Re: NewGroup 4 Escort MK2 rolling shell
[ATTACH=CONFIG]80008[/ATTACH][ATTACH=CONFIG]80009[/ATTACH][ATTACH=CONFIG]80010[/ATTACH][ATTACH=CONFIG]80011[/ATTACH][ATTACH=CONFIG]80012[/ATTACH][ATTACH=CONFIG]80013[/ATTACH][ATTACH=CONFIG]80014[/ATTACH][ATTACH=CONFIG]80015[/ATTACH][ATTACH=CONFIG]80016[/ATTACH][ATTACH=CONFIG]80017[/ATTACH][ATTACH=CONFIG]80018[/ATTACH][ATTACH=CONFIG]80019[/ATTACH][ATTACH=CONFIG]80020[/ATTACH][ATTACH=CONFIG]80021[/ATTACH][ATTACH=CONFIG]80022[/ATTACH]Tags: NonePosting comments is disabled.
Categories
article_tags
Latest Articles
by madmaxpttI am building a 2,3 pinto with twin dcoe 45s.
what is your advice???-
Channel: Welcome to Turbosport
27-03-2024, 10:52 -
by ZakspakBreak pedal box back on the bench for fitting the break light switch and setting the pedals up.
09-08-2023, 15:39 -
by ante1970Ok boy. Thank's at all. Today, with help of my father in law have finished " modification with hammer" of oil pickup and make little space for conrod bolt ! Post some pics of work ! Another time thank 's HonkyWhiteTrash and Daniele....
08-05-2023, 18:15 -
by MO1Wanted
Good usable SIERRA Cosworth 16V head complete or minus valves. But must have cam caps. Cheers-
27-04-2020, 19:23 -
by ZakspakOn to the centre sections. New metal on to new metal. Nice ! I welded extra plates in where the jacking point is to increase its strength, hopefully to stop it becoming dented when on stands or jacking. I over laid the new sections against the originals to check alignment, and marked them for drilling the plug weld holes. Again insides where painted with the gloss black. I marked where the originals where and removed them. Due to the replacement floor it was just a matter of un-bolting th...
21-02-2019, 15:26 -
by markbRyou should be abel to reduce the size by editing them in paint or similar.. to post them upload them using the link at the top of the page and copy the test it gives you into a post ...
29-05-2017, 15:30 -
