Page 1 of 2 1 2 LastLast
Results 1 to 40 of 71
Thread: Zetec on the cheap maybe?
    Aldershot
    4,538
    This site has a good guide about doing a zetec conversion on the cheap. Has anyone tried the cvh ignition ecu on a zetec before and does this actually work?
    Pit Crew Decade Plus User TepiTheFinn's Avatar
    Jan 2003
    Finland
    1,226
    Re: Zetec on the cheap maybe?
    my friend took ignition system from fiesta hcs engine...working fine...
    Aldershot
    4,538
    The only problem that is putting me off is no one seems to have done this and if I have to buy a £400 ECU as well as everything else then I can't afford it. Argh this is doing my head in.
    Richard
    Pit Crew Decade Plus User ludsonline's Avatar
    Apr 2003
    Suffolk
    1,417
    Sierra 1.8 CVH sump & pick up pipe will fit.
    We need to set up a Zetec conversion bit on this forum so this conversion can be done cheaper with everybodies help
    What do you think?
    Jul 2003
    England
    766
    19
    agreed, weve got a cosworth section, now we need a zetec section.
    Jonny
    Pit Crew Decade Plus User esscynutter's Avatar
    Jul 2003
    All smegged out somewhere
    959
    What about the ecu from a late model xr3i along with the wiring loom does anyone know if this will work as that is electronic injection as well???????
    Aldershot
    4,538
    Luds you got photos of the sump and pickup pipe modifications or do they bolt straight on? And what car does it work for? I don't think the xr3i system is gonna be much good. You don't need the injection part cos its cheaper and easier to use carbs. You need something to do ignition cos the zetec uses distributerless ignition. I think some late cvh carb models had this and this might work. Possibly the sierra/granada dohc engine (yuk) might have an ecu that would work as I think some came with a carb instead of injection. We definately need a zetec section. How about an engine conversion section with cossy, xe and zetec subsections? could be an idea. I'm off to look at a zetec install to make a final decision....zetec or pinto.
    CU
    Richard
    Jan 2003
    Finland
    1,226
    direct ignition system from fiesta/escort HCS-engine has one drawback. Rev.limit is set to 7500RPM. but in daily cruising should not be a problem.
    very easy to install...i have advance curve somewhere...
    i will buy Mondeo 2.0 zetec "black top" with mechanical valve lifters. 1998 onwards.
    just wondering, can i use the same DCOE intake manifold what is used with older zetec. is there any difference in bolt pattern and port sizes?
    Aldershot
    4,538
    I thought thats the limit of a zetec anyway even with arp bolts on the rods? I've decided to go with a pinto anyway now because its going to cost too much money. Dammit
    Feb 2003
    S/West
    158
    Having tried this engine conversion ( and spent enough money to fund a small south american army), I can say that when these things run right, they are extremely quick and ecenomical. Like all things, theres a cheap and expensive way to go around doing it.
    My advise would be to buy mounts and a water rail ' off the shelf' and to then buy a CVH sump, ignition pack, and to go for an 1800 zetec motor as these seem to need less expensive bits to make them go.
    Jan 2003
    Finland
    1,226
    allrighty then, now i have bought a new blacktop 2.0 zetec engine.
    wasn't cheap, but sure is clean.
    Jan 2004
    here
    2,410
    Jonny
    http://www.zetecinside.com has a lot of info on fitting one into a fiesta
    Jan 2003
    Finland
    1,226
    here is pic of my new engine which arrived today.
    well, it's a little bit dusty, but otherwise brand new, never been started
    but the mk1 where to i'm gonna put it, ain't that shiny. think i spend my holiday with mig welder
    Jan 2003
    Finland
    1,226
    how is this done? looks like a hole drilled for thermostat in to the side of cylinder head?
    http://img6.photobucket.com/albums/v...r/DSC01277.jpg
    World Champion Decade Plus User Pitstop's Avatar
    Apr 2003
    Essex
    66
    4,809
    Looks like you have the same outlet on your engine.
    Aldershot
    4,538
    I think you can blank the outlet from the back of the engine with plate and drill into the water jacket in the head and have an outlet from the side instead. Then you don't need to buy a water rail. Thats what it looks like to me anyway.
    Richard
    Apr 2003
    Suffolk
    1,417
    I have spoken to a m8 with a zetec in his 1950's Ford pop & he is running a xr3i coil on a homemade bracket driven off the exhaust cam with a standard ignition loom and twin carb's and he says it runs sweet
    Apr 2004
    hiya peeps!! ive just fitted a 2.0ltr focus blacktop into my mk2 orion! (i dont know why either?!) but i have been living in scrapyards for the past couple of weeks!! i used a mondeo ECU and engine loom (its separate from the main car loom) and a few hours reading the haynes manual wiring diagram to find out where the wires go to! because its an alloy block most of the wires are earths so thats easily sorted... ive had to fit 3 relays and a fuse box for the possitive side of things.. but if i can do it im sure everyone can!!
    ive had it running but not for long coz i havnt sorted the coolant pipes out yet... back to the scrappy tomorrow then!!!
    while doing this conversion a seem to come across people who say they know how its done but wouldnt give up any info?? its as if they say ive struggled so you can too!!!
    but we are all in this game together so why not help each other out??!!
    so if i can be of any help whatso ever please email or post on here.... just got to get my computer re-routed to the scrappy now!!!
