There seems to be a couple of options for running big cams, either under bucket shims from trd or similar or yaris 1fz-fe solid shims. both these options are fairly expensive.
So i was wondering if i could set the clearance using standard shims and buckets and then tack weld the shim into the bucket using a tig welder to stop the cam lobe flicking it out.
I realise it sounds like a bit of a bodge but just looking for a cheaper alternative.
