Page 2 of 2 FirstFirst 1 2
Results 41 to 73 of 73
Thread: How to Fit 2wd Cossie 4 Pots to RWD Escort.
  1. #41
    Mar 2004
    Harlow, Essex
    14,285
    318
    Re: How to Fit 2wd Cossie 4 Pots to RWD Escort.
    numbers on their page ... http://www.raldes.co.uk/
  2. #42
    Pit Crew Bart2207's Avatar
    Jun 2004
    Netherlands
    816
    Can somebody please tell me what thread size the RS strut has, and what thread should be made to fit the cossie calliper???
    "Busy doin' nothing..."
  3. #43
    Pit Crew Decade Plus User raymondmarble's Avatar
    Sep 2005
    Dundee
    1,029
    116
    That Cosworth caliper conversion actually looks really good. I can honestly say I've never seen them on an Escort before.
    I went a wee bit off the beaten path with mine. Dont think anyone else has Porsche Brembos on an Escort, but they are tops and I got them cheap
    Cheers! Graham
  4. #44
    Nov 2006
    Enfield
    66
    90
    where did you get the mounting brackets from for the Porsche calipers?
  5. #45
    Sep 2005
    Dundee
    1,029
    116
    Hi mate
    The rears are lug mounted, so no big deal, but the fronts are radial mounted so I had some alloy mounts cnc'd up. They wern't cheap, but are the business! You could just as easilly make the mounts out of steel and weld something up. Again, no big deal.
    Hope this helps mate!
    Cheers! Graham
  6. #46
    Remember the camper......? Decade Plus User
    mk1matt's Avatar
    essex
    7,616
    70
    Some pics of my brackets my dad made me using this thread for info
    The small holes are for locking tabs.
    Instead of surface grinding the plates down he turned them down on thye lathe.
    Started with 1/2" plate and it ended up around the 7/16" so if you can source some 7/16 plate you may be able to use that
  7. #47
    Spanner Monkey Turbosport Subscriber NeilCos's Avatar
    May 2004
    Neath
    379
    Excellent work Matt (and Matts dad)
    Can you post up the dimensions for those brackets?
    Have you thought about making a few more sets for sale?
    Neil
  8. #48
    mk1matt's Avatar
    essex
    7,616
    70
    I thought about making up a few brackets but got a deffinate NO from my dad
    As for dimensions which ones are you after?
    I can put up the overal dimensions of the plate and the thickness.
    Wonder how i would go about posting a realsize pic
  9. #49
    Moderator+ Decade Plus User
    dangerousdave's Avatar
    Oct 2002
    London
    15,132
    65
    Keep shrinking it til the one you have in your hands the same size as the one on the screen
  10. #50
    Oct 2008
    MANCHESTER UK
    Thought i may add some info here for those looking to run 14 or 13" wheels
    Disks Citroen BX16V or diesel fronts 266x20.
    You will have to increase the whole in the center of the disk to suit the hub and re drill mounting holes.
    Rally Design part number BM121; You will have to adjust mounting lugs for the calipers with a new mounting plate.
    These fit sunbeams also. best suited to Willwood or Brembo calipers
    If you are looking for a 260x22mm disk E30 BMW work also, I used to machine these down to 258mm for princess/volvo calipers.
    Rally Design part number: BM067
  11. #51
    Oct 2008
    MANCHESTER UK
    not sure which of these 2 is the disk used in the Rally Design 285 kit but knowing RD they always look for something that requires next to no machining.
    RENAULT. 21 2.0 TURBO 87/92-F 285/21 BM246
    Rover 800 820, 820T; V6 86/96-F 285/21 BM092
    Anyone got any idea's which it is?...i am swaying to the Renault disk at this time.
  12. #52
    Spanner Monkey robvirgo's Avatar
    Mar 2002
    Cork , Ireland
    251
    10
    any pics of this 13" conversion.nice solid upgrade for cossie powered old skools
    rob v
    Rob Virgo
    Cork
    Ireland
  13. #53
    Dec 2007
    Dubai
    1,678
    29
    Well as I have decided to go with 15" wheels, have bought a nice set of RWD Cossie calipers off eBay. I have a set of 260mm Rally Design discs, so will have a look and see if I can get the calipers to work on those for 13" wheels, while I am playing with them
    Has anyone figured out what disc it is that Rally Design use for their 285/BD13 disc, as I may be able to get them locally, or are there any other Disc options I can use on the Cossie Caliper conversion for my Capri struts
    www.gulfpetrolheads.com
  14. #54
    Nov 2005
    preston
    284
    i think they are 2.8 capri ones ? not sure wot i ordered when i rang ?
  15. #55
    Dec 2007
    Dubai
    1,678
    29
    Quote Originally Posted by graham c View Post
    Thought the 2.8i ones were 247mm
    Did some measurements on the RD 260mm ones that I already have:
    1: Hub hole (disc centre) 68mm
    2: mounting bolt PCD 92mm
    3: disc thickness 21mm
    4: mounting face thickness 8mm
    5: total disc height (hub face to disc front face) 32mm
    So basically have to find something like that, but 285-300mm in diameter
  16. #56
    Oct 2008
    MANCHESTER UK
    Im now pretty sure the BD13 disk is the Renault 21 Turbo disk, after finding a pic on Ebay showing the top of the disk.
    bay prices are around 40quid
    and then i find these pics of the Rover disks http://forums.mg-rover.org/showthread.php?p=3317323
    hard to tell although the renault disk looks to have less offset
  17. #57
    Oct 2008
    MANCHESTER UK
    Renault 21 turbo front disk 285x21, look to have around the right offset, priced for group N at RD 51quid, BD13 replacement disks 51quid...kinda to close to be not the same.
