Price for the scraper is £30 + £8 registered postage to UK and rest of world, sent with a piece of wood on one side to keep the plate nice and straight
Have about 10 in stock at the moment if interested send me a pm with your address and I will send you my paypal email
The scraper is fitted with RTV sealant on both sides of the scraper and a normal cork gasket on the other side, both sides will be level when fully tightened
Fit the sump tighten the bolts, let the RTV sealant set over night, then fully tighten, will give a perfect seal
The half round rubber sump seals need to be modified slightly on the scraper side, simple cut 1mm off the bottom with a razor blade so that the seal sits on top of the scraper
Bulk discounts available
Regards
Jason
