Results 41 to 80 of 101
Thread: The Ultimate Mk1 Fiesta?? ;-)
  1. #41
    Mar 2003
    Now over the pond North side
    3,540
    Re: The Ultimate Mk1 Fiesta?? ;-)
    By dazzles9r at 2010-10-08
    So, with the main part of the cage in, it was time to look at the rear suspension
    Do these look familiar?? They're from the back of the Imprezza! The thought process behind this project is for it to look like it was factory produced! So, if we can use part of the Imprezza, we will
    By dazzles9r at 2010-10-09
    A little bit of template use and drawing took place and then a trial fit. Bonus was we had a rear strut brace as well, so we could use that to make sure the tower tops were the correct distance apart!!
    Due to the contours of the Imprezza part and the contours of the rear of the Fiesta, we couldn't use the whole tower, so we ended up just using the tops!
    Then we tied in the rear strut towers to the main cage!
    We'll be connecting the 2 strut towers together with a strap bar but will do this after we have finished all our fabrication in the boot area
    Dazzle
  2. #42
    Mar 2003
    3,540
    During this initial part of the build, our donner vehicle changed shape!! We were offered a P1 for silly money! The Engine had gone 'POP', throwing a rod through the side of the block. Also it was very tatty (not well looked after!) and the guy was in desperate need of some money so the deal was done.
    Next it was onto the fitment of the Imprezza rear clip to the Fiesta. This required us getting to the underside easily. So, it was time to use my rollover jig I had for my MK2 Escort
    Dazzle
  3. #43
    Mar 2003
    3,540
    By Dazzles9r at 2010-10-09
    So, with the main brace for the rear clip cut out of the Imprezza, it was time to fit it to the Fiesta! Believe it or not, during this project we have been outstanded by the way certain things have just fitted! When we came up with the idea and had the Fiesta at the Workshop, someone with an Imprezza came down to do something on it. When he put it up on the ramp, we were able to have a good look at it and take measurements. As you are starting to see, it's amazing how much matches up between the 2 different cars!!!!!
    Obviously, once the brace was fitted, we had to have a trial fit of the rear suspension
    Dazzle
  4. #44
    Mar 2003
    3,540
    With the rear clip in place we needed to look at the boot! We already knew we would have to fit the radiator in the boot as there was no room under the bonnet!!
    We also realised how important the rear clip is, so we wanted to really tie it in well to the chassis of the Fiesta! This also required us to cut out the boot area!
    So, with the rear clip mount well and truly fitted in the car, it would be time to look at what we were now going to do with the boot!!
    Dazzle
  5. #45
    Mar 2003
    3,540
    So, with a boot floor back in (though not sure if it will stay!) by turning it upside down again we can also finish of the lower part of the clip brace and tidy it all up.
    Now it was time to take a look at the front end! One cut out ImpreZa front end ready for somewhere to put it
    One empty looking Fiesta Engine bay
    Dazzle
  6. #46
    Aug 2002
    Geordie Land
    2,232
    thats just mad
    MY MK1 ESCORT (Now turbo'd)
  7. #47
    Mar 2003
    3,540
    As you may have seen, we made a cradle for the Fiesta so we could move it about but also for the next part of the job, fitting the engine bay and g/box tunnel!
    With a little bit more measuring, and some offering up, we cut some more of the ImpreZa engine bay!
    After lots of 'in & Outs' and 'Left a bit - Right a bit' and cutting bits of here there and everywhere, it slotted in! And to be honest, a lot easier then we expected and once again, fitted up as if it was supposed to be there
    With it fitted in and some well placed welds, it was time to fit some front struts and wheels to make sure we had done our calculations properly!!
    Back in it's work slot, was time to trial fit our engine!
    Then trial fit the front panel and find out how little room we have!!
    Then we can't help but fit our new front arches
    Dazzle
  8. #48
    Mar 2003
    3,540
    With the engine bay and tunnel fitted, we looked more at the floors. We wasn't happy with the fit of what was left so we decided to go for new floor pans.
    So, knowing we was going to replace the floors, we had to cut out the old ones. I was able to get all 4 pieces of floor from the Donnington Ford spares day, and at a good price
    So the passenger side all in. Front and rear trying to make it fit/look like it was supposed to be there
    Taking care to make sure we still had the chassis number in place, we fitted in the rest of the floors! Good job we carried out those delicate repairs at the beginning
    Dazzle
  9. #49
    Mechanic mk2 wizard's Avatar
    Apr 2006
    Liverpool
    974
    Nice job no wonder ur mk2 isnt finished yet
    Looks like you know what you are doing but could you not have moved the bulk head back a bit, to give you more room in the bay or would you have lost space in the cab
  10. #50
    Mar 2003
    3,540
    With the floor pans in we had to re establish the chassis. We decided this was a good time to make it a little bit more substantial and also to connect in with the ImpreZa points that came of the G/box tunnel.
