Originally posted by lee edwards
Pinto Big Valve Head
Selling the head which i had built from new parts back in january. Its done 2 night events.
New cam bearings, Seals and Valve stem seals.
The head has been machined to give a CR 10.75:1 on a Standard bottom end.
Also the head has just been pressure tested and is fine! (I removed the head because cyl 4 had low compression, HG was fine, so i had the head test which was fine, i then stripped the bottom end and its the piston and ring)
Stage 2 Ported & Polished Head
New Stainless Steel Big Valves (44.5mm IN - 38.1mm EX) in cotters
New Double Valve Springs
New Newman 4.5 Cam
Vernier Pulley
New Padded Followers
New 82Deg Thermostat
Also included is a New Felpro Head Gasket, So its ready to fit!
£650
Any questions
Lee - 07725518796
