Had a little play, nothing major, its pretty much right as it is. Quality isnt great cos piccy was shrunk for the net, will get some better ones on Sat when i pick it up.
The quality has gone down alot as you have your JPEG compression quite high. You should be able to set the JPEG compression to none and it will look a lot sharper. HTH
