    Funny how sometimes bad news are infact great news. I had my injectors tested and the result was a disaster. "Bin them" was the recommendation. They had some 50% differences in total volume between them on partial load near idle and 30% on full duty. I ordered a new set on the spot. All this cost me 400€ but I'm still smiling and feeling light at heart.
    So after work I raced to the garage to start putting the car back together. I installed the new fuel lines which proved to be a good move. The old fuel feed line had leaked in its protective pipe. The stagnant fuel inside the pipe had softened the hose and it made some alarming cracking sound when bent. This new hose is higher quality and stronger and can be submerged to fuel. Some fuel hoses apparently can't.
    The new iinjectors are a 70cc's bigger so I need to get the car on the rollers to get it mapped for the new squits. If it starts to run proper that is.
    Thought I'd stick in the new manifold on while I'm at it to see how it performs. So I needed to spray on the coating 24h before installing.
    The coating was very thin and left the media blasted surface quite grainy. Propably blasted with too coarse media for this coating. Nevertheless It does it job protects against corrosion and even more so acts as a heat insulation. Looks almost like cast plastic when dry.
    So I still have a week to make it to the season finals.So that feels like a real fighting chance. The new injectors should arrive tomorrow or on monday. If the car starts to run properly I was promised it would be mapped by the end of the week.
    • madragon199
      • May 2010
      • 1139
      Great news ..hope you have solved the problem..watching with interest..
      Cheers mark
      • dug112y
        • 298
        is it possible the fuel hose has deteriorated and contaminated/blocked injectors/filter/pump or regulator?
        track fiesta on all the right bits.....
          My thoughts exactly. Only the injector specialist reckonf there would be some debree in the injectors filters but according to him there was none. But still I can't help but think these things are somehow linked. And on that note I changed the fuel lines to a quality hose. And renewed the filter. I still need to flush the fueltank.
          I think the inferior fuel hose don't take well to these new petrols with 5% ethanol in them.
            Manifold and the rest of the system installed for good today. Made an additional bracket for the manifold for added support, installed new fuel lines and re routed the oil lines. Busy day but I'm very happy with the outcome.
              Got the official test chart. Maximum flow cc/min was 288cc worst and 342cc "best". Dynamic test showed 27cc's in worst and 39,6cc's in the best.
              The car now seems to hesitate when starting to move and stalls easily. But soon picks it self up and can now take load. Only the new mani seems to leak from the overlap joints and may throw the lambda off so I need to take it out and seal the joints.
                Sealed the manifold , dropped the fuel pressure to 3bar and re calibrated the throttle body. Now the car acts nicely. The TPS had trouble noticing the tiniest openings of the butterflys. Hence the hesitation and stalling when calmly lifting of the clutch. After re calibration I feel the car is ready for rollers. The maps are obviously off but now it moves and can deal with load. I'm booked for thursday evening. And hopefully on friday morning I'll be off to the season Finals.
                • Matt75
                  • Mar 2011
                  • 797
                  Good to hear things are getting sorted. Must be very frustrating.
                  Matt
                    Its now sorted! The rollers show its not missing a single pony. Infact due to the new manifold it's even gained some between 4000 to 6000. Some 10 to 20Nm more to be more precise.
                      excellent news, well done
                        Great job getting it sorted. Hopefully you will have many good races with no more problems
                          Yeah, if the dry sump belts could just stop snapping. That would be great.
                            Have you space to fit a wider set of pulleys and a decent strong dry sump drive belt, honestly I think that the usual dry sump belts are just waiting to fail, they are the flimsiest things I have ever seen & they keep the engine together, the only thing I would trust those little belts to drive is a sowing machine lol!
                            Good work with the manifold, I was expecting more mid range with the relatively small pipe diameters and long primary lengths you chose, great that the top end is the same as before, very best of luck with it
                              There's your problem.
                              Which resulted in this.
                              And in turn to this. Some colors in the oil
                              NOTE TO SELF: Do not reuse the locking pin on the main axle.
                                That is a seriously messed up looking belt and locking pin.
