Re: Escort Suspension issues
slippers are needed if your going to keep leaf springs when you 4 link, otherwise the rear suspension would bind and not be able to move up/down properly.
Could anyone tell me the advantage of those slipper springs?? Just saw them the first time.
I think I´m going to fit a second spring from a stock escort to my single on for the next event.
At Sunday the Escort drove like a Tarmac Escort should:
One wheel in the air
Can´t post the picture http://www.rennfotos.de/galerie/weit...013/index.html 7.row Pic DSC_5768Leave a comment:
yes, it's certainly been done with 4 links and slippers.
Edit. And yes it was an improvement!Leave a comment:
We drove on German Masters Slalom yesterday and had the same problem as jonsey. I talked with someone who watched the race and he says we are wo soft with the leaf springs.
Has anybody tryed to use leaf springs and a coilover spring together in the back??
Nice to meet you yesterday, car looked good in the pits but I didn't get chance to see it going
Thanks for the ratchet too.
Leave a comment:
I did the Kidwelly Targa Rally yesterday at Pembrey Cicuit. It was the first event I've done where you needed someone to navigate you. I did it with the Wife who has no experience at it what so ever. It involves a series of tests including reverse park , J turn, carousel slaloms etc, whilst navigating around Pembrey collecting code boards stopping at junctions etc. like you would on a night rally.
The 1st stage was a bit of a mare. We missed lots of code boards and tests, and picked up huge time penalties as a result. As the day went on it got better and better and on the last stage we were flying. We thoroughly enjoyed the whole day and would love to do it again (although my brother says he'll never organise another). Only prob with car was the radiator pressurising (head gasket i think), the fan fell off on stage 4 and the clutch also slipped a bit on stage 4. To over come the suspension issues I took the 888 tyres off the back and fitted a set of Nexan Skid Master Specials and has no issues all day. I was chuffed to finish and picked up an award for best turned out car. We also picked up an award for "Last Qualified Finisher" which meant we were the best losers!Last edited by jonsey; 01-09-2013, 17:04.Leave a comment:
Freddy686868 I don't have enough posts to PM yet. Nice to meet you and Luke at the Kidwelly Targa Rally yesterday. There is no build thread of it on any forums. I bought it in 1997 and raced it for a couple of seasons down pembrey tri oval circuit. It then sat in the garage for about years until i rebuilt it about 6 or 7 years ago. Just about every panel has been repaired or replaced. I do have lots of photos of the build, but have never put them on line. used it for the last few years with a x flow then 18 months ago fitted the 2.0L. Meant to ask you yesterday where can you get arp flywheel bolts from? Do you use zetec?Last edited by jonsey; 01-09-2013, 16:52.Leave a comment:
The Photo is from a 180 deg hand brake. Probably driving straight for 20 metres in 1st gear. No object was struck and its nice flat but quite grippy concrete. Will have to take the shock off after the weekend as its going on the trailer ready for tomorrow. I'm tempted to wind them up a few clicks just to help the rear break tracion a bit.Leave a comment:
Can you take a rear damper off, and then push it in and pull it out, and report back on the 'feel' ?Leave a comment:
I would only expect to see that sort of angle after launching off a bump on one side, not just turning .... unless it was .. left right left right left, setting up a pendulum effect.
You can flip most SUV's like that on road tyres..Leave a comment:
it seems like your rear end roll stiffness are much higher than the front end..you did mention about not having ARB on both end.i would suggest get it fitted(on front) to stiffen up the front end and see how it goes..Leave a comment:
Thanks all for responses. I have no ARB fitted either end. The slip is brand new and 30/65 (loose in tight out) if i remember correctly and a 4.6 ratio. It does seem to have plenty of rear grip with these tyres as it doesn't want to spin the wheels up like it did on the old ones with very little effort. It just stinks of clutch on rapid starts. I'm not driving quicker than my brother as he's not well in the head after years of dirving a morris minor on the grass with a Honda S2000 motor. This is happening at slow speed and as i've had it nearly go over (over 45deg) in the past, it doesnt inspire confidence. Should I go back to crap rear tyres which is a step backwards really, or try harder front springs as Lee sugests as it does feel like the front is sinking. Any suggestion on poundage? This is happening with 2 spare wheels tools etc and fuel so there is a lot of weight at the rear.Leave a comment:
If your not using a front arb it might be better tp try sightly harder springs or an arb but it is hard to comment like it has been said before. Do you feel the wheel on the rear lift and then grip when it touches back down? As i have had this in the past and it is down to the rear being too hard as i ran van leaf springs.Leave a comment:
Leave a comment:
