TUTORIAL - Changing Wheels
This is a sticky topic.
  • Adam_Ash
    holier than thou
    • 1035
    Right tried to keep this simple
    First, open up the picture you want to put the wheels on.
    Next open up the picture of wheels you need to nick . Use the elliptical marquee tool to select a wheel, if you have trouble using that you can also use the lassoo tool, either magnetic or polygonal .
    Copy the wheel using EDIT, Copy. or CTRL + C.
    Select the image you are adding the wheels to, and select Paste. Ta daa you now should have a wheel on your picture.
    if it is the wrong way around once pasted, use Edit, Transform, flip horizontal.
    Then use Edit, transform and Scale to resize it.
    Move to where you want and job done
    Repeat with the rear wheel and you have cracked it
    cheeRS
    Ad
  • Bricktop
    • 213
    Re: TUTORIAL - Changing Wheels
    Once again Adam you're a star
    Question for you, the tutorial is based on a side view of a car, what happens if the car is at an angle?
    • Adam_Ash
      holier than thou
      • 1035
      just cut them out the same and use the transform options to rotate and change angles of the wheels.
      piece of piss m8
      cheeRS
      Ad
      • Bricktop
        • 213
        Take a look at the pic, does it look ok?
        I took the wheel from the red cossie above just to try it out,
        am i right in thinking that the wheel that you copy/paste has to be facing you like the ones above, i tryed with a wheel from a car pic that was at an angle, but got all confused cos the wheel looked like it was facing the wrong way
        • Adam_Ash
          holier than thou
          • 1035
          you can basically cut one from any angle and by using the Skew Distort & Perspective, you can change the look of the wheel.
          I think thats what you asked
          cheeRS
          Ad
          • Bricktop
            • 213
            Adam, see the pics below, can you take the wheel from the 5 series and put it onto the mustang? because of the angle the pics are so different i wasnt sure if it can be done?
            the mustang pic is nice and easy to work on cos of its size, thats why ive been using that one
            • Adam_Ash
              holier than thou
              • 1035
              yeah it can be done , not very well though.
              You just need to have a mess about m8, thats how i learned
              cheeRS
              Ad
              • Bricktop
                • 213
                I dunno that look fine to me i had trouble with the angles etc
                ahh thanks Adam you've been great, im still in the testing/learning stages just need a few pointers in the right direction, thanks again
                • Bricktop
                  • 213
                  right heres the Mustang with a set of Viper wheels on it, i know they look a bit false cos of the wheel colour (i'll have to learn how to change that) but do they look ok? are they at the right angles etc?
                  • Adam_Ash
                    holier than thou
                    • 1035
                    Looks spot on that m8.
                    Just use Image, Adjustments, Hue / Saturation to change the colour when wheel is selected
                    cheeRS
                    Ad
                    • Bricktop
                      • 213
                      thanks, i give it a try
                        angled photos don't work so well with deep dish wheels, or wheels that have a lot of shadow on them. Notice that the two examples both the front and back wheels are the same wheel off the other photo, the back wheel off the beemer was to angled to be of any use. Think about this when chossing the wheel you want too use. Skew etc can only do so much.
                        you can see on the pics below, I've tried to squint the front wheel a little but the pic still looks a little wrong. Original for this was borrowed from PF so sorry if it's your motor...
                        • h290ewk
                          • Aug 2003
                          • 549
                          Adam is that the same way you go about changing the colour of cars? by using the adjustments like hue/saturation and replace colour?
                          • NRspeed
                            • 1762
                            heres my effort, thanks for the how to's.., and a colur change a pearly grn job.
                            CheeRS Nat
                            PS3 gametag: NR_Speed
                            • NICK MEXI-COS
                              • 1640
                              Some one try this the , see what wheels ya have
