Just a dump of things I think of:
Rear Brake Shoes
Rear brake Fitting Kit
Handbrake Cable
RS2000 Radiator
Oil
ATF
Anti Freeze
EP90
outer Window rubbers
Set Water Pipes
Rear Brake Shoes
Handbrake Cable
RS2000 Radiator
Oil
ATF
Anti Freeze
EP90
Set Water Pipes
might have some fluids will go check this afternoon
no luck with the fluids but if we are still struggling then I will buy them from the spare shop round the corner from Gary's
I can erm........ "aquire" some EP90.
How much do you need?
Oh, and I just worked out what ATF is.
I think I have a gallon of that too. I'll check.
1 gallon of ATF here.
Dextron II is what it says on it.
i will bring down the anti- freeze
ep-80/90 and some synthetic(sp) engine oil if you want me to.
also have all the paint etc...
hope it all helps
Oh yes it all helpsOriginally Posted by PIG
Dave the Dextron is ideal m8
I have a recently recored RS2000 rad that I can chuck in. Only problem is the top hose pipe is slightly bent. It should pull back into shape and the rest of the rad is basically new. I'll take pics if it helps. Sorry its not much but thats all I could find in the shed thats on the list.
Oh I have some Cortina GLS fishnet recaros in the shed (look the same as Escort ones but slightly wider and grey. They would need recovering to look nice though. If they are any good then you are free to use them
Thats Great RichOriginally Posted by RChambers
Is a mk2 one the same as a mk1? Mine is a mk2 rad.
got the new M16 spaced calipers/pads today as well as new master cylinder , have ordered new vented discs and they should be in monday
Any other bits needed Clint? No guarentee I'll have any of it, but if I do, your more than welcome to it. Maybe an updated list of needed parts?
Good call Matt
