Re: Escort Suspension issues
I mean suspension drop rather than travel, as the rear rolls once its reached the end of its downward travel it will want to lift the rear, especially if the front is soft and has more travel than the rear???
It is lower on the back than the front. I have std height front, and 40mm lowering blocks on the back, but it sits less than 1" lower on the back. I dont think its running out of travel on the back as there nno crashing noises / bumps etc.Leave a comment:
From the photos it looks as if you dont have enough rrear suspension travel....maybe its too high at the front and low at the rear aswell as being sprung to soft at the front???Leave a comment:
Mine turns in really good aswell. It just coks the rear wheel. My brother mk2 is axactly the same set up as mine but with a vauhall red top. I do run a lot of castor tho.Leave a comment:
The only difference in set up from your car to mine is the lack of a front ARB, i run a pinto with r888 tyres, 190 front springs, 146 leafs., panhard and a twin cam arb.....rj TCA's etc. my car handles perfectly, occasionally lifts a front wheel but never 2, i would say you need stiffer front springs........i sometimes use 220ld with an ARB......your set up would be ok with road tyres but put soft rubber on and youll need to go stiffer., i also use +10mm Gp4 alloy hubs, the front end is planted and turn in is amazing with 185 tyres.Leave a comment:
Looking good, not so many mk1's out these daysLeave a comment:
I did a Motorkhana at Pembrey Circuit yersterday. We used part of the main track as well for a change. The car is still cocking a rear wheel on tight turns if you it isn't sliding (haven't changed anything yet so as expected). It was quite a wet day and used 21's on the front and old cut slicks on the rear. I tried to keep it clean and tidy driving style but was difting everywhere but did manage to finish 2nd in class and 4th overall out of 60. I will invest in 220lb springs in new year.Leave a comment:
I'm sure it is 30/65, but don't know the preload. The settings were written on the box the slip came in, but I left it with the guy who set it up for me, and doubt he has kept it. Do Gripper write the settings on the diff itself?Leave a comment:
Have you checked the LSD settings yet? as it looks Tail Happy from your Photos, that could be causing your 360 spins.Leave a comment:
Before I did the Targa rally I had a problem with the cooling system Pressurising. As much as I tried to convince my self that it wasn't the head gasket (I even fitted a new alloy rad and larger fan) I had to admit defeat in the end. With the power down on the rally a few days later the oil was milky and it was refusing to start. I couldn't be bothered to do the gasket incase it was the head cracked, so I paid my £135 to some guy on ebay and fitted another RS2000 engine. This one came with the added bonus of a bit of compression when you turned it over by hand.
I also took the opportunity to fit a lightened Sierra 1.8CVH flywheel and Pinto paddle clutch. The standard flywheel is huge and feels like it weighs twice as much.
Back to the suspension, I had the corner weights checked and with a couple of spare wheels, a tool bag in the back and nobody in the car it is actually heavier at the back. It does sit slightly high at the front. Could this be a problem?
A couple more Photos. I've got vid of me doing the slowest 360 ever, but don't know how to upload it.
Leave a comment:
Have you recently had the rear Diff settings checked? most people thick tightly set Diffs with aggressive Ramp angles are the way to go with Tarmac or Forest settings when quite the opposite is often the case. An easy Car to Drive is very often a quick one without having to wrestle your way round corners,
Two Wheel Driving might look spectacular for the Spectators but it won`t give you the quickest Time.Leave a comment:
The I4 is a big old lump but heavier engines have found thier way into scorts. I would be tempted to pull the damper out of the strut to see what dampers they are. It might even be worth just buying a set of tarmac spec dampers to fit whilst your at it. I'll be there for the track day where/how do i pay/sign up.Its a trackday on November 10th, using the circuit. £80 to club memebers. If 2 people share the same car its only £40 for the second person.
Retromotorsport / Graham. You may be right with the front damping. The front struts are the only unkown. They are thick stem struts like Bilsteins, but they don't have the rod that goes through the bottom of the casing. They could well be standard settings as far as i know. My brothers escort is similarly set up with 190 springs, but is even higher off the ground and he suffers no such problems, but he runs Grp4 struts with tarmac bilstein inserts. He has an xe engine which is also probably lighter than the rs2000 I4. It could also be my crap driving style like you say. I have no finesse.Leave a comment:
At the moment I rebuild the Racecar with a new 2 door arched shell so i can lower it more than the 4 door. And I looked to make the car as light as possible and mount everything lower than in the 4 door. But I only have 2 weeks left to get it ready for the next race.Leave a comment:
Along with what Graham said, id be looking at getting any weight I can down on the floor, including the drivers.
the higher the center of gravity, the easier it is to get onto two wheels..Leave a comment:
Leave a comment:
