Road Rally Mk2 Escort No 5
  • JimKeogh
    • Sep 2008
    • 95
    #16
    Re: Road Rally Mk2 Escort No 5
    Axle painted...drum brakes retained incase I decide to do historic events
    • JimKeogh
      • Sep 2008
      • 95
      #17
      • Miniliteman
        • Feb 2004
        • 5078
        #18
        W.r.t. the engine crossmember: I wouldn't elongate the holes.
        You could fit a crossmember chassis tube kit or (what I did) modify the engine mounts in such a way that the engine + gearbox fit the tunnel.
        • JimKeogh
          • Sep 2008
          • 95
          #19
          Thanks Miniliteman....I have that chassis tube kit fitted . Good call about the engine brackets...I will do that
            #20
            Originally posted by JimKeogh
            ....we learn! I sealed the rear firewall with fireproof sealer....but can somebody tell how does a scutineer know that the sealer is actually fireproof?
            Speaking as a scrutineer, they will only be looking to see there are no gaps that fluid can pass through, they wont actually check to see if its fireproof
            • JimKeogh
              • Sep 2008
              • 95
              #21
              Thanks Graham.
              Just to follow up on an earlier post I got the gearbox moved over and now its about 3 mm from the tunnel...I'll leave it at that for now and see how it behaves when I drive the car.
              The fire extinguisher I went to great pains to position behind the navigator's footrest is not legal here in Ireland for stage rallying. I'm going to put it behind the drivers seat and move the battery from there to the boot. The oil cooler had to be moved as well as the pipes were not long enough. So much for my dry build!
              • JimKeogh
                • Sep 2008
                • 95
                #22
                The boot is nearly there..just a couple of earth straps to bolt in
                • rallyrob
                  • Apr 2010
                  • 2739
                  #23
                  Looking good
                  • JimKeogh
                    • Sep 2008
                    • 95
                    #24
                    A photo here of the interior. I had to cut up the mint carpet and there will be a bit more cutting when I get the roll cage back from paint. I was at Group 4 Fabrications today in Galway returning the M16 callipers vented discs and spacer kit as they didn't fit. They are genuine Ford reconditioned calipers and for now there is a a lot of head scratching going on.
Name:	escort interior.jpg
                    • FrankC
                      • Aug 2012
                      • 128
                      #25
                      Too nice to rally…don’t do it!
                      • JimKeogh
                        • Sep 2008
                        • 95
                        #26
                        ...its only going to be used for a bit of fun....I'm not chasing pots.........for now!
                        • JimKeogh
                          • Sep 2008
                          • 95
                          #27
                          • Mkdu
                            • Oct 2009
                            • 422
                            #28
                            here in Belgium, extinguisher must be accessible by both from their seat and needs to be a 2kg one.
                            • JimKeogh
                              • Sep 2008
                              • 95
                              #29
                              Yes I have a hand held one which will go just infront of the navigator's seat
                              • JimKeogh
                                • Sep 2008
                                • 95
                                #30
Name:	13.4.24 Escort finnished.jpg
                                Well the car is built and I entered it's first event on Saturday just gone.The TDC (Trial Drivers Club) Irish Classic Retrospective Trial 2024....here it is at the end of a long day driving 250km around the beautiful County of Wicklow and doing 15 special tests. The fact that the car made it round was the best takeaway from the day. The car build was only finished the night before and test driven for about 3 miles!