  19. #19
    Apr 2004
    here is an pic from early in the conversion!!
    http://img6.photobucket.com/albums/v.../zetec_013.jpg
  20. #20
    Jan 2003
    Finland
    1,226
    alloy block??? did i misunderstood something? is there an alloy cylinder block in your 2.0 blacktop engine? mine is cast iron? i thought only duratec comes with alloy block?
  21. #21
    Apr 2004
    its obviously been too long a day in the scrap yard today then!!! but MOST of the sensors are either on plastic (inlet manifold and thermo housing) or the alloy head... thanks for pointing that out to me matey!! im now off for a good lie down in a dark room somewhere!!!
  22. #22
    Jun 2003
    CHESHIRE
    967
    Can i get a 2.0L Zetec from a focus is it the same as the mondeo
  23. #23
    Aldershot
    4,538
    No thats a Duratec. Much better engine too. If its cheap go for it. Thats the all alloy one. More power than a zetec and much lighter too. Just harder to get the conversion parts for. I think Burton do them though.
  24. #24
    Apr 2003
    Suffolk
    1,417
    My 2001 Focus has got a Black top Zetec in
  25. #25
    Apr 2004
    the engine ive got is a black-top focus one! (and its the cast one not the alloy one!) the engine itself wasnt too bad for fitting, it was the wiring that i had most hassle with!!
    the mondeo engine has the sump at the diffrent end of the engine and i belive it catches on the g/box x-member... so the sump and pick-up pipe need to be changed, the focus has a strenthening intermediate sump wich has to be ground at the rear to clear the driveshaft but other than that it was just like fitting a cvh back in!!
    p.s. to the people who have e-mailed me i will be in contact asap with what details i can help with!! please bear with me!!
  26. #26
    Jan 2003
    Finland
    1,226
    do all blacktops have same waterpump. i would like to change direction of rotation, and replace the pulley to one with grooves
  27. #27
    Apr 2004
    i think its only the mondeo with the stupid long belt that goes the WRONG way!!
  28. #28
    Apr 2003
    Suffolk
    1,417
    My block is cast iron aswell
  29. #29
    Jan 2003
    Finland
    1,226
    do you have pic of your focus waterpump and pulleys
    Cheers,
    Tepi
    i think i should install microcat, could save me from many questions
  30. #30
    Apr 2004
    ive been asked by a few people for pics so i'll take some tomorrow!!
  31. #31
    Jun 2003
    CHESHIRE
    967
    one in my 2000 focus is a 1800 zetec ?
  32. #32
    Apr 2004
    sorry i havnt been able to take any pics yet due to the fact i havnt got a under water lens!!! bloody rain!! i'll take some as soon as noah comes past!!
  33. #33
    Apr 2003
    Suffolk
    1,417
    You can use the ignition from any carb CVH with HCS ignition and then use either twin choke weber on modified CVH manifold or twin 40/45's webers with a four branch. This definatly works
    Paul
  34. #34
    Apr 2004
    hey! its stopped raining so i took some pics!!
  35. #35
    Racer Decade Plus User Dom's Avatar
    May 2003
    UK/France
    1,934
    BTTT because I thinking of a Zetec conversion, so has anyone got it in yet?
  36. #36
    Jan 2003
    Finland
    1,226
    i'm going to make engine brackets on weekend
  37. #37
    Apr 2004
    well in the above pics it looks like its in!! and ive had it running too!! fitting the engine in was the easy bit!
  38. #38
    Aldershot
    4,538
    I think he means in a RWD car. Its a lot more involved. The best way is to mod the bulkhead and use the dunnel sump/mounts and the raceline water rail. An easier way is to use the Retro Ford stuff because it doesn't require any body mods. It mounts the weight further forward though so not helping the handling. Bit of a question mark over how good their sumps are too. Ashley do a manifold for the zetec that I think bolts to an x-flow system.
    Richard
  39. #39
    Mar 2004
    Harlow, Essex
    14,285
    318
    I use the Dunnel sumps, and yes the engine is a few inches further back, and yes the gearbox tunnel does need enlarging, and the bulkhead has to go back, but dunnel has been doing this for a few years, and I've never heard of any problems with oil surge. Dave Whites (Gulf Oils MK2 RS2000) car has the Dunnel engine mounts, flywheel, clutch and sump, Raceline water rail and stat housing, MBE Ecu (mappable) 45's, and hit 173 bhp on the rollers from a standard 136ps mondeo 2L. have a look at the attachment.
  40. #40
    Mar 2004
    Harlow, Essex
    14,285
    318
    Ooppps
