Ford Fiesta Zetec-S Race-Car
  • Mordriel
    • Nov 2010
    • 5
    Hi there,
    my name is Kevin Hönscheid, I'm from Germany, 23 years old and a mechanical engineering student.
    I thought I would be reporting regularly this year from my Autoslalom championship in Germany.
    I'm starting in the class for modified cars up to 1600 ccm with my Zetec-S,
    which I built together with my Dad, who drove STT, VLN, 24-h and Hillclimbs with the racecars he developed and build himself.
    Unfortunately I only got 113 bhp and some of the other cars in this class have 140 bhp +. It's all a matter of getting more power approved by the local authorities which is a crux in Germany... And you need this approvement of road-legallity for starting in the class.
    I'm starting together with my Dad.
    Some pics as it stands now:
    First the championship and it's rules.
    Slalom is a time-attack type of race.
    Each driver races individually and alone.
    Usually it takes place on big traffic-training facilities, huge parking lots or small airports.
    There will be a fixed course you have to drive as fast as possible.
    This course is set with pylon alleys and gates as well as some stating the side which you have to go around. One pylon lying with its big bottom facing to one standing beside ( like this: <|/\ ) means for example "drive right" and like this /\|> means "drive left".
    You have to get through the full course one or more times which depends on it's lenght.
    There are Slaloms of under 1500 meters and over 1500 meters.
    For each pylon you knock over you will get 3 sec on top of your time. leaving out a gate or driving around the wrong side means a harsh 15 sec on top.
    As 3 secs are a world already you better have a clean lap.
    I'm driving in the so called Class F9.
    F means it is for modified cars and according to the regulations really a lot can be changed. Engine wise you may change everything before the throttle body, which needs to stay standard as well as the inlet manifold. You can freely modify the engine internals as well as the exhaust system.
    Without going into too much details here the rest of the car can nearly be modified at will but you have to keep the upper part of the dashboard and your heating system.
    The main Problem is that all of these things need to be road legal, which in Germany means someone like your MOT-Testers needs to approve every single part that has been changed and only if that is possible you may drive the car legally like it is on the street and due to the regulations in this class F.
    In Germany this approvement ceased over time and due to strict watch from the higher ups a lot of testers simply wont approve of good modified Stuff anymore. I mean, if an exhaust rattles and defo is too loud, ok, no problem if it does not get approved, or if the brakes are crap and so on.
    But if you use just the best quality parts and even then if the tester says "WOW what a extremely nice and good built car!".... in the next sentence he says: " I can't approve of that!" and you ask "Why?" and he just says without a real reason but worries about his job "I just can't, if anything happens they'll rob me of my license!"
    This is a trend due to cheap tuning and accidents because of that. Therefore it gets very difficultto get things street legal nowaday here in Germany.
    Long story short, after asking a lot of people and crying blood and tears why I have built something like that for the street my car is, as it stands, completely legal and therefore within regulations for class F.
    The planned engine upgrades:
    I already got a baffled sump here from Shawspeed as well as a lightweight flywheel supplied by TTV Racing Components.
    I just didn't have the time to fit them.
    I also wanted to upgrade the engine output with a worked head and some nice cams such as SS4's. I already had quotes from Jon.
    BUT I need to get them approved and since we have some nice EU regulations regarding exhaust gas regulations nobody wants to simply approve of the more BHP since the car pollutes the air a lot more than standard...
    And since that is the case I need to wait for more power until I find someone to get it approved....
    Let's come to the cars spec:
    915kg due to regulations
    113 HP, 150 Nm unmapped
    Engine bay:
    -2001 Zetec-S
    -1.6 Zetec-S Phase 1 engine
    -BMC Carbon Airbox
    -Milltek 4-2-1 Manifold
    -200 cell HJS Race-Cat
    -In house custom built free flow exhaust system
    -Sachs Race engineering Clutch and plate
    -SPAL fan
    -strenghtened shifting-rods
    -FRP Box
    -LSD
    -Vibratechnics Competition Engine Mounts and Torque Link
    Suspension and Brakes:
    -H&R Racing Coilovers
    -All Powerflex Bushes
    -Some sets Team Dynamics 1.2s 7x15
    -Street: Toyo R1R 195/50 R15
    -Dry: Dunlop Slick 205/555/15
    -Wet: Matador Rain-Tire: 200/560/15
    -upper and lower strut brace
    -rear strut brace
    -ALL Suspension parts renewed
    -Groved and tempered Sandtler Brake discs
    -Ferodo DS 2500 Pads
    -HD Braking-Hoses
    -All Brake parts NEW
    -Long, trimmed studs, aluminium wheel nuts
    Interior:
    -WIECHERS FIA Certified Full cage
    -SABELT 6-Point Seatbelts
    -Sparco Bucket Seats
    -OMP Alu-Pedals
    -VDO Clocks for oil-/watertemp, oilpressure
    -Carbon Doorcards front and rear
    -Battery in the back within a case
    -Lightwight OMP Alumium Fire extinguisher AFFF
    -battery cut off switch
    and some more parts I have forgotten
    The car was built in house by WH-Motorsport, which means mostly me and my dad.
    Here are a few tech pics from the car, more to come as I need to source them from my dads PC.
    Suspension and brake, I'm running another set of springs at the front now though:
    A little bit of my underbody and my epic exhaust system:
    And I'm waiting for some free time when I'm @home to fit this shiny thing
    Thats it for the write up now, if you got any questions, let me know!
  • Mordriel
    • Nov 2010
    • 5
    Re: Ford Fiesta Zetec-S Race-Car
    Review of the first two Races on the 30. and 31. March
    First of all it was damn cold, 1 to 2°C to be precise, not exactly good for tire temperatures.
    It even snowed during the race...
    Saturday Race:
    Second place for me with best-time but due to a fault of mine I got some extra time on top, therefore second place.
    Third place for my dad.
    Sunday Race:
    First place for me with 1.8 seconds of a gap to the second place.
    My Dad got the third place.
    Very happy with the results and the car handled extremely nice with the new Dunlop Slicks.
    • PERKY
      • Oct 2006
      • 2658
      Great little car, maybe worth you looking at this thread :
      He has a similar race car.
      • Mordriel
        • Nov 2010
        • 5
        I know Jason's since 3 years
        • Mordriel
          • Nov 2010
          • 5
          Since the pictures on the first post somehow decided to take a leave here they are again:
          Obviously a problem with the image hoster, we will see if they can sort it.
          • stitchmotorsport
            • Apr 2012
            • 29
            looks great the couple ive driven have been great fun. good luck with getting your engine upgrades approved.
            stitchmotorsport
            fail to prepar prepare to fail
            • Mordriel
              • Nov 2010
              • 5
              UPDATE!!!
              News from the Slalom at the Motodrom Hagen at the 14.04.
              First place in Class for me and 4th for my dad.
              Even though this course was more power demanding than the one before we still got the best overall car setup wise.
              I changed the wheel geometry before the race to get the maximum out of the car on this course.
              And as I could get the full potential out of the car timing 1:39,84 and 1:39,86 the limit was set.
              The major player Civic Type-R EK4 was left behind 2 Seconds each run which made a tremendous gap of 4 seconds overall to the second place!
              Just a side note to myself: I need to disable the ABS/TC for the next dry run. Just when the ABS kicks in it reduces the amount of braking power to nearly zero... Not a fun fact indeed. Could've run at least a second faster without it but as I was already on track I couldn't change it anymore.
              Well, here are some Pics of the Day!
              Pic of me and my Dad
              I'll keep you updated, next one is in a fourthnight!
                cool, great reading, thanks for posting
