My MK2 Just for Dave !
    • 977007
    So what do you think about the motor !!
    Regards
    Clint
  • **DONOTDELETE**
    • Jun 2026
    • 1400
    Re: My MK2 Just for Dave !
    perfect combo )
    • BigDave
      • 4787
      Just one reply to that...
      Giz it !!!!
      • BigDave
        • 4787
        well then????
        When are you dropping it off at my house then??
        You know it makes sense??
        Me, me, me, me...
          ooooh gimme gimme gimme
          • Magrah
            • 1599
            Mr Clint
            Whens it going to be finished and how long has it taken you so far?
              Dave I will drop the car off to you for no charge if you wanthehe
              • BigDave
                • 4787
                I always knew that Sharon was a top lass!
                I get home on Tuesday..Say around 2 ish??
                Dave...
                  • 977007
                  I want it finished by end of next year had the car since November 1999, used it for a while then went into hoard mode for the parts, so far I have the axle setup most of the engine and front suspension and brakes, getting the body rebuilt soon (Thanx Mark) so it will start comming together.
                  I am a bit worried that when its done that Sharon will want to always drive it.
                  Regards
                  Clint
                  • BigDave
                    • 4787
                    Well if either of you get sick mate..You know where I am!!
                    I keep saying the same to Dingy but he will never part with his beastie!!
                    Dave...
                    • Magrah
                      • 1599
                      Firstly, Dave you have far to many cars as it is!
                      Clint, what axle are you using, and what brakes?
                        • 977007
                        The axle began life as a 30k mile item from a MK3 2.0 Capri, Gartrac shortened it to MK1 3litre capri lengh using thich wall tube and fitted cooling unions for the diff, I had them slide the 4 link kit brackets over while they were at it. It then took a trip to Quaiffe where it was fitted with a new ATB Diff and 3.22 CWP Group 1 Shafts and Flanges. This is (I am told) the same setup as used by Paul Bailey on his RS500 MK2.
                        The brakes are 280mm 4x4 cossie rears and 335mm AP fronts using 5200 calipers.
                        Regards
                        Clint
                        • BigDave
                          • 4787
                          How do you spell that noise that is made when Drool runs all down your chin???
                          Go on, giz it!!
                          <A target="_blank" HREF=http://www.big-dave.8k.com/>Big Dave's Happy Place</A>
                            The year is nearly up Clint
                            • BigDave
                              • 4787
                              and I still want it!!! Go one I have said pretty please. well I just did then anyway....
