Australian Forest Escort
  • bmw02rally
    • Jan 2010
    • 92
    #16
    Re: Australian Forest Escort
    Cars just about ready for its first dance on the gravel.....took her for a drive and she goes pretty well for what she is!
    First event on the 31st March is a charity ride day for kids with cancer so a good shakedown and a good cause! Can't beat that!
    I've changed over to the forest setup ready...
ID:	1997717Click image for larger version
ID:	1997718Click image for larger version
    Aussie Taffy
    • bmw02rally
      • Jan 2010
      • 92
      #17
      My mate who has done all the Carbon work on the car arrived with a pressie today. Fibre Glass Bonnet complete with RS stripes! I think it looks so cool?
      Aussie Taffy
      • rwd2ltrfiesta
        • Jan 2011
        • 1731
        #18
        gotta go full stripes now , sweet car fella
          I like that!
          • flowmetrics
            • Dec 2007
            • 61
            #20
            very nice car!
            • jimmy2006
              • Feb 2009
              • 1986
              #21
              [ATTACH=CONFIG]53413[/ATTACH]
              looks well you going over the roof and down the boot with the strips
              • bmw02rally
                • Jan 2010
                • 92
                #22
                I think I'll have to now to match it all up...thanks for all the comments lads. I just hope it still looks like this after the weekend! First time out in 5 years and not many of those were on gravel so I'll be bricking it on Saturday morning.
                Aussie Taffy
                • bmw02rally
                  • Jan 2010
                  • 92
                  #23
                  Well the weekend was awesome due to the company we had and the reasons for the event!
                  The car and driver need a bit of work to say the least.
                  The Escort started well then the main ignition fuse came loose cutting all power, with that restored I spent my time looking at oil pressure and water temps just to be safe. It was very hot and rough!
                  The temp went up too much at the end of each stage so that will need looking at. Then after a pretty good attack at a hairpin I ripped the rear tyre off the rim and the front shock top mount nut came off which ended play as a didn't have any spares.
                  I was a bit gutted that I couldn't take any more people around for the ride too be honest as its such a good cause but it was a truly humbling experience and a really good first test for the car and driver!
                  Here is a short compilation my son Ethan has done on youtube of the event....enjoy.
                  Mark
                  Aussie Taffy
                    Well done on your first event - ripping a rear tyre off sounds scary!
                    • bmw02rally
                      • Jan 2010
                      • 92
                      #25
                      Well its been over a year...I have been out of work twice, the engine and box have been in and out at least 4 times but finally I think I've turned a corner.
                      I fixed the oil leak that ruined 2 clutches by spending hours filing down the very slightly raised Tig welding on the Retrosport wet sump to make sure it was flatter than a flat thing! Then I used a different gasket glue and it finally has a good seal.
                      I decided to enter Saturdays Murwillumbah CARnival as mine and the cars first proper Australian event to try and see if it would hold together and to see if I had gotten to old?
                      First of all the car and the driver still need some work as I am rusty and the car needs setting up BUT I can't say I wasn't chuffed with coming first outright with both the lowest accumulative time over 6 runs as well as fastest time of the day. So it looks like there is some life in me yet but I've got to be honest the car is by far the quickest thing I have driven in anger....just need a set of cams, rods and pistons and she should be pretty competitive.
                      Mark
                      Aussie Taffy
                      • nathanblaise
                        • Jan 2013
                        • 209
                        #26
                        nice car, I noticed that you are not running a header tank for the cooling - hows is that working out for you? Also would you be able to tell me which radiator you are using (if you got it off the shelf of course). Cheers and all the best!
                        • bmw02rally
                          • Jan 2010
                          • 92
                          #27
                          I am running a big header grp4 rad from out of the UK. Can't remember where from but they are basically all the same? It hasn't overheated so far and it was a hot 30 degrees in the shade on Saturday.
                          Mark
                          Aussie Taffy
                          • nathanblaise
                            • Jan 2013
                            • 209
                            #28
                            Thanks for the reply Mark. Sounds good, I think I'll try and souce one locally as they tend to cost a lot to get shipped (as much as the Rad sometimes!). Cheers.
                            • PERKY
                              • Oct 2006
                              • 2658
                              #29
                              Nice car mate, looks like it goes well too in that video
                              • bmw02rally
                                • Jan 2010
                                • 92
                                #30
                                Here is said video...
                                Aussie Taffy
