Page 3 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 81 to 120 of 233
Thread: Thread thread
  1. #81
    Part of the furniture Decade Plus User Ratters's Avatar
    Mar 2004
    Bristol
    8,648
    75
    Re: Thread thread
    cheers dave i just tried copy/pasting a table thing i found that might be handy but it didn't work
  2. #82
    Dave's Avatar
    Oct 2003
    Cheshire
    19,588
    141
    Re: Thread thread
  3. #83
    Mechanic zetecfourdoor's Avatar
    Feb 2008
    bonnie scotland
    846
    20
    Re: Thread thread
    Quote Originally Posted by zetecfourdoor View Post
    does anybody know the thread size of the stud that the rear shock mounts to on the spring plate?
    cheers
    m12
    edit: On a Mk2
    Four doors do it sideways too
  4. #84
    Racer Decade Plus User Stringpants's Avatar
    Jan 2009
    Worcestershire
    63
    3,345
    67
    Re: Thread thread
    Crossflow/Mex oil pressure pipe...both ends look the same but what size?
    ta,
    Russ.
  5. #85
    Dave's Avatar
    Oct 2003
    Cheshire
    19,588
    141
    Re: Thread thread
    Some very useful info and links re threads.
    http://www.boltdepot.com/fastener-in...g/Default.aspx
  6. #86
    Dave's Avatar
    Oct 2003
    Cheshire
    19,588
    141
    Re: Thread thread
    Mk1 Escort, Gearbox crossmember to body, 5/16 UNC
  7. #87
    Jun 2004
    Haywards Heath, West Sussex
    1,373
    Re: Thread thread
    BTW I have a machinery's handbook from the dark ages here if anyone wants any thread form or similar info.
    I can't find my zeus book
  8. #88
    Mar 2003
    TRURO
    5,250
    246
    Re: Thread thread
    Crossflow rocker cover bolts anyone please? I have a set of the Burton style long bolts-need some short ones for the new alloy cover.
  9. #89
    May 2007
    nottinghamshire
    176
    Re: Thread thread
    Anyone know the thread for capri steering rack to track rod ends,I think its 1/2 UNF.
  10. #90
    Dave's Avatar
    Oct 2003
    Cheshire
    19,588
    141
    Re: Thread thread
    Quote Originally Posted by sven View Post
    Don't know, but they are the same as Mk1 Escorts.
    1/2" unf sounds about right.
  11. #91
    May 2007
    nottinghamshire
    176
    Re: Thread thread
    Thanks so are mark 2 escorts m14?
    sven
  12. #92
    Dave's Avatar
    Oct 2003
    Cheshire
    19,588
    141
    Re: Thread thread
    They are metric, but they might be M12 rather than M14. I can't say for sure as I have never really messed with modern stuff.
  13. #93
    Oct 2003
    wales
    331
    Re: Thread thread
    ENGINE
    Crossflow
    Engine bolts (in block): 5/16 UNC.
    1300-1600 flywheel bolts: 3/8 UNF.
    Oil pressure take-off: 1/8 NPT for 681 blocks & 1/4 NPT for 691 and 711m.
    Thermostat Housing: 5/16 UNC 25mm long
    Inlet Manifold: 5/16 UNC 25mm long
    Exhaust Manifold: 5/16 UNC 25mm long
    Oil Pump: 5/16 UNC 25mm long
    Rear Crank Cover: 5/16 UNC 25mm long.
    Water pump x2: 1/4 UNC
    Water Pump x1 (alternator bracket one): 5/16 UNC 25mm long
    Sump bolts:
    Oil Breather Box:
    Distributor to block: all 1/2" long
    Front Timing Cover: all are 20mm apart from 1 which is 43mm long
    Pinto
    Pinto spark plug thread: M18x1.5.
    Pinto oil pressure switch: 1/4 NPT (pipe thread).
    Pinto alloy sump to engine bolts: M6x18
    Pinto alloy sump plug: M12x20.
    Pinto block drain: 3/8 NPT
    Gearbox & Bell housing
    RS alloy bellhousing to engine bolts: M10x1.5 (30mm long).
    Bellhousing to type 9 gearbox: M12 x 1.5 FINE
    AXLE & PROP
    Propshaft to Atlas/English axle bolts: M10x1.0mm pitch.
    Drum brakes to english axle Mk1: 7/16 UNF.