  18. #58
    Dec 2007
    Dubai
    1,678
    29
    Yeah the Rover disc has a 51.2mm offset, as seen here
    A pair of the Rally design BD13 discs are £138 including vat
    A set of the Renault 21 Turbo discs which would require the centre hole to be machined out to 68mm and the mounting bolts drilled at 92mm pcd for the Ford fitting, can be had from eBay for £65 or half the price
  19. #59
    25,124
    bob at EBC tells me they sell lots of Renault discs to rally design
  20. #60
    Dec 2007
    Dubai
    1,678
    29
    Must be the BD13 drilled to suit their various Wilwood packages, wonder if EBC would sell them direct (drilled for Ford) or undrilled
  21. #61
    Oct 2008
    MANCHESTER UK
    ahha that says it all
    Do they have an exclusive deal or are they willing to work with the members here on kits?
    Looks like the regular Renault 21 disk is 244mm
    BMW E30 260mm
    Citroen BX16V or diesel 266mm
    Renault 21 Turbo 285mm and possibly a 260mm disk
    All will fit Sunbeams or Escorts with simple mods.
    If EBC are willing they could list up fully re-machined disk prices with minimum order quantities for group buy
  22. #62
    Mar 2002
    Cork , Ireland
    251
    10
    doubt ebc would rick a solid contract with rd for a small gb
    rob v
    Rob Virgo
    Cork
    Ireland
  23. #63
    Oct 2008
    MANCHESTER UK
    depends how many modified 21 turbo disks he sells and if he supplies them pre modified. If he just sells disks then we have no issues...
    Also RD used to use the BX16V disks and the e30 disks for escorts but no longer list them, the e30 machined down to 257 suits princess/Volvo callipers and I seem to remember the BX16V disk suited superlite callipers. The standard e30 would be good with old gp4 callipers.
  24. #64
    Clint's Avatar
    Jul 2001
    938,794
    Btt
  25. #65
    norfolk
    72
    77
    Before seeing this thread I have just put 285mm Renault 21 discs and Cossie calipers on my Corsair 9with 16 inch wheels). Home made brackets. Very good results. Using National brake disc catalouge their number is NBD596 2.0 Renault TXi year 89-92 as has been said open out the centre hole and drill four more holes to fit Ford hubs other dimensions the same as Capri Injection. Other Renault 21 use 5 studs so make sure you get 4 stud ones. Paul
  26. #66
    norfolk
    72
    77
    Ok I have done the above and the brakes work great...But I have used a .875 master cylinder. When you apply the brakes the pistons move out and clamp the pads but when you take your foot off the pistons retract off of the pad by less than 1mm. When you reapply there is a small amount of pedal travel. Now all is bled correctly no air. A friend has suggested that the size of the master cylinder piston may be pulling fluid back and therefore pulling the pistons back as well. Strange but it sort of makes sense. Anyone with any ideas out there? As a temporary solution I have made up some ally shims between pad and piston but with wear it will come back. Paul
  27. #67
    Ireland
    3,579
    173
    Yeah your front master cylinder is too large, try using .625" for the front calipers as Clint suggested
    If anyone is interested I can supply modified 285 x 21mm plain discs read to bolt onto your front hubs, same as the rally design items but cheaper, current RD prices are £120 for the pair + vat, £144 + delivery, I can do them for £139.95 including delivery to UK and Ireland, also soon I am going to design a fitting kit with brackets and bolts to fit cosworth calipers for a reasonable price, send me a message if interested, rwdfords@hotmail.com
  28. #68
    Nov 2009
    essex
    6,623
    338
    i'll have to remember you when i need some bigger discs!
  29. The Following User Says Thank You to caprimentle For This Useful Post:
  30. #69
    Ireland
    3,579
    173
    We can modify a variety of discs to mount on the back of the hubs as per normal and with the rear face of the disc in the same position as a std 2.8 capri disc to clear the steering arms and give plenty of clearance to the wheel spokes on the outside, some of the rear mount disc sizes are:
    260 x 22mm, 266 x 22mm, 285 x 21mm, 285 x 26mm and 300 x 26mm, most available grooved
    Can also do front mount discs such as BMW E34 302 x 28mm but they have the disc positioned further out towards the wheel spokes and more than likely need some 8mm wheel spacers for clearance
    Will be working on a new front brake upgrade soon with 300 x 26mm discs and alloy 4 pot calipers from a high powered car
    Let us know what you need and we will more than likely be able to sort you out
  31. #70
    Clint's Avatar
    Jul 2001
    938,794
    I am now using a Peugeot disks £30 a pair then my lolcal shop enlarges the center and drills the 4 holes for £30 the pair, same brakets in this thread
  32. #71
    Tyre Kicker wyngt's Avatar
    Feb 2007
    anglesey
    21
    Are 4x4 callipers and pads the same as 2wd pads?
  33. #72
    Ireland
    3,579
    173
    No, 4wd calipers are single pot, 2wd are 4 pot, pads are also different
  34. #73
    kent
    348
    can you still get these done Clint?
