Originally posted by snapper1
My Cossy 2wd sump, oil return blanked off but could easily be unblocked if required.
Very clean with no repairs.
Better windage plate fitted, I believe Doug did this as it matches the pattern of the baffle top plate he makes and I bought the engine from his mate.
Extra lug welded to the sump front, this was used for a crank position sensor for a Megajolt install.
Small ground relief on an internal web possibly for long stroke crank.
£100