    Drum brakes to english axle Mk2: M12x1.5.
    Mk1 Axle U bolts: 7/16 UNF (20tpi)
    SUSPENSION, STEERING & BRAKES ETC
    Caliper to strut bolt (2.8i strut): 7/16 UNF.
    Disc to hub bolts 2.8/RS hubs: 3/8 UNC.
    Brake pipe unions metric: M10X1
    Brake pipe unions imperial: 3/8 UNF
    Bilstein competition/Escort RS type front insert bottom thread: M10x1.0mm.
    top thread 5/8 UNF
    MK1 RS roller top strut mounts - 5/16 UNF (24tpi)
    Leaf spring (front): 7/16 UNC
    Mk2 Steering rack track rod end lock nuts: M14
    MK1 rack-to-crossmember bolts: 5/16 UNC (18tpi)
    Mk1 Escort wheel studs: 7/16 UNF.
    Mk2 Escort wheel studs: M12x1.5.
    Group 4 wheel studs: 1/2 UNF.
    Capri wheel nuts: M12x1.5mm
    BODY/MISC
    Escort seatbelt mounts: 7/16 UNF
    Cross member to body: 3/8 UNF
    Mk2 Escort - most bolts are M8 (ie bonnet, boot, hinges, etc)
    Large inner tank outlet 3/4 BSP on Mk1 and most probably Mk2
    Added 5/8UNF to bilstein insert top thread
  14. The Following User Says Thank You to bobb1 For This Useful Post:
  15. #94
    Moderator+ Decade Plus User
    dangerousdave's Avatar
    Oct 2002
    London
    15,132
    65
    Re: Thread thread
    Copied that last updated post to the first post aswell as it makes it much handier being there too
  16. #95
    Pit Crew Decade Plus User justinveal's Avatar
    Aug 2008
    south england
    1,659
    133
    Re: Thread thread
    any idea what thread the nuts are on xflow inlet and exhaust studs?
  17. #96
    Mar 2004
    Bristol
    8,648
    75
    Re: Thread thread
    Quote Originally Posted by justinveal View Post
    thay are 1/2" spanner so i would guess at 5/16 but not sure if course or fine.....
  18. The Following User Says Thank You to Ratters For This Useful Post:
  19. #97
    Aug 2008
    south england
    1,659
    133
    Re: Thread thread
    they look like fine mate thanx
  20. #98
    Dave's Avatar
    Oct 2003
    Cheshire
    19,588
    141
    Re: Thread thread
    I "think" the bit that screws in is coarse and the bit that sticks out is fine.
  21. #99
    Nov 2003
    Wirral UK
    6,740
    257
    Re: Thread thread
    Yeah, 5/16" UNF for the nuts and UNC in the head.
    http://escort.accelerator.org
  22. #100
    25,124
    Re: Thread thread
    Quote Originally Posted by Dave View Post
    my thoughts too, but i wasnt sure i wasnt imagining it so i didnt say anything
  23. #101
    Aug 2008
    south england
    1,659
    133
    Re: Thread thread
    Yup your all correct definatly coarse into the block and fine for the nuts
  24. #102
    Oct 2008
    whitley bay
    2,436
    89
    Re: Thread thread
    twin cam anti roll bar thread and size?
    Hexham and District Motorclub
  25. #103
    Nov 2003
    Wirral UK
    6,740
    257
    Re: Thread thread
    The anti roll bar retaining bracket bolts are 5/16 UNC.
  26. #104
    Nov 2003
    Wirral UK
    6,740
    257
    Re: Thread thread
    Crossflow water pump pulley / fan retaining bolts - 5/16 UNC for MK1s, Mk2 and most remanufactured pumps are M8
    MK1 Escort anti-roll bar bracket retaining bolts - 5/16 UNC
    MK1 Escort window winder / door release handle screws - 3/16 (no.10) UNF (32 TPI)
    MK1 Escort interior door handle screws - 7/32 x 24 tpi - try finding them though!!!
  27. #105
    Dave's Avatar
    Oct 2003
    Cheshire
    19,588
    141
    Re: Thread thread
    http://cgi.ebay.co.uk/Interior-Door-...item2a02fb0239
    Very useful for such things
  28. #106
    Nov 2003
    Wirral UK
    6,740
    257
    Re: Thread thread
    They're the door release handle screws Dave, I meant the door closing handle - the foam and vinyl thing. They are different screws.
