    • 25242
    lets put it this way if they were in the middle of the piston they wouldnt be cut outs they would be holes!
      • 25242
      if you take a look at this pic with the cam on overlap, not only can you see how much the inlet valve is open but you can see quite a bit of the exhaust valve and the white area towards the top right of the red box is the workshop wall!
        • 25242
        its in! i just have to be carefull and not trip up and fall down an inlet port!
        • tom burgess
          • 3590
          Havent cuaght up in a while on this.you have been steaming along Grahamshould have a lot more room in youre engine bay this yearGreat stuff so far
          sigpictommy 2000
            Great work there Graham, must be a relief to get the engine in the car at last.
            Whats left to do, i take it a lot of the remaining plumbing carries over from the last setup?
              • 25242
              some of the plumbing carries over,
              a few of the jobs i can think of at this late hour,
              still to do is the plumbing,
              modify the ecu loom to fire 8 injector,
              fit the induction system
              fit the exhaust manifold
              make an exhaust system,
              source/make some 50mm ram pipes
                • 25242
                it has to be said i need to thank stephen (my son) for his help getting the engine in, it was such a big job shifting loads of stuff including non running cars i doubt i would of got it done
                thanks son
                now about doing some housework
                • mk2stu
                  • 318
                  good work their m8
                  the tensioner coming loos when lifting of is abit scary
                  do ya like dags
                    • 25242
                    a little more progress, i fitted the oil tank and finished the dry sump pumping which included the remote filter as its only just sitting in plce in the previous pic, primed the pump and cranked i over, the oil was obviously cold but became up to 35psi on the starter,
                    the i walked around the front of the car and saw a pool of oil on the o/s no where near any of the oil fittings, after a WTF, i realised the oil came out the exhaust manifold stud holes in the head panic over, the exhaust stud holes break into the oil return in the head so if a stud is missing then out poors out, and i havnt yet fitted any studs
                    • 4drmatt
                      • Jun 2007
                      • 2079
                      Good stuff. I re-read this thread the other day at work (don't tell the boss) and it's amazing the amount of work you have put in
                      It also you mention a 2002? I don't supposed you have any more info or pictures do you?
                      Anyway, keep up the good work and best of luck for the new season
                        • 25242
                        using a bit of alloy angle and a yb fuel rail, i 've knocked up a second fuel rail assemble so i can run 8 injectors
                        heres my much modified pinto ashley 3 piece, which is now a bmw 4 piece
                        funds are very low now so the exhaust system was a case of build it out of what i had, in this case an escort 2 1/4 system, it might be a bit small for my engine, but it was free, only time will tell its its actually too small, with a 2.0 version of this engine i did try both 2.25 and 2.5 inch systems, the 2.5actually gave less power in most tests, although it did give a fraction more if you got the intake length just right
                        finally after a trip to emerald, where dave had a fiddle with my ecu then carl had a fiddle with my lap top i was able to talk to my ecu and start my engine
                        it wasnt easy to start, with a totally different engine configuration and radically different injector sizes, it really didnt want to play ball until i had a eureka moment, and stopped playing with the low comp turbo bmw map and installed a 200bhp xe map
                        • Dave
                          • 19588
                          Those eureka moments are good aren't they.
                          Well done
                            Not sure about the rear exhaust mountingI see you're entered on the 10th,will you be ready?
                            • Joe-Tait
                              • Jun 2007
                              • 3437
                              Great News and Good Luck
                              Screaming 1300 mexico rep
                                Good stuff Graham, if you need any more 2 1/4 exhaust stuff i still have some bits at home. Are you only running one box in the system, as this is what i am planning to do with the sierra
