Complete kit to convert your ATLAS axle to disc brakes, including the following;
Pair - NEW 2wd Cossie/Granada/Sierra 4x4 handbrake type rear calipers
Pair - NEW Solid discs to suit
Pair - Steel mounting brackets
Pair - Bearing spacer plates (fills the gap where the drum backplate used to be)
Set - Brake pads
Set - mounting bolts.
And some fitting instructions.
Turbosport members price: £225 (inc VAT) + P&P
NOTES:- These calipers have the mechanical handbrake facility which is required by law for road cars...
- The kit does NOT include handbrake cable itself - as the type required depends on the vehicle being fitted to. We can advise on the right cable - but usually a Sierra or MK5 RS2000 cable does the job.
- The mounting brackets are the WELD-ON type. You will notice they have bolt holes - but these are for alignment/spacing purposes only - basically to get the bracket in the right place before welding. The vehicle must NOT be used with the brackets only bolted on.
- The kit can be used in conjunction with 6x13" RS type alloys (picture below shows this) but I must warn you that it is a fairly close fit....
- You MAY require longer wheel studs when using rear discs.
HALFSHAFTS - In order to allow the disc to fit over the halfshaft flange, the OD of the halfshaft has to be machined down a couple of mm. If you have access to a lathe, this is a 30second job.... Otherwise send your shafts to me and i'll do it Free of Charge, then send the shafts back with the kit.
ALL PARTS AVAILABLE SEPERATELY - CALL FOR DETAILS.
I think that's everything. Any questions just give me a shout.
The kit will soon be available to fit the
ENGLISH axle... Watch this space.
