Hey all
It's been a long time since i've been on here due to being so busy working on my house and general work.
But I thought i'd put a post up because I know how much you all love pictures and it's turning into a massive project which originally I didn't plan, oh well it's always the case. I should have bought a car that worked properly in the first place (Dads voice ringing around in the back of my mind).
I bought 'Florence' back end of last year after some health issues were resolved I wanted a fun toy car to cheer me up. I went looking at XK8s (too old manish), Lotus' (too small inside), BMW 640i (nice car) and a few TVRs. I fell in love with the Chimaera, the looks, V8 rumble, decent amount of space in boot and behind the seats and just how comfortable they were.
I was looking originally at the 400 (4 litre) but felt it wasn't fast enough as afterall it was a second car purely for fun, the 450 and 500 models were getting a bit pricey. Then I found an early 400 model that had a 4.6 engine fitted. I drove up to Edinborough and drove her home, 4 hour drive only one stop, no discomfort at all even with the suspension being set to rock hard.
I've had some pretty powerful cars in the past, but nothing like this, especially having the power available in any gear at any revs. The noise is incredible and pops/bangs on overrun are amazing. It might not be everyones cup of tea, and everyone I know has said "why would you buy a TVR". Everyone assumes it will just break down everyday, and they are probably right. But it makes me smile like a little girl everytime I start her up.
After a few months driving I thought I would start to fix some of the (many) things that needed doing.
Spec of the car as I bought it is 4.6 crossbolted Range Rover v8 with wildcat heads, not sure on cams. ecu from a 5ltr, body off chassis restoration couple years ago, gaz shocks, big brake upgrade on front,. TVR OZ split rims toyo t1r tyres.
Problems so far
Dials - basically all of them Speedo is quite a bit out, rev counter sticky, fuel gauges doesn't work at all, temp/pressure gauges aren't reliable. Lights dont work.
veneer on dash cracked/knackered
Stereo wired so badly, no radio reception, crackles when going over a bump and has a funny interference noise that mimics the revs.
wheels need a refurb
there is an unbelievable amount of heat in the cabin, I can't drive with the roof on without windows down it's too hot, literally makes you sweat like you've been for a run. roof needs replacing as the rear window is cracked and switching is coming away.
Runs way too rich (5.0 chip so it's over fuelling loads i assume) which i'm guessing also adds to the heat?
interior carpet is faded so badly.
center exhaust section rattling and manifold blowing
suspension too low and hard
battery goes flat if left more than one day.
seats are old, saggy, scratched, seat belts don’t work.
So the project began.
I’ve got a garage full of parts I’ve been buying for the project so it was time to get started.
first issue was the blowing exhaust manifold, fixed by steel gaskets and ARP bolts. This was so difficult it is ridiculously hard to get the manifold bolts out. Once the manifolds were off I got the bottom bolt holes machined into slots so I could put the bolts in the head then just slot the manifold on top, best modification i've ever done and saved so much time. The exhaust manifolds are wrapped which I think I will remove as I think this is adding to the heat in the cabin? the wrap stops at the down pipe so the section going through the tunnel i'm guessing will be made hotter.
I've stripped out the interior as I have new carpets, and Dynamatting everywhere. I am changing the colour of the leather from black to cream with a Furniture Clinic kit (has anyone else used this? it's great stuff). The wiring is such a joke, in fact the build quality of most of the car is a joke for how much these cost new, tiger seal and random bits of angle bracket everywhere. The battery wasn't fixed it, just floating about it the footwell with the ecu loose and the wiring loom shoved up behind the carpet.
I found an unplugged wire which was the ECU tune resistor, no wonder it was running rich, this being disconnected means it’s always been running in limp home mode
I'm moving the fuse board from footwell behind passenger seat and I’ve got an odyssey battery which I’m moving into the boot. Hopefully I can work out whats draining the batt and causing the alarm to constantly go off (maybe fuel pump relay)
MX5 seats are going in, with speakers in headrests so no need for the 6x9s. seats will be changed to cream this weekend.
Centre section of the exhaust is normally just a silencer box filled with wadding. This is being replaced by two cherry bomb type silencers, makes it not too loud but more aggressive than standard.
I’ve ordered a new dash panel with extra gauge and it’s in swirled stainless steel, all new gauges and senders from ETB, they are chrome bezel with black face, LED alloy switches (savage ones). Also alloy stalks to get rid of the horrible Vauxhall plastic ones. Rewiring the stereo and putting a new amp behind driver seat to run the headrest speakers
It’s an early Chimaera so the door locks are on the rear quarter panel and the mechanism doesn’t work. So I’m fitting switches to the underside of the wing mirrors like on the later models.
When the near rear roof section is made I’m getting a much smaller rear window which lets it fold properly and lets it go further down. A good thing as you can’t see anything out the rear window when it’s down.
Anyway, I’ve bored myself writing this so no doubt have everyone else, time for some pics.
Brett
