Mk1 Escort
  • mrjimbo
    • 668
    Mk1 Escort
    Just thought I would post a few photo's of my Mk1 Escort
  • Merlin69
    • 156
    Re: Mk1 Escort
    I recognise those piccies Mr Jimbo - top class - tell the gang the specs mate!!!! Lovin it!
    RWD ESCORTS RULE THE FUEL WORLD
    • esscynutter
      • Jul 2003
      • 959
      Re: Mk1 Escort
      v-nice mate
        Re: Mk1 Escort
        Well nice!
          Re: Mk1 Escort
          Ooohh when did this get posted, I've got a soft spot for Mk1's or should that be a .... ok won't go there..
          well nice though
          • nobby
            • May 2004
            Re: Mk1 Escort
            Looks good
              • 977007
              Re: Mk1 Escort
              Very sweet m8ty
                Re: Mk1 Escort
                I know this should be in the tech section, but your pics show the relationship between castor and camber angles when the steering is off center.
                In the straight ahead position it looks like your running around 2 degrees neg, and when looking at the other pic with the wheel turned you can see that the wheel is almost upright and the wheel we cant see may have 3-4 degress neg on it.
                Which is why i don't worry about castor angles and only set the camber as a start point from experience at anywhere between 1-3 neg depending on what the car is doing, the castor I leave to the driver to tell me what he wants, then when the tyre temps are taken after a few laps the camber can be adjusted to suit what the tyres temps tell us.
                on some tracks this may mean the camber is taken off and castor is added to get more neg camber on the car through tight corners without the need to overheat the inner edge on fast, shallow corners with long straights between them.
                Ok I'll let people carry on telling you what a nice car you have
