Ford Taunus TC2 - now Trackday car
  • Arieke
    • 442
    #61
    the engine had I Think 10 years ago a fresh build, new rings and bearings. So should be still oke. If i do a full season of Rallycross I maybe do 160km, The engine would have 1500 on it so. Still fresh i asume. Every year a oil change. and filters.
    Original? :-p Its a bit modified, But there aren't alot of go faster parts for these engines. expect cams.
    • Arieke
      • 442
      #62
      Last weekend 22 august on the race at last the diff broke. So i opened it up today and the satelits are broken, so the rest is intact. Pinion and crown wheel are oke. So Will be taking the old satelithousing out and fixing it and hopefully i can fix it before the event in holland starts. Will post pics of the diff.
      I had fully bushed the rear axle and yes my problem is solved, it pulls nicely off the start it was awsome, till it broke. had lots of fun with it on saterday
        • 25244
        #63
        sounds like you fixed the first problem, now your probably gonna keep breaking diffs
        • Arieke
          • 442
          #64
          we are going to fully lock the diff. We going to fill the satelite housing with melted pistons. So it forms a solid block so, this should be stronger then just welding the teeth together.
          People say the this is a chocolat axle, but what actuallty breaks? Pinion? crownwheel, shafts? of the satelits?
          If i get the full locked diff back i will put a pic on. It will be cool.
          • Arieke
            • 442
            #65
            So I got my new diff back, it is I think stronger then before. We made 2 flat sides on the satelite wheels en made a metal piece and placed it in the satelite housing. And the rod that holded the knackerd satelite wheels in place, we used it again to hold the metal piece in place.
            Pics:
            I had a go with it, Its been tested and it didnt break yet, I dont assume it will break. If something now breaks, it will be the half shaft or the whole housing.
            • Arieke
              • 442
              #66
              So at last I found the cortina atlas axle. Went to Germany drove up 600 km. And wel worth it but now. I dont know what diff ratio to get.
              I would like to keep my MT75, because i modded whole the tunnel and driveline.
              My powerband is from 2500 rpm 175NM to 4600 rpm 200NM and At 6600 175NM So it aint high revver.
              13" MT75 + 4,63
              16, 9,6 6,2 4,63 3,5
              RPM 1 2 3 4 5
              1000 6 11 17 22 30
              1500 9 16 25 34 44
              2000 12 22 33 45 59
              2500 16 27 41 56 74
              3000 19 32 50 67 89
              3500 22 38 58 79 104
              4000 25 43 66 90 118
              4500 28 49 74 101 133
              5000 31 54 83 112 148
              5500 34 59 91 124 163
              6000 37 65 99 135 177
              6500 40 70 107 146 192
              7000 44 76 116 157 207
              MT75 + 5,14
              18,5 10,6 6,9 5,14 3,9
              RPM 1 2 3 4 5
              1000 6 10 15 20 27
              1500 8 15 22 30 40
              2000 11 19 30 40 53
              2500 14 24 37 51 67
              3000 17 29 45 61 80
              3500 20 34 52 71 93
              4000 22 39 60 81 107
              4500 25 44 67 91 120
              5000 28 49 74 101 133
              5500 31 54 82 111 147
              6000 34 58 89 121 160
              6500 36 63 97 132 173
              7000 39 68 104 142 186
              MT75 + 5,8
              20,9 12,0 7,8 5,8 4,4
              RPM 1 2 3 4 5
              1000 5 9 13 18 24
              1500 7 13 20 27 35
              2000 10 17 26 36 47
              2500 12 22 33 45 59
              3000 15 26 40 54 71
              3500 17 30 46 63 83
              4000 20 35 53 72 94
              4500 22 39 59 81 106
              5000 25 43 66 90 118
              5500 27 47 73 99 130
              6000 30 52 79 108 142
              6500 32 56 86 117 153
              7000 35 60 92 126 165
              I got some price from fostek 225£ for 4.63 300£ for 5.14 and 5.8 for 440£
              Somebody told me on this forum the best gear diff ratio is 11 for racing. So the 5.14 is the closed to 11. Any body have a bit advise? Yes The first Gear wont be any use only for in the carpark. So second Gear is the starting Gear.
              in 2011 mid season i will start building a 2300 RS engine, and cams. So power wise the car will have more Torque.
              Thanks
              • REGMCI
                • Jul 2011
                • 15
                #67
                Any news?
                Don't Scrap it, Restore it !
                • Luke
                  • 392
                  #68
                  Yeah whats been happening?
                  • SidewaysMk1
                    • 1284
                    #69
                    Originally posted by Arieke
                    Re posted the pics
                    Any info on the distributor setup?? it looks like a CVH one but don't the weights in dissy work the other direction??
                    1973 mk1 escort
                    1982 Toyota corolla ke70
                    1988 mk4 escort
                    • Arieke
                      • 442
                      #70
                      Been long time, i recently build a 2300 bottemend. This or next week i hope to port the head a bit so it can flow some more air. Just waiting for the inlet manifold. (i'll post pics from block) the one i have is to restrictive.
                      I think its a CVH one, but when i got a new cap and rotor they gave me parts from a rover :-s. so i' wouldnt know
                      For the rs2300 I'm going to use a pinto distributor from my blown up pinto. I don't know about weights. i thinks it turns in the right direction. clockwise like the pinto ones.
                      • Arieke
                        • 442
                        #71
                        Plans for this winter are,
                        Succesfully build a rs2300 and hope for 200+hp and +185 lb/ft of torque.
                        A new exhaust is build build because i can't build exhaust. Will add pics when I get the car back.
                        A brake upgrade and only in front. My disks have a verry nice blue color after the race. So going to fit 260mm vented disk and clamps from the scorpio with red dot pads. And a master cilinder from a 2.8 granny. I hope this works. (i still have the standard brakes on the car)
                        An other things is installing servo. (steering) because turning the steering wheel is hard and trying to down shift doesnt work that good. (2:1 steering) And its killing my shoulder. I have a rack from a sierra dohc.
                        And of course some bits and bobs.
                        • rwd2ltrfiesta
                          • Jan 2011
                          • 1731
                          #72
                          how u guna make a pinto dizzy work on the 2.3, cant u use an esc1 pack that some people use 4 the zetec conversion, i have an esc 1 pack running the ignition on my rs2k with carb, its about 50 quid ish, but looking gd all the same
                          • Arieke
                            • 442
                            #73
                            info on r2300
                            some pics.
                            A scorpio 2300 block with sump from a 2.0 DOHC from a sierra because then i can remove the balencer shafts. less weight more revy
                            Using a Rs2000 head with RS2BP300H RALLY cams, (these are the latest cams you can use before getting rid of the hydrailic tappets) and adjustable camshaft sprockets. and a moddified pinto dizzy from H&H.
                            Took of 1.3mm from the pistons, because cr is to high if you use rs2000 head you get 11.8, what is nice you i had forged pistons and better con rods. But thats a bit to much for the standard pistons. the rs2000 had 10.3. I'm hoping for 10.6 - 10.7. But I don't know much cr they can take so trying to do a safe build.
                            Thats all for now i think.
                            • Arieke
                              • 442
                              #74
                              going to make it the same way it works on my rs2000 engine. To be fair i wont know how to install it. And would believe a moddified dizzy by H&H would have a better advance curve. the pinto dizzy I got was build for a race engine. so i would asume its better then a sec1 pack. or am I wrong?
                              • Arieke
                                • 442
                                #75
                                pics of engine
ID:	1995148Click image for larger version
ID:	1995149Click image for larger version
                                for some reason, i couldn't upload the pictures.
