Hi, im about halfway through my mk2 escort cossie conversion and im thinking about buying a bigger turbo for the engine.
It's basically a standard 2wd cossie with a 4x4 manifold a stage 3 chip, green injectors and a 3 bar map snesor.
I'm from Australia and ive been looking at a few turbos that are for sale on ebay aus. I dont really know anything about a/r ratios and what not..
I want a turbo that isn't going to be very laggy. What do you guys think about this the spec of this turbo.. or isnt the description detailed enough ?
T3/T4 - T04E Turbo Charge !
Great Turbo - 450~550 HP
*Good balanced*
Turbo T3/4 .5 front .63 rear -
Great spool up on 2l motors eg RB20 SR 20 -
Great upgrade for RB25 .
Can be supplied with internal wastegate
or what about this one..
TamKO T3/T4 600HP TURBO
The T3 / T4 TamKO Turbo are custom matched for specific applications. Airflow ratings to 600 HP. Consists of a T3 turbine section, (standard, Stage II or Stage III trim) and a T4 compressor section (T04 trim).
The turbo offers the low inertia and fast boost response of the light weigt T3 Turbine wheel and the high airflow characteristics of the T4 compressor. Air flow rating of up to 600HP
3" Inlet Diameter : 2" outlet : Wet Floating Bearings : 1/8 NPT oil inlet
T3 Flange : Fits T3 and T3/T4 Manifolds
Specs: . 50 a/r compressor .63 a/r turbine .57 trim
Turbine wheel:
Exducer: 2.48"
Mayor : 2.89"
Compressor wheel :
Exducer: 2.07"
Mayor : 2.36"
I thought 600hp would be a bit optimistic from a turbo that size ??
Any help will be greatly appreciated.
Cheers,
Damion