    My partner in crime decided to have a bit of a tidy up and do some of the welding that was required. I wasn't around so we couldn't get on with the next part so this was something he could do on his own!
    So the engine bay needed to be fully welded into the car.
    He then cleaned up the back end ready for fillets to fit in the corners
    Dazzle
  11. #51
    Mar 2003
    3,540
    Quote Originally Posted by mk2 wizard View Post
    Yeh, you're right there, me bad
    Many thanks Very good idea but you've answered your own question As you'll see in later posts, we can only just get the seats in! I'm 6' 2"
    Dazzle
  12. #52
    Mar 2003
    3,540
    Our next job was to start looking at the fitment of the rear axle/diff unit and the brace bars for the nose of the diff. Once again, things fitted in well though we did have to cut the brace bars down a little, they were still in the same plane
    Then we needed to look at the tie bars. Again, the Fiesta uses tie bars for it's rear suspension and with a little adjustment we were able to make mounts in just about the same position!
    These tie bars were something we quickly made up so we could put it on it's wheels and move it about! We will be looking at them again soon to come up with something different
    Dazzle
  13. #53
    Mar 2003
    3,540
    So, with the rear end finished to a point where we could move it about, what do you do?? Maybe fit your engine?.......
    .....Maybe fit all the suspension, wheels and running gear and push it outside for some piccies??
    And a quick fit of the front panel just to remind us of our future problems :Whatever_
    Hmmm, we seem to have missed out on a few photo opportunities! But these couple are of the roof skin removed! Doesn't look like we have any of the new one being fitted?? It was changed as the ghia originally had a microwave door in it!
    Dazzle
  14. #54
    Mar 2003
    3,540
    Well, unless the piccies turn up later, it doesn't look like we've got any of putting the roof on! Shame, as we did a good job!!
    Once we had the roof on, it was time to look at the front wings. Because of the way we had fitted the engine bay, we had some space where the inner wing parts should be, so we had to remove the outer wings in a certain way to allow us to do some modifications to the front. We're having a removeable front panel so need to pick up on the right bits of the wing
    These last 2 piccies are of the new wings fitted and the front panel all modified to be removable and give us clearance of the engine!!
    This is where the fuel filler normally fits on a MK1 Fiesta.......
    ......We didn't want ours there though so started to move it somewhere else
    Bit of modification...
    Studs welded to the inside of the B pillar....
    ....and a new filler placed in the B pillar!!
    A bit of paint to show it off in a better light
    Dazzle
  15. #55
    Sep 2006
    cambridge
    1,056
    WOW that one hellva project there love it some quality work going on there..
  16. #56
    Dec 2006
    Here
    396
    this will be mental mate
  17. #57
    Mar 2003
    3,540
    Due to the change in our filler hole, we had to remove evidence of where it was before hand
    While we're not always able to work on the car, we are doing research and asking questions. One of them was to do with the Cooling system. After talking with several companies, we came up with an idea and paid a large sum of money to one of them...
    These piccies were sent of along with a drawing with dimensions on it.....
    .......and this beauty came from mister postman :luxhello::luxhello::luxhello:
    Pro Alloy came up with the goods for us and we have to say, what a beautiful piece of workmanship!! We'll definitely use them again
    The arch kit we're using requires us to cut the fronts, which is easy enough but the rears need to be tubbed. So we started out by cutting the outer part first.
    Dazzle
  18. #58
    Mar 2003
    3,540
    We decided to roll out the inner arch to mate up with the outer arch as we believe this will keep it nice and stiff! An arch roller was made which didn't work too bad! Well enough to do the job
    Another thing that was going on during this time was the good old E-bay searching. One of the next purchases was some seats....
    With the seat mounts fitted, it was time to fit the seats in
    Dazzle
  19. #59
    Mar 2003
    3,540
    Another thing that was going on was the choice of wheels and brakes. We had a bit of a catch 22 situation as to get the brakes made, they needed to know the wheels we were going to use! And then when we went to buy the wheels, they asked what brakes we were going to fit!!
    We didn't want to fit anything bigger than 15" rims, so most of the ImpreZa rims were out of the question. Also, we wanted to keep with the ImpreZa hubs, so this also limited us. We wanted to keep them looking a bit old skool.
    So, we purchased our wheels. This then allowed us to send one of with a front strut/hub to get the brakes fitted/made!
