Jon Betts MK1 Escort Sprint/Trackday
  • Jon
    TS Supporter/snapper
    • 1567
    Most of you will know my car from the pages of Classic Ford and down at Retro Motorsport where most of the work has been carried out. I will update with more details and a full tech spec ASAP but I'm just off to finish my Christmas shopping!
  • PIG
    • 11882
    Re: Jon Betts MK1 Escort Sprint/Trackday
    very nice
    • Ratters
      • 8649
      That's a cracker
      • tezscort
        • 552
        Looks awesome mate.
        Of all the things I've lost, its my mind I miss the most.
          • 977007
          It looks the nuts Jon
          • FOSSIE
            • 1591
            That's one saucy motor.
            Having seen it in the flesh, i can safely say the paint finish is every bit as good as it looks in the pictures.
            Any chance of some pictures under the back Jon? popcorn:
            • Jon
              • 1567
              Having owned a number, well loads of modified cars from Lowriders and Kustoms to V8 Yanks and Mini’s I decided to build a MK1 Escort taking my main influence from the V6 SuperSpeed Escorts. The plan was to fit an Essex V6, Panhard rod, anti tramp bars and keep everything very subtle but then I spoke to Gary at Retro Motorsport, and well you can see what happened! I have tried to build a very period looking race car, but have stuck with the Essex regardless of the ‘it won’t handle’ comments. The engine is set quite far back and I think it will handle as well as any Escort, if not better. It maybe down on power compared to many of the Cossie/XE/Duratec cars but the Essex will provide plenty of torque and there’s loads of scope for further improvement as it’s fairly tame at the moment.
              I owe a lot to Gary for the way the car has turned out and while I’ve tried to do as much as possible it just wouldn’t be like this if it wasn’t for him. I’ve still got to sort the windows, wiring, and propshaft out but I’m hoping to be getting it MOT’d in February then I plan to compete in the RAF MSC sprint series which is campaigned on various air bases close to where I live. It will be a case of drive to an event, maybe change wheels, compete then drive home.
              Engine: 3100cc Essex V6, Kent fast road cam, 40DFAV carb, custom made tubular exhaust manifold, Aldon electronic ignition, 4-speed Capri gearbox, twin side pipes..
              Suspension: Front Gaz coilovers, twin cam anti roll bar JEMS tubular cross member, quick rack, poly bushes, double width and anti dive kit. Rear Four bar, watts linkage, GAZ coilovers, poly bushes, Atlas axle, Fossie built LSD, Image 3-piece split rims, Toyo tyres.
              Brakes: Hi-Spec front dics conversion, Retro Motorsport rear disc conversion, mechanical handbrake, bias pedal box.
              Body/Interior: Steel bubble arches, bumper removed, modified 6-point Safety Devices roll cage, flocked dash top, Cobra bucket seats, roof mounted switch panel, Smiths gauges, Silver with black/green Castrol design by Central Blast Cleaning, removable towing eyes, safety cut-out box.
              Thanks to: Retro Motorsport, Central Blast Cleaning, Janspeed, Fostec Engineering, Kent Cams, Safety Devices, Image Wheels, Toyo, Specialised Engines plus many others….
              More pics to follow...
              • Dom
                • May 2003
                • 1934
                That looks really I'm liking that alot
                I posted! Another thread successfully ended then....
                  Nice pics Jon, you could do that for a living
                  The car looks very nice and I'm sure you are very proud of it now its nearly done. Good to see something that looks and is a bit different too
                  Cant wait to here it rumble now
                  • andy
                    • 4929
                    • Jon
                      • 1567
                      • Bart2207
                        • 816
                        WOOOOOOOOOOOOOWWWWW
                        What a nice car!!!!!!!!!!!!!!!!!!!
                        "Busy doin' nothing..."
                        • Dom
                          • May 2003
                          • 1934
                          You might want to put some nuts on those link bars!!!!!!!!!!! What sort of power does the V6 put out? Any chance of a pic of the dash as I'm thinking of flocking mine but haven't seen what it looks like on a Mk1
                            now i like that luuuurrrrrvvvlly motor
                            • Kevmk2
                              • Dec 2003
                              • 10228
                              Looking good mate. I really liked it when i see it a couple of months ago.
