The chevy SB Small Journal rods (to suit a 2.000" big end) are the right length and very cheap, (the ones you have links to will not fit as they are to suit 2.100" journals) only problem is they are much narrower than std pinto rods, however the small end is much wider, std pinto = 25.8mm wide small end and big end, the eagle 5700SLW rods have a big end width about 2mm narrower, 1mm each side, but the small end is 26.924mm wide, this might be a good fit in the Ross pistons, a friend of mine has a set of them, I will ask him what the width between the pin bosses is
