Re: 1977 Mk2 Zakspeed Escort. Rebuilding my pride and joy.
    On to the centre sections.
    New metal on to new metal. Nice !
    I welded extra plates in where the jacking point is to increase its strength, hopefully to stop it becoming dented when on stands or jacking.
    I over laid the new sections against the originals to check alignment, and marked them for drilling the plug weld holes.
    Again insides where painted with the gloss black. I marked where the originals where and removed them. Due to the replacement floor it was just a matter of un-bolting them. I had to cut through the front chassis rail just ahead of where the centre section extends.
    Again lots of measurements taken and marked off, although the dimension drawing doesn't show any critical dimensions here. Not as many pictures taken as I thought, so hope it makes sense.
    Did the RH side first just because I was set up for it from the rear section.
    [ATTACH=CONFIG]83622[/ATTACH]
    [ATTACH=CONFIG]83626[/ATTACH]
    Rail is bolted down first, for alignment and also to pull the rail and the floor together. That's the gap I had to close up.
    [ATTACH=CONFIG]83623[/ATTACH]
    [ATTACH=CONFIG]83624[/ATTACH]
    and bolted in place
    [ATTACH=CONFIG]83625[/ATTACH]
    Plug welds made mainly from underneath through the flanges.
    Then the LH side.
    [ATTACH=CONFIG]83621[/ATTACH]
    Complete
    [ATTACH=CONFIG]83627[/ATTACH]
      Posting comments is disabled.
    Categories
    article_tags
    Latest Articles
      by madmaxptt
      what is your advice???
      27-03-2024, 10:52
      by Zakspak
      09-08-2023, 15:39
      by ante1970
      08-05-2023, 18:15
    • Cosworth Head
      by MO1
      Wanted
      27-04-2020, 19:23
      by Zakspak
      21-02-2019, 15:26
    • Fitting radiators
      by markb
      29-05-2017, 15:30
