Originally posted by HonkyWhiteTrash
2.8I ones are longer to allow for spaced calipers (and the bolts are used with a spacer to bring the caliper to the right position) - are you sure the shorter ones will be ok - i may have a spare of either.
Rs2000 and 2.8 are the same i need the spacer aswell if you have any cheers