  29. #107
    Dave's Avatar
    Oct 2003
    Cheshire
    19,588
    141
    Re: Thread thread
    I have always giant self tappers if I haven't got the right ones for them.
  30. #108
    Racer 4drmatt's Avatar
    Jun 2007
    Bedford
    2,079
    69
    Re: Thread thread
    are these the ones???
    http://www.mtmc.co.uk/p-39078
    there's a useful table on this link too... well it was for me
    http://www.gizmology.net/nutsbolts.htm
  31. #109
    Nov 2003
    Wirral UK
    6,740
    257
    Re: Thread thread
    Quote Originally Posted by 4drmatt View Post
    Could be, but unfortunately they don't specify the number of t.p.i
  32. #110
    Jun 2007
    Bedford
    2,079
    69
    Re: Thread thread
    anyone know the thread for the propshaft centre mount on a mk1 escort?
  33. #111
    Nov 2003
    Wirral UK
    6,740
    257
    Re: Thread thread
    ENGINE
    Crossflow
    Exhaust Manifold: 5/16" 25mm long (UNF for the nuts and UNC in the head)
    Sump bolts:
    Oil Breather Box:
    Pinto
    AXLE & PROP
    top thread 5/8 UNF
    Capri 2.8 Bilstein top nut M12 x 1.25
    Rear leaf spring (front): 7/16 UNC
    MK1 Escort Steering column top nut : 9/16 UNF
    BODY/MISC
    Added quite a bit of stuff
  34. #112
    Spanner Monkey jbenny1's Avatar
    Apr 2006
    Hatfield
    257
    Re: Thread thread
    anyone know what bolt size / thread is used on the antiroll bar brackets to hold them onto the front of the chassis rail (in the corner under the rad)?
    The old bolts are rusted to buggery and i don't want to damage the captive threads with the wrong bolts.
  35. #113
    9,208
    Re: Thread thread
    bilstein bottom nut on the 2.8 billy is an m7 thread.
  36. #114
    Oct 2002
    London
    15,132
    65
    Re: Thread thread
    Quote Originally Posted by jbenny1 View Post
    Mk1 or mk2?? On a mk2 they are m10 i think so they will be the imperial equivalent for mk1
  37. #115
    Nov 2010
    daviidwilson
    36
    Re: Thread thread
    Quote Originally Posted by para144 View Post
    Anyone know the size for the nut that holds the steering wheel onto the column in a mk2? I've lost one
    dont know but theirs a couple in a box in my shed if your stuck
    ___________________
    watch movies online
  38. The Following User Says Thank You to daviidwilson For This Useful Post:
  39. #116
    Pit Crew Decade Plus User para144's Avatar
    Jan 2006
    South Wales
    1,075
    75
    Re: Thread thread
    Quote Originally Posted by daviidwilson View Post
    ___________________
    watch movies online
    Thanks for the offer, sorted now though
  40. #117
    Jul 2006
    Merseyside
    70
    10
    Re: Thread thread
    Hi Guys, Anyone know the size of the following :- (Mk2 Escort)
    Wiper Motor to body
    Heater Motor to body
    Pedal Box lower nut + upper bolt
    Steering Column to under dash nuts
  41. #118
    Jun 2004
    Bristol
    1,494
    18
    Re: Thread thread
    Wiper Motor to body - M6
    Heater Motor to body - some odd square thread (possibly acme) with 7/16" heads into clip nuts
    Pedal Box lower nut + upper bolt - both M8 I think, but lower nut could be 5/16" UNF, same as exhaust clamps
    Steering Column to under dash nuts - M8
  42. #119
    Jul 2006
    Merseyside
    70
    10
    Re: Thread thread
    Thanks Gavin
  43. #120
    Nov 2003
    Wirral UK
    6,740
    257
    Re: Thread thread
    ENGINE
    Crossflow
    Sump bolts:
    Oil Breather Box:
    Pinto
    AXLE & PROP
    top thread 5/8 UNF
    BODY/MISC
    MK1 Escort steering column to the underside of the dashboard - 1/4 UNC
Similar Threads
  1. Pinto Spart Plug Thread / Lambda Thread
    By Dalek in forum The Technical Section
    Last Post: 24-05-2005, 19:04
Tags for this Thread