    As you can see the calipers were from a MGF and were a good deal from the Bay So, a company called BG racing in Birmingham took on the job of fitting them inside our wheels with the biggest discs they could!
    And with the Compomotives fitted as well! Looking good
    Seats, wheels, brakes and tyres all fitted
    To aid the flow of hot air from the boot area, we made a few openings
    Dazzle
  20. #60
    Mar 2003
    3,540
    As we've now aided the air flow out through the back of the car, we thought about what was stopping it coming through from under the car. The rear clip is held together by a pressed metal contraption, stopping all air flow, so we decided to make a new 'less' restrictive version
    So we built a jig and some braces to hold it all in the right place! Then we took lot's of measurements and started to construct something
    And that's all the piccies!!
    Not bad, has only taken me best part of a day and a half to sort it all out and put it up on 3 different sites!!
    Hopefully it'll be easier to keep up to date now!
    There's loads of things missed out, not intentionally, just no piccies. BUT it's always good to keep some surprises back
    I hope you all enjoy
    Dazzle
  21. #61
    Bodger Retro-Mike's Avatar
    Mar 2009
    Hertfordshire
    That's amazing!, very impressed with your work
  22. #62
    tuk and poke me Decade Plus User mogsmex's Avatar
    Jul 2002
    essex, innit !
    2,763
    9
    looking the dogs bits Dal, nice to see it still progressing, let me know when you want the SS stripes put on
  23. #63
    Mar 2003
    3,540
    Quote Originally Posted by mogsmex View Post
    Funny you should mention that!! We've already talked about it and want you to fit them
    Dazzle
  24. #64
    Bodger longy's Avatar
    Dec 2009
    derby
    129
    WOW
  25. #65
    Bodger Turbosport Subscriber stew's Avatar
    Nov 2004
    rainham essex
    that looks the bollocks dal , could do with a few more pics though
  26. #66
    Mechanic bennods's Avatar
    May 2009
    Staffordshire
    731
    23
    top work. makes me wish i was the WORLDS GREATEST FABRICATOR instead of the WORLDS GREATEST LOVER! still, we all have to make do with what gifts God gave us.
  27. #67
    Aug 2009
    blackpool
    24
    stuning build top work hope to see it finished
  28. #68
    Part of the furniture Decade Plus User Ratters's Avatar
    Mar 2004
    Bristol
    8,648
    75
    awesome work buddy fooking love it
  29. #69
    Mar 2003
    3,540
    Many thanks for the kind words gents
    Spending 4 full days on it next week and aiming to have the engine running and loomed up
    Dazzle
  30. #70
    Spanner Monkey FrEdOoOo's Avatar
    Mar 2009
    Portugal
    384
    25
    Stuning build, love it!!!
  31. #71
    Tyre Kicker Scoobys FieSTI's Avatar
    Oct 2010
    Oxfordshire
    Hellooooo!
    I have just joined the forum to get involved with the chat, I am building this FieSTI with Dazzle, and hope to play a part in keeping you up to date with the progress on the old girl,,, and the FieSTI
    So many toys so little time!
  32. #72
    25,124
    wow fantastic stuff mate
  33. #73
    Mar 2004
    Barking Essex
    9,034
    262
    That is an amazing project, and it looks like its going to be weapon when its finished. Some well thought out fabrication work aswell.
    Keep the updates and pictures flowing, liking your work gents
    Old skool forever
    Just don`t tell the wife
    how much it really costs!
  34. #74
    Nov 2004
    Sunny Essex
    4,831
    100
    Cant see all of the last pics for some reason but thats a great project you got there. Glad to see you've used origional panels as much as possible from both cars as that gives it an almost factory look. Should absolutely fly
    Mar 2003
    3,540
    Quote Originally Posted by david_white View Post
    Just scrolled back up and I can see them all
    Thanks for your kind words though mate
    Dazzle
  36. #76
    Mechanic rampant racing's Avatar
    Nov 2008
    sarnia ontario canada
    58
    521
    10
    absolutely lovely job.an inspiration to us all.
  37. The Following User Says Thank You to rampant racing For This Useful Post:
  38. #77
    Nov 2004
    Sunny Essex
    4,831
    100
    No worries its a superb bit of kit, oh and I think there were too many pics for my laptop to deal with so I just altered the size of the pages in the forum editor and now I can see them all
    Love the rad set up
    Mar 2004
    Harlow, Essex
    14,285
    318
    Nutters!!
    And you just know i love to see something different
  40. #79
    Jun 2006
    3,670
    Great build fella's
  41. #80
    Mar 2003
    3,540
    Dazzle & Scooby are very happy boys!!!
    Here's why
    http://img145.imageshack.us/img145/3507/img0290.mp4
    Dazzle
