DW's Sapphire Cosworth race car
    Re: DW's Sapphire Cosworth race car
    • Sweetcorne
      • 1380
      Dave
      Outstanding mate not long now
        Fitted my 4x4 anti roll bar that I had in stock, have modified it to accept the drop links that I will be making this week (not the mocked up ones)
        Old 3 door ARBs now surplus to requirements
        • kliobas
          • Oct 2013
          One question regarding these mounts - do they make, if using the same shocks, springs, etc., sit the front of the car higher than with standard mounts ?
          Been a tough couple of months but I'm finally getting time (not much) on the cossie again.
          Am upgrading the front suspension, adjustable TCAs, comp struts and forward anti roll bar etc and these turned up today;
          New comp brake top mounts. Fit beautifully and I know the adjustment isnt as great as some but I will have other means of adjustment too.
            These top mounts are similar in ride height compared to std ones.
              Got one arch rolled nicely to cover the tyre. (pic is before starting!) Other front should be straight forward but I'm sure it will be a struggle to get the rears out as far as I need. Fingers crossed.
              Also fitted a good pair of side skirts as the white ones had seen better days. Just got to finish removing the adhesive from the door mouldings, hoping thinners or petrol might do it easier.
                Fitted the tow hook using a D shackle for now to save chopping anything about, still not convinced these will stay. Will unclip easily from the bumper in use.
                Have also acquired a set of inters, just got to sort the wheels out now, namely the 15mm too much offset on the rears. Will probably involve ordering a set with around ET35 to use as rears while keeping the ET23s on the fronts.
                  Had a bit of sun today so cleaned up the grilles and gave them a coat of paint.
                  Looks more like a car again with its Ford badge
                  • cossie daz
                    • Apr 2007
                    • 286
                    Looking good
                    • madragon199
                      • May 2010
                      • 1139
                      looking ready to race....when is the big day...cheers mark
                        • 25252
                        All strapped in nice and tight. Eyebolts at the front also clamp down the ally base and one of the rears doubles up as diff hanger bolt through the bracing. Next to bolt down the swirl pot and pumps, and finish plumbing it all in..
                        dave do you have a splash bowl to fit around that filler? blue book says it needs one
                          Not long, just needs a week in a bodyshop..
                            Will either make one or might still make a remote filler directly above.
                            • ossie cossie
                              • Jul 2005
                              • 9
                              nice work
                                One last look at the car before the big strip down ready for the paint shop..
