Results 1 to 11 of 11
Thread: piper 285 cam
    Jan 2014
    Essex
    piper 285 cam
    I brought a mfi head for my rs turbo powered bonus and its got a pipe 285 cam just wondered if any one new what stage it was cheers
    25,118
    Re: piper 285 cam
    generally considered a fast road/mild competition profile, probably to wild to work well with a turbo
    Jan 2014
    Essex
    piper 285 cam
    Ok cheers
    Pole Position Decade Plus User morcheen's Avatar
    Sep 2003
    n/london
    20
    955
    Re: piper 285 cam
    quite a common cam on rst back in the day.i think i have one on an old head somewhere.
    Jan 2014
    Essex
    piper 285 cam
    Sweet chees guys do any of u no what stage they are?
    Spanner Monkey haz87's Avatar
    Aug 2012
    Colchester
    218
    Re: piper 285 cam
    This cam doesn't really fall under a stage. Like Graham said fast road/mild competition area, so if you were comparing against say Newmans 'staging system' then it would be a ph4(ish) in the cvh world
    Jan 2014
    Essex
    piper 285 cam
    Ok cheers haz
    romford essex
    2,613
    86
    Re: piper 285 cam
    I use to use these all the time and run at 115 deg, they made 230hp on low comp them run out of fuel with the mfi system so were drop to 220 hp and diddnt hang about brilliant cam and run smooth
    Jan 2014
    Essex
    piper 285 cam
    Ok cheerts
    Mar 2007
    Hartwell
    166
    Re: piper 285 cam
    I use to fit these in the day , use to set them to the right spec but nearly always use to so a cam swing for best results. I think
    from memory it was something like 3-5 degrees advanced on the cam for best results and always use to see around 10-18hp
    gain on a healthy motor runing around 12-14.7 psi.....
    Jan 2014
    Essex
    piper 285 cam
