac terriost's Avatar
    Aug 2005
    truro cornwall
    450
    gp4 mark
    tarmac t
    cheers alladdin
    soz to hear bout your job!!!
    mrk 2 mondeo ghia saloon
    17" tsw reflexs bomz kit
    fast road cams/obx pulleys
    drop 30mm eibach springs mongoose catback exhaust
    4.1 ceramic coat exhaust manifold
    custom down pipe/highflow cat
    list to do :-
    st bodykit 300mm disc conversion+rear disc
    underdrive pulley custom management 45mm throttle bodies gasflown big valve head
    comp ratio increased 11:1
    looking for a mint 4x4 rouse motorsport 304r sapphire running std (260bhp) or stage 3 set up
  6. #46
    Feb 2005
    Greenock, Scotland
    I hadnt realised my mistake. yeh its 0.1ms for ms1
  7. #47
    9,208
    tarmac i have mailed.u.
    i think this forum deserves a megasquirt section ? or ecu section?
  8. #48
    Dec 2004
    Ireland
    1,781
    31
    My thoughts exactly
  9. #49
    Aug 2005
    truro cornwall
    450
    i agree
    like what to buy
    how to set up
    ratio's of fuel set up etc
    what comes in the kit
    what bits do what
    different map set ups to compare each others !!!
    list to do :-
  10. #50
    Sep 2007
    MI, USA
    I was just sent over here from the USA site CEG. Im doing work to my Contour Zetec build 5/99. I have VCT but it will be removd this winter. Finally to my question.
    As i am not sure about your engines i must ask. What are you doing about the MAF sensor ? I have my engine with it off once, when cleaning and drove on it in my sub and everything ran horribly.
  11. #51
    9,208
    when using 4 individual thottle bodys you dont have a maf. an aftermarket ecu is used which uses either tps or map . hope thats the correct answer.
  12. #52
    Sep 2007
    MI, USA
    ahhhh . thanks
    It makes sense so it must be correct...
  13. #53
    Jun 2007
    Maidenhead
    18
    does anyone know if there is a kit for sale for spacing GSXR throttle bodies? I know Bogg brothers do one but I e-mailed them for a price and it was £120 whcih seemed a bit steep to me.
  14. #54
    Feb 2005
    Norway
    438
    Made a bookmark some time ago on this supplier, not bought anything and dont know anything about the company other than what is written on his web pages.
    Prices looks OK if he is still trading....
    http://throttle-bodies.com/
  15. #55
    Jun 2007
    Maidenhead
    18
    not a hope would I deal with them again. I bought an inlet manifold from them on ebay and sent them the money via bank transfer as they wanted and I got nothing. they all ready have £129 from me and they'll get no more.
  16. #56
    Feb 2005
    Norway
    438
    Thanks for the warning, money saved.
  17. #57
    Jun 2007
    Maidenhead
    18
    I won't complain too much, I've bought hundreds of things off ebay and other websites and thats the first time I've ever had any trouble.
    I'm gonna keep looking for another few weeks for the spacer and fuel rail kit and if that fails I'll just bite the bullet and bite from Bogg Brothers.
  18. #58
    9,208
    i can give you the sizes to make your own, i sold a few on e bay, heres a 750 k2 to zetec spacing kit.
  19. #59
    Jun 2007
    Maidenhead
    18
    that'd be brilliant if you could.
  20. #60
    Jun 2007
    Maidenhead
    18
    Quote Originally Posted by zetecdamien View Post
    just an update on that website.
    I've been contacted by one of the owners of throttle-bodies.com and problem has been solved. Already have a manifold now but I'm getting the spacer kit and fuel rail extensions for a set of GSXR600 throttle bodies instead.
    when they arrive I'll post up some pics and let everyone know how they work out.
  21. #61
    9,208
    that pm was a waste of time then
    be interesting to see a fuel rail extension kit as its an alloy one piece on the 600.
  22. #62
    Aug 2007
    Hampshire
    Taken from their website...
    Also available as an option is a set of new fuel rail tubes for the 750/1000/1300 fuel rails to match the new bore spacings of the chosen spacer kit.
  23. #63
    9,208
    on the 600.
    Quote Originally Posted by V8 Dave View Post
    750 / 1000 / 1300
    popcorn:
  24. #64
    Aug 2007
    Hampshire
    The website makes it clear that it's not for the 600, and the fuel rail extensions are an optional extra popcorn:
  25. #65
    9,208
    not sure if we are on same wavelenghth ?
    his is 600 bodies for which they are sending extension set... interesting to see i say.
    as you pointed out, they only sell 750 + ones ..... thats my point ??????????????
  26. #66
    Aug 2007
    Hampshire
    Aha, didn't realise. Furry muff.
  27. #67
    Dec 2006
    Here
    396
    Quick question-gsxr1300 t/b's ,tps has 3 wires what one does what ?
  28. #68
    Dec 2004
    Ireland
    1,781
    31
    Should be easy enough to figure out if you have a multimeter.
    Set the meter to measure ohms and measure between any two wires. Move the throttle and see if the measurement changes. Keep checking the wires until you find one that gives a stable measurement while you move the throttle. These are power and Ground. The third wire is the output and indicates the position of the throttle. If you measure between ground and the output it should read a low resistance when the throttle is closed and increase as the throttle is opened.
    Regards
    Tom
  29. #69
    Jan 2006
    Lancashire
    282
    Just picking up on the spacer issues, I have made fuel rail extensions, alloy spacers for the bodies and welded extensions for the butterfly steel plates plus longer studs from B&Q! I can do all this work and reassemble for £60 if you send me your bodies if it's any help? hope the image is clear. good luck with the project...
    p.s. I would need to know your manifold spacings, mine are equal at its a home made manifold, if yours is a bought one chances are it's a 2 + 2
  30. #70
    Brum Town
    1,822
    26
    my TB's cannot be individually spaced, something i really should have looked into before buying them i spose.
    oh well, it wasnt the end of the world. i made a manifold using 8x mandrel bent 45 deg exhaust bends, plus an inlet manifold flange from work at a grand cost of 60 quid.....
    just have to mount the injectors into it now and use the Blacktop fuel rail with some cossie yellows.......
    this way i could angle them appropriatley in order to miss the brake servo tower. im going to use the motorbike injector holes with some aluminium tube mounted into them in order to have a take off for the brake servo too.
  31. #71
    Brum Town
    1,822
    26
    as a side project at uni, im going to (attempt!) to make some direct to head slide throttle bodies.....
    ball park design, still needs to be matched to the zetec port shape, plus mounts for the injector, bearing housings, TPS mount and throttle lever etc
  32. #72
    Jun 2007
    Australia
    176
    Quote Originally Posted by seventynine View Post
    I made mine seriously more complicated than that to clear the brake booster.. Mine is like the old group 4 IDF(?) weber manifold for a pinto with the 90 degree bend. I didn't think I'd get away with a manifold like that, but it looks like I would have.. Ah well.
    andrew
  33. #73
    Brum Town
    1,822
    26
    so youve effectively got downdraught throttle bodies?
    pics?
  34. #74
    Jun 2007
    Australia
    176
    Nah no pics, the manifold is only 3/4 made.. I've made the runners and the flange, but not joined the two yet. I could get a pic of me holding it in place but essentially yeah it is like a twin downdraft manifold.. Like twin IDFs. I've been thinking of a re-design today.. I might cut the 90 degree bend to make a shallower bend. I didn't think it would fit until I saw your pics, I think now i'll wait until the engine is in place to finalise the manifold. My measurements put the #1 runner right on that brake booster bulge..
    andrew
  35. #75
    Brum Town
    1,822
    26
    yeah i just put the engine in and roughly measured that i needed a 45 degree angle and mitred them accordingly.
    also, looking at the inlet ports, they are roughly angled at about 45 degrees into the combustion chamber, so effectively the fuel/air mix doesnt have to turn any bends, we will see how effectivelly i can port the manifold to give a nice flow into the combustion chamber
  36. #76
    Jan 2006
    Lancashire
    282
    Nice simple solution to the manifold mate!
  37. #77
    Brum Town
    1,822
    26
    ive drew up a flange for the zetec.......see here:
    http://turbosport.co.uk/showthread.php?t=125526
  38. The Following User Says Thank You to seventynine For This Useful Post:
  39. #78
    Aug 2004
    Leicestershire
    1,637
    58
    Has anyone mounted throttle bodies as downdraughts? I'm after a downdraught manifold for my jenvey TB's
  40. #79
    Aldershot
    4,538
    I can't say I've ever seen it. Wouldn't the ideal be to mount them at the same angle as the inlet port if you have space?
  41. #80
    9,208
    didnt realise you posted here, superb site
    t/b dont know where they are as far as im aware ? if its for a zetec then my route would be a cvh manifold and adapter plate as one of the xr2 / 3 came with twin dd as i recall? not sure they were webber flanges but close enough to work around im sure
